Random sample triggering?
2003-07-10 by jorisdeman
I'm trying to reproduce an effect I had on my old and trusty EMU E4 which worked a treat for getting realistic drum and string staccato samples. Basically you had a number of different versions for the same note (staccato var 1, staccato var 2), each assigned to a different group. Then, in the modulation page you could setup a random lfo or random trigger that would randomly choose between the groups you assigned everytime you hit the same note. Since it did this on a per note basis, the same chord played number of times would always sound different and hence, more realistic. I've tried to reproduce this in the EXSmk2, but to no avail. What I've tried so far: -set up a number of samples assigned to different groups -use a random lfo to modulate the destination: sample select although it does seem to switch randomly, it does so while the sample is playing, giving weird and unusable effects. I need to find a way to only have it randomly choose a group on the start of a note (or more exactly, the triggering of a note) and not *while* it is playing. Anyone got any ideas of how to achieve this? Cheers, Joris
