2004-02-18 by lpc2000@yahoogroups.com
Hello,
This email message is a notification to let you know that
a file has been uploaded to the Files area of the lpc2000
group.
File : /ut040218A.zip
Uploaded by : wmk6341 <BillK@...>
Description : "Hello World" on UART0 with a Blinky Light, an elapsed system timer, and optional interrupts
You can access this file at the URL
http://groups.yahoo.com/group/lpc2000/files/ut040218A.zip
To learn more about file sharing for your group, please visit
http://help.yahoo.com/help/us/groups/files
wmk6341 <BillK@...>
2004-04-22 by lpc2000@yahoogroups.com
Hello,
group.
File : /LPC2106__Examples.zip
Uploaded by : prokic <mproki@...>
Description : I2C, Interrupt, UART0; Ram/Rom Config
http://groups.yahoo.com/group/lpc2000/files/LPC2106__Examples.zip
prokic <mproki@...>
2004-04-29 by lpc2000@yahoogroups.com
Hello,
group.
File : /LPC2_BlinkyCAN.zip
Uploaded by : richas <richas@...>
Description : Simple CAN Example (blinky)
http://groups.yahoo.com/group/lpc2000/files/LPC2_BlinkyCAN.zip
richas <richas@...>
Hello,
group.
File : /LPC2_FullCAN.zip
Description : FULL CAN Example
http://groups.yahoo.com/group/lpc2000/files/LPC2_FullCAN.zip
richas <richas@...>
2004-05-05 by lpc2000@yahoogroups.com
Hello,
group.
File : /SOFTWARE_EXAMPLES/ucos_ii.zip
Uploaded by : sobellinni <sobellinni@...>
Description : uC/OS
http://groups.yahoo.com/group/lpc2000/files/SOFTWARE_EXAMPLES/ucos_ii.zip
Hello,
group.
File : /SOFTWARE_EXAMPLES/forth.zip
Description : FORTH INTERPRETER
http://groups.yahoo.com/group/lpc2000/files/SOFTWARE_EXAMPLES/forth.zip
2004-05-05 by Viron Papadopoulos
Please note that UCOS is not an open source software,
you are not alloewd to distribute the source code, you
could share the os_cpu files .
Please remove the other files from zip file.
Viron .
--- lpc2000@yahoogroups.com wrote:
> Hello,
> that
> lpc2000
> group.
> Description : uC/OS
> please visit
> Regards,
Do you Yahoo!?
Win a $20,000 Career Makeover at Yahoo! HotJobs
http://hotjobs.sweepstakes.yahoo.com/careermakeover
2004-05-08 by Leon Heller
To: <lpc2000@yahoogroups.com>
Sent: Wednesday, May 05, 2004 11:46 AM
Subject: Re: [lpc2000] New file uploaded to lpc2000
Thanks, Viron. I've deleted the whole archive. Sobellini may upload the
other files if he wishes.
Leon
2004-05-17 by lpc2000@yahoogroups.com
Hello,
group.
File : /LPC2000 Flash Utility.zip
Uploaded by : philips_apps <philips_apps@...>
Description : Philips Flash Utility V2.2.0
http://groups.yahoo.com/group/lpc2000/files/LPC2000%20Flash%20Utility.zip
2004-05-23 by lpc2000@yahoogroups.com
Hello,
group.
File : /LPC2100-protel-sch-footprint.zip
Uploaded by : cbhargava <list1@...>
Description : Protel 99SE device (sch) and footprint (PCB)
http://groups.yahoo.com/group/lpc2000/files/LPC2100-protel-sch-footprint.zip
2004-07-13 by lpc2000@yahoogroups.com
Hello,
group.
File : /LPC_CANAll.zip
Description : CAN example - Processes all messages
http://groups.yahoo.com/group/lpc2000/files/LPC_CANAll.zip
2004-07-14 by lpc2000@yahoogroups.com
Hello,
group.
Description : CAN example, handles all messages
2004-08-23 by lpc2000@yahoogroups.com
Hello,
group.
File : /i2c.zip
Uploaded by : zpierre007 <zpierre007@...>
Description : functions and an example : how to use the i2c bus
You can access this file at the URL:
http://groups.yahoo.com/group/lpc2000/files/i2c.zip
To learn more about file sharing for your group, please visit:
2004-08-25 by lpc2000@yahoogroups.com
Hello,
group.
File : /PLL_calculator.zip
Description : PLL Settings Calculator
http://groups.yahoo.com/group/lpc2000/files/PLL_calculator.zip
richas <richas@...>
Hello,
group.
richas <richas@...>
2004-08-28 by lpc2000@yahoogroups.com
Hello,
group.
File : /LPCAdap.PCBDOC
Uploaded by : acetoel <acetoel@...>
Description : Adapter for the LPC2106 LQFP package
http://groups.yahoo.com/group/lpc2000/files/LPCAdap.PCBDOC
2004-08-28 by Mark Butcher
Hi All
Using IAP command I have just ported an S-record download utility to
the (LPC2106).
When the first byte to be programmed is received, a 512 byte RAM
buffer is mapped to the sector and 512 block of FLASH which it is
destined for. The present FLASH contents are copied to the block.
The code to be programmed is then collected in this 512 byte RAM
buffer until a byte for an address outside of the buffer range is
received. This causes the 512 RAM block to be copied to the
destination FLASH block (512 byte block in the destination sector)
and a new RAM block is prepared.
[Generally the S-Rec contains addresses starting from the lowest
address to the highest address without too much skipping about and
so this tends to be efficient.]
After writing the code and debugging it I tried a download of a
large S-Rec file of about 120k (from sector 0 to 14) and sent it at
19'200b/s (LPC2106 PCLK running at 28MHz). All seemed to work well.
The code is operating from RAM at the moment, since I am working
with a JTAG debugger, and so there are no problems with serial
interrupts during the download.
Later the download code will be in sector 0 of the FLASH and so it
will probably be necessary to disable interrupts during IAP commands
(at least this is the simplest solution). What I am wondering though
is how long the IAP routines actually take to execute and so what
will be the limiting download speed that is possible without loosing
serial characters?
In other words - how long does it take to execute the IAP command to
copy 512 bytes [smallest block possible] of RAM to FLASH? Does this
increase as the FLASH ages?
Is it advisable to operate the interrupts from RAM space during the
download or is this complicating the matter for a simple download?
regards
Mark Butcher
2004-08-31 by lpc2000@yahoogroups.com
Hello,
group.
richas <richas@...>
2004-09-03 by lpc2000@yahoogroups.com
Hello,
group.
File : /iolpc210x_gcc.h
Uploaded by : rzulfik <rzulfik@...>
Description : easy way to access bitfileds/regs.
http://groups.yahoo.com/group/lpc2000/files/iolpc210x_gcc.h
2004-09-14 by lpc2000@yahoogroups.com
Hello,
group.
File : /PART_ID_TABLE.pdf
Description : Part ID Table
http://groups.yahoo.com/group/lpc2000/files/PART_ID_TABLE.pdf
2004-09-16 by David Roethig
We are having problem with the Part ID
on the LPC2292 and the LPC2294.
Both chips are returning the value
0x301FF13 (50462483)
which is the value for the LPC2194.
We are using the Philips Flash Utility to
get the Chip ID.
What's going on?
Thanks
Dave
lpc2000@yahoogroups.com wrote:Show quoted textHide quoted text
> Hello,
> group.
> Regards,
> *Yahoo! Groups Sponsor*
> ADVERTISEMENT
> click here
> <http://us.ard.yahoo.com/SIG=1298nnfrg/M=295196.4901138.6071305.3001176/D=groups/S=1706554205:HM/EXP=1095268441/A=2128215/R=0/SIG=10se96mf6/*http://companion.yahoo.com>
> *Yahoo! Groups Links*
> * To visit your group on the web, go to:
> * To unsubscribe from this group, send an email to:
> lpc2000-unsubscribe@yahoogroups.com
> <mailto:lpc2000-unsubscribe@yahoogroups.com?subject=Unsubscribe>
> * Your use of Yahoo! Groups is subject to the Yahoo! Terms of
> Service <http://docs.yahoo.com/info/terms/>.
2004-10-12 by lpc2000@yahoogroups.com
Hello,
group.
File : /Timer_issue.pdf
Description : Timer_Issue
http://groups.yahoo.com/group/lpc2000/files/Timer_issue.pdf
2004-10-14 by lpc2000@yahoogroups.com
Hello,
group.
File : /TinyARM_Examples.zip
Uploaded by : tinyarmdev <Yvon1@...>
Description : Example code - LED,UART0,LCD
http://groups.yahoo.com/group/lpc2000/files/TinyARM_Examples.zip
2004-11-11 by lpc2000@yahoogroups.com
Hello,
group.
File : /blink_ADS_1_2.zip
Uploaded by : alextolkachov <alex@...>
Description : Simple example use IRQ in ADS 1.2
http://groups.yahoo.com/group/lpc2000/files/blink_ADS_1_2.zip
2004-11-22 by lpc2000@yahoogroups.com
Hello,
group.
File : /LPC2131_2132_2138_1_DS.pdf
Description : Data Sheet LPC2130-family
http://groups.yahoo.com/group/lpc2000/files/LPC2131_2132_2138_1_DS.pdf
2004-11-27 by lpc2000@yahoogroups.com
Hello,
group.
File : /4LINELCD_RTC8583_SERIAL_OK.zip
Uploaded by : jha_santosh_kr2005 <jha_santosh_kr2005@...>
Description : Drivers for LPC2106(olimex board), 4 LINE LCD, RTC8583,Serial
http://groups.yahoo.com/group/lpc2000/files/4LINELCD_RTC8583_SERIAL_OK.zip
2004-12-02 by lpc2000@yahoogroups.com
Hello,
group.
File : /LPC2129EB/LPC2129EB_REVB.pdf
Uploaded by : j_heissel <j_heissel@...>
Description : Datasheet
http://groups.yahoo.com/group/lpc2000/files/LPC2129EB/LPC2129EB_REVB.pdf
2004-12-02 by joe88250
--- In lpc2000@yahoogroups.com, lpc2000@yahoogroups.com wrote:
> Hello,
> group.
> Uploaded by : j_heissel <j_heissel@y...>
> Regards,
Hi j_heissel
could you tell me more about price and lead time for this board?
thank you!
2004-12-04 by j_heissel
> > Hello,
> > group.
> > Regards,
> Hi j_heissel
> thank you!
The modules are immediately available.
Price is 99 EURO exclusive of VAT and/or taxes.
Shipping depends on country.
J. Heissel
2004-12-06 by lpc2000@yahoogroups.com
Hello,
group.
File : /TinyArmSchematics.zip
Description : Circuit diagram of TinyARM boards
http://groups.yahoo.com/group/lpc2000/files/TinyArmSchematics.zip
2004-12-23 by lpc2000@yahoogroups.com
Hello,
group.
File : /Philips_Flash_Utility.zip
Uploaded by : mortenmllr <mortenmllr@...>
Description : Flash Utility ver. 2.2.1 for LPC213x
http://groups.yahoo.com/group/lpc2000/files/Philips_Flash_Utility.zip
2004-12-23 by Bill Knight
Where did this come from? The latest flash utility on the Philips
web site is still 2.2.0 and the .cab file is older. Maybe Philips
Apps can confirm this is safe to install and use??
-Bill Knight
On 23 Dec 2004 11:52:05 -0000, lpc2000@yahoogroups.com wrote:
Hello,
group.
2004-12-23 by johnnorgaard2003
Hi
Go into Philips, it is updated yesterday.
http://www.semiconductors.philips.com/pip/LPC2131FBD64.html
Here is also the new flash utility.
best regards
John
--- In lpc2000@yahoogroups.com, "mortenmllr" <mortenmllr@y...> wrote:
> It came directly from Philips Micro support - I believe it to be safe.
> Regards
> Morten
> > Regards
> > -Bill Knight
> > Hello,
> > group.
> > Uploaded by : mortenmllr <mortenmllr@y...>
> > Regards,
2004-12-23 by lp2000c
The links to the Flash Utility on that page do not work.
--- In lpc2000@yahoogroups.com, "johnnorgaard2003" <john_2005@c...>
wrote:
> Hi
> best regards
> John
safe.
> > Regards
> > Morten
Philips
Philips
> > > Regards
> > > -Bill Knight
> > > Hello,
> > > group.
> > > Regards,
Hello,
group.
File : /LPC2138 User Manual.pdf
Uploaded by : lp2000c <lp2000c@...>
Description : LPC 213x User Manual
http://groups.yahoo.com/group/lpc2000/files/LPC2138%20User%20Manual.pdf
2004-12-27 by lp2000c
I removed this file, because a newer version of the LPOC213x User
Manual was posted by Philips Apps at:
http://groups.yahoo.com/group/lpc2000/files/LPC213x_UM_prel_Nov22_sm.p
df
> Hello,
> group.
> Uploaded by : lp2000c <lp2000c@e...>
20Manual.pdf
> Regards,
2005-01-07 by lpc2000@yahoogroups.com
Hello,
group.
File : /lpc/lpc-h22xx-sch.gif
Uploaded by : shedon_real <shedon@...>
Description : H2294 schematic
http://groups.yahoo.com/group/lpc2000/files/lpc/lpc-h22xx-sch.gif
Hello,
group.
File : /lpc/lpc-e22xx-sch.gif
Description : LPC-E22xx Schematic
http://groups.yahoo.com/group/lpc2000/files/lpc/lpc-e22xx-sch.gif
2005-01-07 by Charles R. Grenz
Hi shedon,
Just a note. If you want USB 2.0 for the ARM7 systems with only a
few external components, we use a Silicon Labs. CP2102 chip. You just need
the USB connector, 4.7uF/5V Tantalum and a 0.1uF cap. This is a USB 2.0 to
serial bridge that can run to baud rates of 460.8K baud.
http://www.silabs.com/
Charles
From: lpc2000@yahoogroups.com [mailto:lpc2000@yahoogroups.com]
Sent: Friday, January 07, 2005 10:34 AM
To: lpc2000@yahoogroups.com
Subject: [lpc2000] New file uploaded to lpc2000
Hello,
group.
Yahoo! Groups Links
2005-01-07 by Leon Heller
Sent: Friday, January 07, 2005 3:36 PM
> Hello,
> group.
I've deleted it, as it is copyright Olimex Ltd.
Leon
Checked by AVG Anti-Virus.
Version: 7.0.300 / Virus Database: 265.6.8 - Release Date: 03/01/2005
2005-01-07 by Dmitry
> Leon
Hi Leon,
Excuse, simply I searched for schematics with LPC2292, and have not
found them here, a folder lpc22XX was empty, and when I have found
circuits have decided to place them in it to a folder that for other
them did not search, I did not know that here it is impossible to
place.
Sent: Friday, January 07, 2005 5:14 PM
>> Leon
> Hi Leon,
> place.
You could put a link to the schematics in the Links area. That way there is
no problem with copyright. Or, you could ask Olimex for permission to make
their files available.
Leon
2005-01-07 by Curt Powell
Charles,
These appear to be USB 2.0 full speed (12 Mbps) devices, not high speed (480
Mbps) devices, correct? If so then they don't differ much from other USB
interface chips such as those from ftdi, except possibly lower component
counts.
Curt
Sent: Friday, January 07, 2005 7:46 AM
Subject: RE: [lpc2000] New file uploaded to lpc2000
Hi shedon,
Charles
Hello,
group.
Yahoo! Groups Links
Yahoo! Groups Links
2005-01-08 by Rick Collins
--- In lpc2000@yahoogroups.com, "Curt Powell" <curt.powell@s...> wrote:
> Charles,
speed (480
other USB
> counts.
I'm pretty sure you won't find any high speed USB chips with an
integrated physical interface (PHY). I seem to recall that the high
speed interface requires something fundamentally different in the chip
design that would require additional mask layers, so it makes the chip
less cost effective. Is you need high speed, you can count on using a
separate PHY chip for now.
I just did a search and found a number of articles about IP vendors
adding USB PHY cores to their product line. So it may not be too much
longer before we see interface chips for high speed with the
integrated PHY.
2005-01-08 by Curt Powell
Rick,
You are probably correct. I was simply pointing out that, while meeting the
USB 2.0 spec, the chips do not support high-speed transfers (to a lot of
people USB 2.0 and high-speed are synonymous when in fact high-speed
transfers are simply an option under 2.0).
FWIW, we tried interfacing a Cypress EZ-USB SX2 chip to a '2106. The GPIO
on the '2106 simply was not fast enough to keep up with the configuration
timing requirements of the SX2 so we abandoned the attempt. Fortunately,
for our purposes, full-speed (12Mbps) is fast enough and there are lots of
options in that arena.
Curt
Sent: Saturday, January 08, 2005 12:26 AM
Subject: [lpc2000] Re: New file uploaded to lpc2000
> Charles,
speed (480
other USB
> component counts.
I'm pretty sure you won't find any high speed USB chips with an integrated
physical interface (PHY). I seem to recall that the high speed interface
requires something fundamentally different in the chip design that would
require additional mask layers, so it makes the chip less cost effective.
Is you need high speed, you can count on using a separate PHY chip for now.
I just did a search and found a number of articles about IP vendors adding
USB PHY cores to their product line. So it may not be too much longer
before we see interface chips for high speed with the integrated PHY.
Yahoo! Groups Links
2005-01-17 by lpc2000@yahoogroups.com
Hello,
group.
File : /softspi.rar
Description : Software SPI Mode 3 driver, includes Atmel Dataflash Driver
http://groups.yahoo.com/group/lpc2000/files/softspi.rar
2005-01-18 by lpc2000@yahoogroups.com
Hello,
group.
File : /resolve_missed_capture.c
Uploaded by : kerem_or <k.or@...>
Description : Interrupt function to resolve missed capture interrupts in T0/T1
http://groups.yahoo.com/group/lpc2000/files/resolve_missed_capture.c
kerem_or <k.or@...>
2005-01-25 by lpc2000@yahoogroups.com
Hello,
group.
File : /LPC2138_SCHlib.zip
Uploaded by : mpavlin969 <mp@...>
Description : LPC2138 protel SCH library
http://groups.yahoo.com/group/lpc2000/files/LPC2138_SCHlib.zip
mpavlin969 <mp@...>
2005-01-28 by lpc2000@yahoogroups.com
Hello,
group.
File : /lpc2138.lbr
Description : Eagle Library for the LC2138
http://groups.yahoo.com/group/lpc2000/files/lpc2138.lbr
richas <richas@...>
2005-02-04 by lpc2000@yahoogroups.com
Hello,
group.
File : /Philips_Flash_Utility_V2_2_1.zip
Description : Philips_ISP_Utility_V2_21
http://groups.yahoo.com/group/lpc2000/files/Philips_Flash_Utility_V2_2_1.zip
2005-02-18 by lpc2000@yahoogroups.com
Hello,
group.
File : /LPC-FlashRoutines-18Feb05.zip
Description : LPC Flash Programming Routines
http://groups.yahoo.com/group/lpc2000/files/LPC-FlashRoutines-18Feb05.zip
wmk6341 <BillK@...>
2005-02-28 by lpc2000@yahoogroups.com
Hello,
group.
File : /lpc22xx_duart.h
Uploaded by : kennethwada <kwada@...>
Description : quick access to duart using 0/1 indices
http://groups.yahoo.com/group/lpc2000/files/lpc22xx_duart.h
2005-02-28 by Anton Erasmus
Does anyone have some example code for gcc for a nested timer
interrupt ? I have googled a bit, and have found some discussion
regarding the switching of modes from interrupt mode to system mode
before re-enabling interrupts.
Anton Erasmus
A J Erasmus
2005-02-28 by Robert Adsett
Before you go too far make sure you've read the timer race conditions errata.
Robert
" 'Freedom' has no meaning of itself. There are always restrictions,
be they legal, genetic, or physical. If you don't believe me, try to
chew a radio signal. "
Kelvin Throop, III
2005-03-01 by Anton Erasmus
> errata.
I am using the LPC2292, and there is no mention in the LPC2292 errata
regarding timer problems.
http://www.semiconductors.philips.com/acrobat/erratasheets/2292.pdf
Can you maybe point me to the specific errata sheet that describes this ?
The idea is to set up a periodic interrupt of x milli-seconds. After the interrupt
has been acknowledged, interrupts are enabled again. If an overrun occurs, the
interrupt routine will be interrupted, and I can then detect this and take appropriate
action as neccesary.
Anton Erasmus
A J Erasmus
2005-03-01 by Robert Adsett
> > errata.
Take a look for Timer_issue.pdf in the files section (I'd post a link but
that seems problematic). I think this has not made the actual errata
sheets yet and AFAIK has not been addressed in any of the new devices yet
(that was certainly the case when I asked about the 213x).
>interrupt
>appropriate
You expect the timer interrupt to take multiple milliseconds? That's a
pretty busy interrupt routine. I'll take some measurements of the SPI
interrupt I'm working on if you'd like a time comparison.
Hmm, I did some performance measurements on a polled timer for the
lpc-newlib
support.
http://www.aeolusdevelopment.com/AppNotes/LPC210X/an-timerperformance.pdf
microsecond resolution, 12 microsecond minimum time, keeps track of time as
long as it's polled at least once every few minutes. The 12 microsecond
time is the overhead required to deal with various overflow, underflow and
scalings so it's doing a fair amount of work. I wouldn't expect even a
fairly busy timer routine to take the two orders of magnitude longer that
would be required to overflow a multi-millisecond timer.
Robert
Kelvin Throop, III
> > > >mode before re-enabling interrupts.
> > > conditions errata.
> >this ?
> but that seems problematic). I think this has not made the actual
> errata sheets yet and AFAIK has not been addressed in any of the new
> devices yet (that was certainly the case when I asked about the 213x).
Thanks, I will have a look.
> >the interrupt has been acknowledged, interrupts are enabled again. If
> >an overrun occurs, the interrupt routine will be interrupted, and I
> >can then detect this and take appropriate action as neccesary.
> a pretty busy interrupt routine. I'll take some measurements of the
> SPI interrupt I'm working on if you'd like a time comparison.
Yes, my main application actually runs in the timer interrupt.
Typically I use a periodic interrupt rate of 2ms. My high priority code
then executes every 2ms. This code must not take more than about 1ms
on average, and NEVER the full 2ms. After the "fast" code executes, I re-enable
interrupts, check a "slow-code" flag, and if not set, set the flag and start executing
the slow code. This code can then be interrupted by the 2ms interrupt, so that
the fast code always executes. When the interrupt returns, the "slow-code" continuse
to execute. The slow code can take up multiple 2ms cycles as needed. When the
slow code returns, it disables interrupts and returns back to the "main" code, which
in my case is just used for background debugging and Built-in-test code.
> lpc-newlib support.
> pdf
> time as long as it's polled at least once every few minutes. The 12
> microsecond time is the overhead required to deal with various
> overflow, underflow and scalings so it's doing a fair amount of work.
> I wouldn't expect even a fairly busy timer routine to take the two
> orders of magnitude longer that would be required to overflow a
As can hopefully be seen from my explanation above, I do not use
the timer interrupt to time thing per-se. I use it to implement a simple
shedular where I can garauntee that portions of my code WILL execute
every 2ms. I can then add debugging stuff, and user interfacing etc.
in the background without affecting my main application timing.
This approach has worked remarkably well on every CPU I have used except
the 8051.
Anton Erasmus
A J Erasmus
<snip>
>re-enable
>start executing
>continuse
>code, which
OK, I understand now. I would have done it as a single fast timer
interrupt portion and put both the slow portion and the background portion
in a state machine in non-interrupt mode.
A thought occurs to me inspired by the thread on SWI and VICSoftInt. You
could (depending on what other interrupts you may be using) restructure
this in a cleaner way.
- Move the timer interrupt to the FIQ
- Put the slow portion in a standard interrupt vector controlled
by the VIC (ie standard IRQ)
- Leave the background task as is
- Now when the FIQ fires it will preempt any IRQ (if running).
* in the FIQ perform the high priority task as before and
then use VICSoftInt to trigger the IRQ based interrupt if the flag is set
appropriately.
- In the IRQ perform the low priority task with flag setting
around it.
If you don't care about an immediate re-trigger of the low priority task
you could eliminate the flag communication between the two interrupts. If
you do care a little attention would need to be paid to the potential for
race conditions. I did something similar to this on an ST10 when I needed
to change the priority of an interrupt (to allow it to be interrupted) on
the fly.
I think that would work. It's been a while since I read up on VICSoftInt
so it's a bit of a throw-away suggestion.
<snip>
Robert
Kelvin Throop, III
2005-03-02 by lp2000c
Look at TIMER.1 errata for the LPC2114
http://www.semiconductors.philips.com/acrobat_download/erratasheets/21
14.pdf
I ASSUME the LPC2292 has the same problem.
errata
this ?
2005-03-02 by Anton Erasmus
> <snip>
> > > >After the interrupt has been acknowledged, interrupts are enabled
> > > >again. If an overrun occurs, the interrupt routine will be
> > > That's a pretty busy interrupt routine. I'll take some
> > > measurements of the SPI interrupt I'm working on if you'd like a
> > > time comparison.
> >code then executes every 2ms. This code must not take more than about
> >1ms on average, and NEVER the full 2ms. After the "fast" code
> >executes, I re-enable interrupts, check a "slow-code" flag, and if
> >not set, set the flag and start executing the slow code. This code
> >can then be interrupted by the 2ms interrupt, so that the fast code
> >continuse to execute. The slow code can take up multiple 2ms cycles
> >as needed. When the slow code returns, it disables interrupts and
> >returns back to the "main" code, which in my case is just used for
> portion in a state machine in non-interrupt mode.
> You could (depending on what other interrupts you may be using)
> restructure this in a cleaner way.
> controlled
> running).
> and
> set appropriately.
> around it.
> task you could eliminate the flag communication between the two
> interrupts. If you do care a little attention would need to be paid
> to the potential for race conditions. I did something similar to this
> on an ST10 when I needed to change the priority of an interrupt (to
> allow it to be interrupted) on the fly.
> VICSoftInt so it's a bit of a throw-away suggestion.
I had thought about using a FAQ + IRQ. This should work fine for two levels.
The problem is that as soon as one needs more than 2 levels, one will have to
use nested IRQs or FIQs. I have found this sort of multi-level interrupt structure the
easiest to implement on Motorola processors. They seem to put a lot of effort into their
IRQ architecture. And so far the only app note I have found on nested interrupts on the
ARM, is for the Freescale ARM series of MCUs. Unfortunately so far I have been
unable to find the code that goes with the app-note. I have found some documentation
about this from ARM, but it is for use with their compiler which currently provides much
better interrupt support in C than gcc.
Anton Erasmus
A J Erasmus
2005-03-09 by lpc2000@yahoogroups.com
Hello,
group.
File : /timer.zip
Uploaded by : hughokeeffe <hugh.okeeffe@...>
Description : Ashling Nested Timer Interrupt Example (using GNU Compiler/Assembler)
http://groups.yahoo.com/group/lpc2000/files/timer.zip
2005-03-10 by lpc2000@yahoogroups.com
Hello,
group.
File : /I2C_lib.zip
Uploaded by : ytremil <ytremil@...>
Description : I2C lib for LPC21XX . Supports EEPROM(from 24XX04 to 24XX512),RTC DS1307, I/O Ext PCA9555,Temp sensor LM75
http://groups.yahoo.com/group/lpc2000/files/I2C_lib.zip
2005-03-18 by lpc2000@yahoogroups.com
Hello,
group.
File : /schematic_and_fooprint_LPC2129_protel.zip
Uploaded by : domingos_bento <dasbento@...>
Description : LPC2129 Schematic and footprint Protel
http://groups.yahoo.com/group/lpc2000/files/schematic_and_fooprint_LPC2129_protel.zip
2005-05-30 by lpc2000@yahoogroups.com
Hello,
group.
File : /EXAMPLE.F
Uploaded by : holinepu <holinepu@...>
Description : LPC210x monitor --assembly language program
http://groups.yahoo.com/group/lpc2000/files/EXAMPLE.F
2005-06-13 by lpc2000@yahoogroups.com
Hello,
group.
File : /ARMMONITOR2.F
Description : monitor program runs under ARM chip LPC210x with Forth like instruction
http://groups.yahoo.com/group/lpc2000/files/ARMMONITOR2.F
2005-06-20 by lpc2000@yahoogroups.com
Hello,
group.
File : /LPC213xpower.pdf
Uploaded by : owenmooney <ojm@...>
Description : Power Down Testing LPC213x
http://groups.yahoo.com/group/lpc2000/files/LPC213xpower.pdf
2005-06-24 by lpc2000@yahoogroups.com
Hello,
group.
File : /LPC2142_48 (preliminary).pdf
Uploaded by : philips_marketing_usa <philips_marketing_usa@...>
Description : LPC214x Preliminary Datasheet
http://groups.yahoo.com/group/lpc2000/files/LPC2142_48%20%28preliminary%29.pdf
2005-07-05 by lpc2000@yahoogroups.com
Hello,
group.
File : /Keil2130_Eclipse_Lynchzilla_Tutorial_Blinky.zip
Uploaded by : flying_wookie1 <flying_wookie@...>
Description : Lynchzilla Eclipse Tutorial. Blinky for Keil MCB2130
http://groups.yahoo.com/group/lpc2000/files/Keil2130_Eclipse_Lynchzilla_Tutorial_Blinky.zip
2005-07-05 by Blagoj Kupev
Hi to all,
I'm new in ARM7 world, and now I'd like to buy jtag compatible interface
for debugging/programming issues. I saw that Amontec offers interesting
tool: "Cameleon" that can work as Macraigor's Raven, but i need opinion
from experienced users of ARM7 processors. Also I'm considering UJTAG
from Keil? Please help me to make right choice, or maybe you can propose
to me other JTAG. I want to use it with gnu tools, or IDE's that support
GNU compilers/tools like Keil.
Best regards,
Blagoj
2005-07-05 by Leon Heller
Sent: Tuesday, July 05, 2005 8:02 AM
Subject: [lpc2000] Amontec's Cameleon POD
> Hi to all,
My JTAG design in the Files area works fine as a Wiggler-alike, and will run
faster than the real thing. I've got an Amontec Chameleon and that also
works OK for me, emulating a Raven. I've only used them with the LPC2106.
FWIW, The Chameleon also worked OK as a Xilinx Parallel Cable III when I
tried it with a Xilinx CPLD.
Leon
[This E-mail has been scanned for viruses but it is your responsibility
to maintain up to date anti virus software on the device that you are
currently using to read this email. ]
2005-07-05 by Paul Curtis
Buy the Bulgarian Special... You just can't go wrong at the price. :-)
Paul Curtis, Rowley Associates Ltd http://www.rowley.co.uk
CrossWorks for MSP430, ARM, AVR and now MAXQ processors
> From: Blagoj Kupev [mailto:bkupev@...]
> Sent: 05 July 2005 10:29
> Subject: Re: [lpc2000] Amontec's Cameleon POD
> Hi Heller,
> Do you think it is worth to spend money on Cameleon or i
> should stay on wiggler?
> Regards,
> Blagoj
> Na 05.07.2005 12:15 Leon Heller rece:
> >----- Original Message -----
> >From: "Blagoj Kupev" <bkupev@...>
> >>Hi to all,
> interesting
> need opinion
> considering UJTAG
> you can propose
> that support
> and that also
> the LPC2106.
> Cable III when I
> >Leon
> responsibility
> >Yahoo! Groups Links
> >__________ NOD32 1.1159 (20050630) Information __________
> >This message was checked by NOD32 Antivirus System.
> >http://www.nod32.com
Hi Heller,
Do you think it is worth to spend money on Cameleon or i should stay on
wiggler?
Blagoj
>>Hi to all,
>Leon
>Yahoo! Groups Links
Sent: Tuesday, July 05, 2005 11:28 AM
> Hi Heller,
> wiggler?
> Regards,
If the Wiggler is fast enough for you and you don't need to use other
devices like FPGAs, there isn't much point in changing.
Leon
Sent: Tuesday, July 05, 2005 11:27 AM
Subject: RE: [lpc2000] Amontec's Cameleon POD
You do need to link pins 8 and 15 at the DB-25 connector, for it to work
with the current MacRaigor software. I don't think that Olimex have got
round to modifying it yet.
It's fine with the Rowley tools, of course.
Leon
2005-07-05 by Rod Moffitt
As long as you use an older version of the macraigor tools (see my site
below) you don't need the hardware mod:
ftp://stimpy.nuked.org/rod/arm/macraigor/
- Rod
___ ____ ___ _ ___
Rod Moffitt / _ \/ __ \/ _ \ (_)__ / _/__
http://rod.info / , _/ /_/ / // / / / _ \/ _/ _ \
rodANTISPAM@... /_/|_|\____/____(*)_/_//_/_/ \___/
~ Where loved ones are remembered http://memoriam.org ~Show quoted textHide quoted text
On Tue, 5 Jul 2005, Leon Heller wrote:
> From: "Paul Curtis" <plc@...>
> Leon
2005-07-05 by tsvetanusunov
price. :-)
thanks Paul ;)
work
got
Leon, you are wrong, all our ARM-JTAGs shipped after January this
year have the 8-15 mod
Best regards
Tsvetan
PCB prototypes for $26 at http://run.to/pcb
(http://www.olimex.com/pcb)
PCB any volume assembly (http://www.olimex.com/pcb/protoa.html)
Development boards for ARM, AVR, PIC, MAXQ2000 and MSP430
(http://www.olimex.com/dev)
2005-07-06 by soren_t_hansen
> work
> got
It depends ... I bought one in april that wasn't modified. I bought it
through demotech in Denmark.
/Søren
2005-07-21 by lpc2000@yahoogroups.com
Hello,
group.
File : /Linux Bootloader Utilities/lpc2k_pgm_1.02.tar.gz
Uploaded by : pauljs97140 <Paul@...>
Description : Linux GTK GUI-based Bootloader Utility (GPL'd source)
http://groups.yahoo.com/group/lpc2000/files/Linux%20Bootloader%20Utilities/lpc2k_pgm_1.02.tar.gz
Hello,
group.
File : /Keil2130_Eclipse_Lynchzilla_Tutorial_Blinky_01.zip
Description : Update 01: Lynchzilla Eclipse Tutorial. Blinky for Keil MCB2130, fixed clock settings for the board and the serial routines work correctly.
http://groups.yahoo.com/group/lpc2000/files/Keil2130_Eclipse_Lynchzilla_Tutorial_Blinky_01.zip
2005-08-17 by lpc2000@yahoogroups.com
Hello,
group.
File : /UM10139_1.ZIP
Description : LPC214x User Manual
http://groups.yahoo.com/group/lpc2000/files/UM10139_1.ZIP
2005-10-12 by lpc2000@yahoogroups.com
Hello,
group.
File : /PLCC44-LPC2103.jpg
Description : Pinout PLCC44 for LPC2101/2102/2103
http://groups.yahoo.com/group/lpc2000/files/PLCC44-LPC2103.jpg
2005-10-13 by lpc2000@yahoogroups.com
Hello,
group.
File : /LPC214x.h
Description : LPC214x Header File
http://groups.yahoo.com/group/lpc2000/files/LPC214x.h
2005-10-20 by lpc2000@yahoogroups.com
Hello,
group.
File : /Tools/lpc2kuart.exe
Uploaded by : joelw_94089 <joelw@...>
Description : LPC214x - Use to determine the optimal UART baudrate reg settings
http://groups.yahoo.com/group/lpc2000/files/Tools/lpc2kuart.exe
2005-11-09 by lpc2000@yahoogroups.com
Hello,
group.
File : /ISP1181B_FOR_LPC2214.pdf
Uploaded by : yodathgreat <christophe.darnet@...>
Description : LPC2214 + ISP1181 Schematic
http://groups.yahoo.com/group/lpc2000/files/ISP1181B_FOR_LPC2214.pdf
2005-11-13 by lpc2000@yahoogroups.com
Hello,
group.
File : /fat-2005-01-24.zip
Uploaded by : seangra <sgraham@...>
Description : FAT File System Module by Alexei A. Frounze
http://groups.yahoo.com/group/lpc2000/files/fat-2005-01-24.zip
2005-11-23 by lpc2000@yahoogroups.com
Hello,
group.
File : /VirtualCOM.zip
Description : Virtual COM Port driver using Philips LPC214x USB
http://groups.yahoo.com/group/lpc2000/files/VirtualCOM.zip
2005-11-23 by Dan Beadle
Thanks for getting the copyright issue resolved. I will definitely use
this
I have already adapted their mass storage class. Well written code
_____
Sent: Wednesday, November 23, 2005 11:00 AM
Hello,
group.
_____
YAHOO! GROUPS LINKS
* Visit your group "lpc2000
<http://groups.yahoo.com/group/lpc2000> " on the web.
Service <http://docs.yahoo.com/info/terms/> .
_____
2005-12-02 by lpc2000@yahoogroups.com
Hello,
group.
File : /LPC2103_Preliminary_UM_small.zip
Description : LPC2103 Users Manual without internal Links size optimized, Dec 2, 2005
http://groups.yahoo.com/group/lpc2000/files/LPC2103_Preliminary_UM_small.zip
2005-12-11 by Doug Sutherland
A while ago a virtual com port driver was uploaded. I have been
wondering about this: is it possible to create a virtual com port
driver on USB MCU that does not require any driver installation
on windows? I would like the virtual com port to behave like mass
storage and keyboard/mouse devices, when they are plugged in they
are immediately available. Why do these work without host drivers
while all virtual com ports I see require special drivers?
Doug
2005-12-11 by Joel Winarske
Yes. USB CDC 1.1 ACM Serial Emulation.
I implemented this as one of my design requirements is to support Win32, Mac
OS X, and Linux. USB CDC ACM will work without a "driver" for all three.
Plugging into a Win32 machine requires a .inf file, no driver, Apple does
not, it simply works. On Windows the driver will maintain the same port
assignment when moving between USB ports. The Mac OS X is the most
conforming to the actual spec. I posted the CDC implementation requirements
on the Apple USB list. I will be testing on Linux sometime this week.
All of the examples I've found of USB CDC ACM on the internet are
non-conformant with the spec, and will not work directly on the Mac, and
possibly Linux.
Joel
2006-01-06 by lpc2000@yahoogroups.com
Hello,
group.
File : /lpc2.hex
Uploaded by : jayasooriah <jayasooriah@...>
Description : Intel Hex Loader for LPC2000
http://groups.yahoo.com/group/lpc2000/files/lpc2.hex
2006-01-16 by lpc2000@yahoogroups.com
Hello,
group.
File : /NOPCEVAL.ZIP
Uploaded by : pjakacki <peterjak@...>
Description : LPC2138 noPC with token threaded Forth and VGA
http://groups.yahoo.com/group/lpc2000/files/NOPCEVAL.ZIP
Hello,
group.
File : /OpenTCP-lpc.zip
Uploaded by : szemzoa <saam@...>
Description :
http://groups.yahoo.com/group/lpc2000/files/OpenTCP-lpc.zip
szemzoa <saam@...>
2006-01-18 by atmelbr
I cant find the file OpenTCP-lpc.zip
"The requested file or directory is not found on the server."
MarcioShow quoted textHide quoted text
> Hello,
> group.
> Uploaded by : szemzoa <saam@k...>
> Description :
> Regards,
> szemzoa <saam@k...>
2006-01-31 by lpc2000@yahoogroups.com
Hello,
group.
File : /EE_demo_1_1.zip
Description : EE_demo ver. 1.1
http://groups.yahoo.com/group/lpc2000/files/EE_demo_1_1.zip
2006-02-10 by lpc2000@yahoogroups.com
Hello,
group.
File : /LPC214x_SampleSoftware.zip
Description : Sample Software for LPC213x/214x FIO, EXT_INT, I2C, SPI, RTC, WDT, UART, PWM, Timer, etc.
http://groups.yahoo.com/group/lpc2000/files/LPC214x_SampleSoftware.zip
2006-03-10 by lpc2000@yahoogroups.com
Hello,
group.
File : /RVDK.zip
Description : Update of Sample Code Bundle for LPC213x/LPC214x peripherals using ARM's RealView, added ADC, SSP, etc.
http://groups.yahoo.com/group/lpc2000/files/RVDK.zip
Hello,
group.
File : /Keil.zip
Description : Sample Code Bundle for LPC213x/LPC214x peripherals using ARM/Keil's uVision
http://groups.yahoo.com/group/lpc2000/files/Keil.zip
2006-03-27 by lpc2000@yahoogroups.com
Hello,
group.
File : /Linker and CRT/LPC2103 Linker and Startup.zip
Uploaded by : fordp2002 <SimonEllwood@...>
Description : A Jim Lynch Scipts and CRT modified to suit the LPC2103 in flash
http://groups.yahoo.com/group/lpc2000/files/Linker%20and%20CRT/LPC2103%20Linker%20and%20Startup.zip
Hello,
group.
File : /efsl_prj_LPC2138.zip
Uploaded by : mukadder_c <mukadder_c@...>
Description : EFSL project for LPC213X ported to Keil ARM (By mukadder_c@...)
http://groups.yahoo.com/group/lpc2000/files/efsl_prj_LPC2138.zip
2006-03-29 by lpc2000@yahoogroups.com
Hello,
group.
File : /Tools/CANBTR.py
Uploaded by : tennessee_cv <tennessee.carmelveilleux@...>
Description : Python script to calculate best CANBTR value for CAN baudrate
http://groups.yahoo.com/group/lpc2000/files/Tools/CANBTR.py
2006-04-04 by lpc2000@yahoogroups.com
Hello,
group.
File : /rprintf.c
Uploaded by : nuncio_bitis <nuncio.bitis@...>
Description : Embedded systems version of printf/sprintf
http://groups.yahoo.com/group/lpc2000/files/rprintf.c
2006-05-11 by lpc2000@yahoogroups.com
Hello,
group.
File : /gcc_and_ucosii.zip
Uploaded by : dave_w_hawkins <dwh@...>
Description : How to use GCC to build microcontroller programs (startup and linker files), and a port of uCOS-II using nested interrupts (uCOS-II source not included, get it from the 2nd Ed book)
http://groups.yahoo.com/group/lpc2000/files/gcc_and_ucosii.zip
