Newbi Questions - is there a ESX converter and ESX file manager
2003-07-25 by andy_email2002
Hi Guy's
Q1, Is there a file converter to convert gigasampler and other
formats to ESX ( I know about the SF and akai convertion )?
Q2, Is there a file manager to sort out the samples I want to use.
ie, when I open a sound font with 20 instruments I may only want to
keep 1 or 2. Manualy deleting/and moving instruments ( and the sound
font info )is painful.
Q3, I have instuments in a different drive form logic, can I get ESX
to look at these other drives/directories? again im doing a lot of
manual cut and paste work I would like to avoid.
Sorry about the dumb arse newby questions.
TIA
Andy.
Re: [EXS] Newbi Questions - is there a ESX converter and ESX file manager
2003-07-25 by Garth Hjelte
At 09:23 AM 7/25/03 +0000, you wrote:
>Hi Guy's
You can convert Giga using the sampler itself, just like you do SoundFonts.
There are two other 3rd-party convertors that do the trick too, while
providing better conversions and additional features
CDxtract www.cdxtract.com
Translator www.chickensys.com/translator (supports the rare ESX format as
well as the normal EXS one)
Quick digression: I can understand people _SAYING_ ESX instead of EXS (they
do so all the time), because, at least for Americuns, it's far easier to
say phonetically. But writing/typing it? I don't find it instinctively
easier to type. Yes, another "why is that?"
Maybe there could be a special ESX-24 sampler where it plays all the
samples backwards.
That's one of the things that the 3rd party convertors does, allows you to
convert single/multiple Presets or Instruments.
In order for EXS (oops, I mean ESX) to see the .exs instrument in the popup
menu on the spaceship, it has to be in the Sampler Instruments folder in
the Logic folder, or linked/aliased to it. (With the Mac, putting an alias
to another folder is an easy way to do this.) You can move your .exs files
around anywhere within these folders without penalty or injury.
The samples are a different story. The .exs files use a path system to find
the samples to load when the .exs file is loaded. So if you move these
samples, the .exs files can't find them and EXS (I mean ESX) goes an looks
for them, with an additional danger of not even finding them if conditions
are right (or wrong).
Use the Project Manager in Logic 6, if you have it, this helps resolves
things. There's also a freeware program called EXSManager for PC you can
download, and also for PC the Translator program (this feature is PC only
for now) you can also fix these sample references.
Q: Is this in the manual, or in the FAQ?
Garth Hjelte
Sampler User
Re: Newbi Questions - is there a ESX converter and ESX file manager
2003-07-25 by Nick Batzdorf
After taking between 8 and 10 hours to resolve unread files or
whatever building the database is called, my Project Manager still
takes over 15 minutes to open (meaning that's how long it takes to
read the file references and build its tree), and I've been wondering
whether it really is without penalty or injury.
I have two folders on two different drives aliased. One of them
contains the Vienna Symphonic Library and the other has a lot of
samples, so that would also explain this, but I can't help wondering
if the aliases compound the issue.
I found out about having to resolve blablabla on the VSL forum! Thank
goodness for user support, as in support from other users (although
the VSL people are excellent about the first as well).
Nick Batzdorf
818/905-9101, cell 590-9101, fax 905-5434
