Lpc2000
tcpip
tcpip
2006-01-13 by Szemző András
Hello,
I'd ported OpenTCP to lpc2292 with rtl8019. I'll add cs8900 and enj28j60 drivers. (All of them working with ported avrlib netstack with lpc2292, so it will be trivial.)
I add a very basic and simple device structure, becouse i would like to use slip too, and then add ppp, etc...
Somebody interested to help developing it? ;)
Andrew
Re: tcpip
2006-01-13 by atmelbr
--- In lpc2000@yahoogroups.com, Szemzõ András <a.szemzo@k...> wrote:
Hello,
   Where I can find more information about OpenTCP ?
> Hello,
> Andrew
RE: [lpc2000] Re: tcpip
2006-01-13 by Joel Winarske
> Hello,
http://sourceforge.net/project/showfiles.php?group_id=66182
Re: [lpc2000] tcpip
2006-01-15 by Rob Jansen
Andrew,
Yes, I am interested.
I've got different boards to do this on, but no lpc2292.
I am currently interfacing the enc28j60 to my board. For my project I do
not need a full TCP stack, I was just asked to show that the enc28j60 is a
workable ethernet solution for a few other projects.
So all I _must_ do is to show a working MAC with the enc, but a full
tcp/ip solution may be so much easier to demo ...
I have the enc28j60 connected to SPI0 and use GCC.
Just drop me an email if you're interested - I can add the 28j60 driver.
I have also en Embedded Artists 2138 board with a DM7000 (10/100 Mb
Ethernet) and can maybe add that driver also.
      Rob
> Hello,
> Andrew
RE: [lpc2000] tcpip
2006-01-15 by Joel Winarske
Hi Andrew,
I may be interested in adding ppp/slip.  The OpenTCP code has much better
documentation than lwip, or uip.
GCC?
Joel
Re: [lpc2000] tcpip
2006-01-15 by Don Ingram
Joel Winarske wrote:
> Hi Andrew,
> GCC?
> Joel
Out of curiosity, how does this compare in performance or functionality to
Ethernut on ARM? There is also an LPC port for this under way.
Cheers
Don
RE: [lpc2000] tcpip
Here's a brief overview of free stacks, in alphabetical order:
Nut/Net (Ethernut) - IPV4, TCP, UDP, ICMP, PPP (minimal) - PAP, stack
documentation?  fragmented packet support?
lwIP 1.1.0 - IPV4, IPV6, TCP, UDP, DHCP, ICMP, PPP - PAP, CHAP, VJ, minimal
documentation, fragmented packet support.
OpenTCP - IPV4, TCP, UDP, DHCP, ICMP, DNS, BOOTP, TFTP, SMTP, POP3, HTTP,
good documentation.  Fragmented packet support?
uIP - IPV4, TCP, UDP, DHCP, SMTP, POP3, HTTP, TELNET, FTP, VNC, IRC, PPP -
PAP, zero documentation, no fragmented packet support.  See Contiki project
for recent code base.
On the ones that support POP3 and SMTP, it appears clear text authentication
is only implemented.  Most modern ISPs require more than this.
The best performing would be dependent on a number of variables - in no
particular order:
1.  I/O bandwidth to EMAC.  This could be a combination of EMAC receive
buffer size, DMA between EMAC and RAM, bit banged port, polled driver, or
interrupt driven I/O.
2.  EMAC hardware filtering - prevents MCU from handling unwanted traffic
3.  Available MCU RAM.
4.  Protocol stack - buffer management.  Zero copy?  Does stack offer
predefined memory pool or is malloc() required?
5.  Protocol stack - CRC implementation.  Some silicon offers hardware CRC
to increase throughput.  Example - Maxim/Dallas DS80C4xx series.
etc. etc.
These are not specific to ARM, but Ethernet in general.  From here you weigh
your design requirements, the MCU features, and the protocol stack.  The
integration of the EMAC can be the biggest performance variable.
HTH,
Joel
RE: [lpc2000] tcpip
2006-01-15 by Paul Curtis
Joel,
> VNC, IRC, PPP -
No, Documentation is extensive:
http://www.sics.se/~adam/uip/uip-0.9-refman/
Wrong.  Set UIP_REASSEMBLY.
http://www.sics.se/~adam/uip/uip-0.9-refman/a00088.html#a1
Paul Curtis, Rowley Associates Ltd  http://www.rowley.co.uk
CrossWorks for MSP430, ARM, AVR and now MAXQ processors#
Re: [lpc2000] tcpip
2006-01-15 by Marko Panger
Recently I was in the same dilemma. Is the OpenTCP project still active
? I am about to integrate a TCP stack in my RTOS and I am choosing with
which one to go.
marko
http://usmartx.sourceforge.net
>particular order:
>etc. etc.
>HTH,
>Joel
>Yahoo! Groups Links
RE: [lpc2000] tcpip
> > VNC, IRC, PPP -
Ah yes, my bad.  Thank you for pointing these out Paul.
Corrections and comments are always welcome.
Joel
RE: [lpc2000] tcpip
Joel,
> still active
> choosing with
> > which one to go.
> Last release of OpenTCP: 2003-08-03
> The last post may sum it up on OpenTCP:
> http://sourceforge.net/forum/forum.php?thread_id=1031838&forum
> _id=224425
> Paul what where the big differences between lwIP and uIP?
lwIP has a sockets-like API, uIP doesn't.  lwIP has many more
TCP/IP-related features than uIP does (windowing, for example) and will
potentially have a better throughput for applications that are streaming
data.  uIP has a single segment in flight at any time hence falls foul
of delayed ACK implementations of TCP/IP (cf Windows at least).  uIP
applications are harder to write than lwIP apps as uIP does not use
threads (but there is something called protothreads that you *can* use
to make life easier).  lwIP is bigger in RAM and code size, uIP is small
in both.  uIP runs a full web server on MSP430s in 8K of code with a
fully-compliant stack and less than 1K of memory (and that's with a big
packet buffer).
If you have space issues, uIP is the way to go.  If you don't, then lwIP
is more the thing.
RE: [lpc2000] tcpip
Hi Marko,
> which one to go.
http://sourceforge.net/forum/forum.php?thread_id=1031838&forum_id=224425
Joel
RE: [lpc2000] tcpip
> packet buffer).
> is more the thing.
Paul thanks for the excellent summation.
Can anyone with Ethernet Nut/Net experience comment?
Joel
Re: [lpc2000] tcpip
2006-01-16 by Don Ingram
>>is more the thing.
<< Apologies in advance for the infomercial, I have no commercial connection,
  just very pleased with the results >>
  I can not comment on the internal IP stack structure of EtherNut beyond saying
the following:
- EtherNut & it's co-operative RTOS are effective on small footprint embedded
systems, it started on an 8 bit AVR. It is there & it works with many years of
history in a broad range of commercial apps.
- The stack uses the single copy of the packet & doesn't copy between layers.
This is explained in the document "Ethernut Software Manual" on the documents
page, the link for which is given below.
- It is actively being developed and supported by it's author and user-base.
~ 10 postings per day on forum. The big kids don't poke fun at me when I ask
dumb noob questions.
- It is functionally documented - http://www.ethernut.de/en/documents/index.html
- Reference hardware is available from the author at www.egnite.de
- It has a configuration system which allows even GNUuoobs such as me to be able
to readily build it and use it with either GCC or some other commercial compilers.
- In short I can easily run the comprehensive range of examples and make the
leds flash without too much hair loss. This alone may allow me to get to a point
where I <can> make intelligent comment about stack internals at a later date.
- The author hasn't done what a number of other open source projects have done &
used contributors as beta testers before sealing off further open source
development and going closed commercial... So far ;-)
- There is an ARM7 version but it is currently targeted at an older Atmel
AT91R40008 ARM device which greatly pre-dates the SAM7 & LPC2xxx
- Another contributor is currently doing an LPC2xxx port but as yet the source
has not been made available. http://www.usbdip.de/en/ethernut2294/index.html  It
is built with the crossworks compiler
- Contributors appear to be waiting to see how the cards fall in the latest
Philips / Atmel ARM based product releases before advancing the ARM port.
Shouldn't be long however.
- The stack seems to have a consistent, functional community that is generous
with it's contributions and support. People come and go & have done so for many
years leaving extra bits on the stack. The stack just slowly gets better. That
is important if you are going to spend the time getting up to speed with it.
In my particular case with the XNut hardware product which also uses the
Ethernut stack ( similarly well supported by it's creator www.focus-sw.com )  we
got from concept to invoiceable application in no time flat & for me that is
what keeps the customer happy & the family fed.  I eagerly await the new ARM
based units.
Cheers
Don
Re: [lpc2000] tcpip
2006-01-16 by FreeRTOS Info
> packet buffer).
> is more the thing.
Just to demonstrate Pauls points...
uIP is a really nice, small and easy to understand system.  It's major
disadvantage is that only one packet can be outstanding at any one time.
This is less of a problem if you have control over both ends of the
communication, but can make streaming data to (for example) Windoze rather
slow.
The following page generates a lot of dynamic data and sends it as one
packet (this uses a non standard port number so if you are on a company
network or behind certain firewalls it will not load):
http://82.32.114.142:47822/cgi/rtos
It should load quickly.  On the other hand the following page generates
dynamic data one line at a time, and sends each line individually.  You
should find this then loads much more slowly as Windoze delays acknowledging
each packet (same firewall restrictions apply).
http://82.32.114.142:47822/cgi/tcp
Therefore, uIP can work with very small buffers but this then restricts the
throughput you can achieve.  Like everything it is a trade off.
lwIP is a much fuller implementation that removes this restriction at the
expense of more CPU cycles and more RAM.  Also the driver required for the
NIC is more complex.  If you look at the SAM7X emac drivers for the
respective FreeRTOS uIP and lwIP demos you will see the former is much
simpler due to the simple buffer management in uIP.
Richard.
http://www.FreeRTOS.org
RE: [lpc2000] tcpip
2006-01-16 by Joel Winarske
Hi Richard,
> slow.
Any plans to have a live lwIP demo?  This would be a nice A-B test to your
live uIP demo.
Joel
Re: [lpc2000] tcpip
> live uIP demo.
The lwIP demo uses the same hardware as the uIP demo so they cannot both be
live at the same time.  The demo is also a bit basic with just a single page
of dynamic text being returned.  As it was not live I didn't do anything
fancy (the uIP demo uses frames and contains graphics if you go to the root
rather than the links I gave).
There is a live LPC2124 / Crystal LAN CS8900 demo.  This is basically Pauls
code running (practically unmodified) as a task under FreeRTOS.org.  Due to
hardware limitations it bit bangs the NIC and does not use interrupts.  See
http://www.freertos.org/embeddedtcp.html for the various links.
Richard.
RE: [lpc2000] tcpip
> be
> page
> root
Perhaps you might periodically rotate between the two?
> Pauls
> to
> See
This one does not load in Firefox, IE is fine.  "Alert - The document
contains no data".
Joel
tcpip
2006-01-16 by Szemző András
I'd uploaded  OpenTCP-lpc.zip to the files section.
Andrew
Re: [lpc2000] tcpip
> > See
> contains no data".
Err, that's not good.  Just looked at the file and it doesn't have the
<html></html> parts.  I think this was doxygen created originally.  Need to
go through and check all the pages for this, but am surprised Firefox
doesn't make a stab at displaying it.
Richard.
RE: [lpc2000] tcpip
hi,
and what about that?
http://sourceforge.net/projects/freescaleotcp/
Andrew
From: lpc2000@yahoogroups.com [mailto:lpc2000@yahoogroups.com] On Behalf Of
Joel Winarske
Sent: Sunday, January 15, 2006 11:08 PM
To: lpc2000@yahoogroups.com
Subject: RE: [lpc2000] tcpip
Hi Marko,
> which one to go.
Joel
SPONSORED LINKS
Microprocessor
<http://groups.yahoo.com/gads?t=ms&k=Microprocessor&w1=Microprocessor&w2=Mic
rocontrollers&w3=Pic+microcontrollers&w4=8051+microprocessor&c=4&s=93&.sig=t
sVC-J9hJ5qyXg0WPR0l6g>  	Microcontrollers
<http://groups.yahoo.com/gads?t=ms&k=Microcontrollers&w1=Microprocessor&w2=M
icrocontrollers&w3=Pic+microcontrollers&w4=8051+microprocessor&c=4&s=93&.sig
=DvJVNqC_pqRTm8Xq01nxwg>  	Pic microcontrollers
<http://groups.yahoo.com/gads?t=ms&k=Pic+microcontrollers&w1=Microprocessor&
w2=Microcontrollers&w3=Pic+microcontrollers&w4=8051+microprocessor&c=4&s=93&
.sig=TpkoX4KofDJ7c6LyBvUqVQ>
8051 microprocessor
<http://groups.yahoo.com/gads?t=ms&k=8051+microprocessor&w1=Microprocessor&w
2=Microcontrollers&w3=Pic+microcontrollers&w4=8051+microprocessor&c=4&s=93&.
sig=1Ipf1Fjfbd_HVIlekkDP-A>
YAHOO! GROUPS LINKS
	*	 Visit your group "lpc2000
<http://groups.yahoo.com/group/lpc2000> " on the web.
*	 To unsubscribe from this group, send an email to:
<mailto:lpc2000-unsubscribe@yahoogroups.com?subject=Unsubscribe>
*	 Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service
<http://docs.yahoo.com/info/terms/> .
RE: [lpc2000] tcpip
Hi Andrew,
It's fairly recent.  August 31, 2005.
Only ten of the OpenTCP-1.0.4.src files are modified.  Most changes are
compiler related.  http_server.c seems to have the largest delta.  On others
the only changes are removal of the license header, and include directories.
I would start with this version over OpenTCP-1.0.4.src, as there are some
useful looking changes.
Joel
Re: [lpc2000] tcpip
2006-01-16 by Mauricio Scaff
Here I use firefox and it works fine.
> > be
> > page
> > root
> > Pauls
> > to
> > See
> contains no data".
> Joel
> SPONSORED LINKS
> Microprocessor
> <http://groups.yahoo.com/gads?t=ms&k=Microprocessor&w1=Microprocessor&w2=Microcontrollers&w3=Pic+microcontrollers&w4=8051+microprocessor&c=4&s=93&.sig=tsVC-J9hJ5qyXg0WPR0l6g>
> 	Microcontrollers
> <http://groups.yahoo.com/gads?t=ms&k=Microcontrollers&w1=Microprocessor&w2=Microcontrollers&w3=Pic+microcontrollers&w4=8051+microprocessor&c=4&s=93&.sig=DvJVNqC_pqRTm8Xq01nxwg>
> <http://groups.yahoo.com/gads?t=ms&k=Pic+microcontrollers&w1=Microprocessor&w2=Microcontrollers&w3=Pic+microcontrollers&w4=8051+microprocessor&c=4&s=93&.sig=TpkoX4KofDJ7c6LyBvUqVQ>
> 8051 microprocessor
> <http://groups.yahoo.com/gads?t=ms&k=8051+microprocessor&w1=Microprocessor&w2=Microcontrollers&w3=Pic+microcontrollers&w4=8051+microprocessor&c=4&s=93&.sig=1Ipf1Fjfbd_HVIlekkDP-A>
> YAHOO! GROUPS LINKS
>       <http://groups.yahoo.com/group/lpc2000>" on the web.
>       Service <http://docs.yahoo.com/info/terms/>.
RE: [lpc2000] tcpip
It works fine on the AT91SAM7X demo, and not the Crystal demo.  I had the
same results some time back.  If I browse the Crystal demo in IE, it's fine.
I'm running the default install on Firefox, no tweaks.
Re: [lpc2000] tcpip
Here too.
Win XP Pro.
Firefox 1.5
http://82.32.114.142:47821/
http://82.32.114.142:47820/
all of them works fine.
> fine.
> YAHOO! GROUPS LINKS
RE: [lpc2000] tcpip
> Here too.
> Win XP Pro.
> Firefox 1.5
Hmm.    First round the second listed was giving me "The document contains
no data."  After multiple tries through the list then the second worked and
the first start complaining.  Are all of these running uIP I wonder?
XP
Firefox 1.0.7
Re: [lpc2000] tcpip
> > Here too.
> > Win XP Pro.
> > Firefox 1.5
and
> XP
> Firefox 1.0.7
The 47820 port is using a WizNET I2C interface.
The 47821 is Pauls uIP demo bit banging a Crystal LAN running as a task
under FreeRTOS (LPC).
The 47822 is uIP running with interrupts and DMA on a SAM7X.
The number of simultaneous connections is limited (#define in the code).  If
you look at a page that sends lots of small packets then each takes a
connection.  I imagine that posting the addresses here is generating several
simulations hits, so maybe its just running out of connections hence the
intermittence.
All works fine for me, but the boards are only a few feet away.  Also I'm
using IE rather than Firefox.
Richard.
RE: [lpc2000] tcpip
IE loads them fine on my machine.  On the ones in question, in IE there is a
delayed load between the header and body.
It's a curious difference between Firefox and IE.
A tracert of 82.32.114.142 results in over 30 network hops.  This may have a
bearing on things.  Are you in the UK?  I'm in California.
Joel
> > > Here too.
> > > Win XP Pro.
> > > Firefox 1.5
> contains
> and
> > XP
> > Firefox 1.0.7
> If
> several
> intermittence.
Re: [lpc2000] tcpip
2006-01-16 by Sean
Just a "me too", they all work fine for me (WinXP IE6) but they are
sloooowwww...
At 04:23 PM 1/16/2006, you wrote:
> > > Here too.
> > > Win XP Pro.
> > > Firefox 1.5
> > > <http://82.32.114.142:47821/>http://82.32.114.142:47821/
> > > <http://82.32.114.142:47822/cgi/tcp>http://82.32.114.142:47822/cgi/tcp
>and
> > XP
> > Firefox 1.0.7
>intermittence.
>Regards,
>Richard.
><http://www.FreeRTOS.org>http://www.FreeRTOS.org
>SPONSORED LINKS
><http://groups.yahoo.com/gads?t=ms&k=Microprocessor&w1=Microprocessor&w2=Microcontrollers&w3=Pic+microcontrollers&w4=8051+microprocessor&c=4&s=93&.sig=tsVC-J9hJ5qyXg0WPR0l6g>Microprocessor
><http://groups.yahoo.com/gads?t=ms&k=Microcontrollers&w1=Microprocessor&w2=Microcontrollers&w3=Pic+microcontrollers&w4=8051+microprocessor&c=4&s=93&.sig=DvJVNqC_pqRTm8Xq01nxwg>Microcontrollers
><http://groups.yahoo.com/gads?t=ms&k=Pic+microcontrollers&w1=Microprocessor&w2=Microcontrollers&w3=Pic+microcontrollers&w4=8051+microprocessor&c=4&s=93&.sig=TpkoX4KofDJ7c6LyBvUqVQ>Pic
>microcontrollers
><http://groups.yahoo.com/gads?t=ms&k=8051+microprocessor&w1=Microprocessor&w2=Microcontrollers&w3=Pic+microcontrollers&w4=8051+microprocessor&c=4&s=93&.sig=1Ipf1Fjfbd_HVIlekkDP-A>8051
>microprocessor
>YAHOO! GROUPS LINKS
>    *  Visit your group "<http://groups.yahoo.com/group/lpc2000>lpc2000"
> on the web.
> <mailto:lpc2000-unsubscribe@yahoogroups.com?subject=Unsubscribe>lpc2000-unsubscribe@yahoogroups.com
> <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service.
Re: [lpc2000] tcpip
a
a
Yep - UK - just a few thousand miles away.
Richard.
Re: [lpc2000] tcpip
> sloooowwww...
Even this one? http://82.32.114.142:47822/cgi/rtos
My contribution to this thread started by saying that uIP could be sped up
by sending dynamic data as single buffer rather than lots of small ones -
using this link as an example compared to the other links.  The standard uIP
demo from Adam Dunkels site sends each dynamically generated item
separately - hence lots of delayed acks and a slow connection to Windoze.
From here I find this page loads quickly, but I'm not 30hops away.
Richard.
RE: [lpc2000] tcpip
I've never had a problem with this one.  It's quite reasonable even 30+ hops
away.
Joel
Re: [lpc2000] tcpip
2006-01-16 by Marko Pavlin (home)
OK, just another "metoo".
lynx 82.32.114.142:47821 works just fine:
Task          State  Priority  Stack    #
uIP             R       3       64      0
PolSEM1         R       0       84      8
PolSEM2         R       0       84      9
IDLE            R       0       99      13
SUSP_RX         R       0       88      7
C_CTRL          R       0       90      5
CNT_INC         R       0       91      3
QConsNB         B       2       99      1
QProdNB         B       2       92      2
BlkSEM1         B       1       84      10
BlkSEM2         B       1       84      11
Check           B       4       100     12
SUSP_TX         B       0       94      6
LIM_INC         S       1       95      4
it shows two frames.
But traceroute gets lost somewhere... over 30 hops (from Slovenia)...
-bash-2.05b$ traceroute -p47821 82.32.114.142 0x40
traceroute to 82.32.114.142 (82.32.114.142), 64 hops max, 64 byte packets
 1  BSN-access.dsl.siol.net (213.250.19.90)  38.685 ms  24.747 ms  13.518 ms
 2  213.250.19.169 (213.250.19.169)  13.265 ms  12.290 ms  13.234 ms
 3  213.250.18.97 (213.250.18.97)  14.052 ms * *
 4  kklag1-176-57.net.uta.at (212.152.176.57)  52.157 ms  21.890 ms
47.014 ms
 5  C76wmode1-tengigE-4-2.net.uta.at (212.152.192.174)  22.154 ms
36.087 ms  58.871 ms
 6  vie3-core.gigabiteth1-0.swip.net (130.244.205.57)  23.852 ms  45.033
ms  24.089 ms
 7  fra2-core.pos12-0.swip.net (130.244.193.154)  68.209 ms  73.552 ms
69.963 ms
 8  weis-core-1.pos0-0.swip.net (130.244.194.181)  145.105 ms  109.349
ms  92.789 ms
 9  some.frankfurt.router.Level3.net (130.244.200.86)  39.166 ms  67.372
ms  60.312 ms
10  ae-0-53.bbr1.Frankfurt1.Level3.net (195.122.136.65)  38.923 ms
70.912 ms ae-0-55.bbr1.Frankfurt1.Level3.net (195.122.136.97)  57.105 ms
11  as-0-0.bbr1.London1.Level3.net (4.68.128.109)  120.925 ms  93.313
ms  75.871 ms
12  ae-0-17.gar1.London1.Level3.net (212.187.131.169)  54.945 ms
ae-0-15.gar1.London1.Level3.net (212.187.131.137)  56.411 ms
ae-0-17.gar1.London1.Level3.net (212.187.131.169)  91.576 ms
13  195.50.91.2 (195.50.91.2)  55.339 ms 195.50.91.6 (195.50.91.6)
55.799 ms  70.178 ms
14  azt-tele1-pos.telewest.net (194.117.136.1)  103.056 ms  73.372 ms
66.472 ms
15  195.188.230.5 (195.188.230.5)  59.610 ms  138.936 ms  223.461 ms
16  195.188.230.58 (195.188.230.58)  86.663 ms  105.322 ms  65.731 ms
17  195.188.230.188 (195.188.230.188)  59.584 ms  93.585 ms  97.788 ms
18  * * *
Sorry for garbage :)
> there is
> a
> may have
> a
> Richard.
Re: [lpc2000] tcpip
2006-01-16 by Sean
Sorry, my bad, the last one loads fast, the other 3 are pretty slow.
-- Sean
> > sloooowwww...
>Even this one?
><http://82.32.114.142:47822/cgi/rtos>http://82.32.114.142:47822/cgi/rtos
>Regards,
>Richard.
Re: tcpip
2006-01-17 by Mark Butcher
Hi All
Just to make things a little more complicated. We also offer a
TCP/IP stack with integrated operating system, a simulator and
project support for GNU and IAR Embedded work bench. It is available
freely to educational establishments and also supported by Email.
Since it is also used for commercial projects, it is presently
restricted to the above mentioned distribution. It is also only
available for Freescale MC9S12NE64 and ATMEL AT91SAM7X projects (as
soon as the new LPC is available it will also get a project)
The operating system and stack include the standard things plus FTP
with FLASH or serial SPI EEPROM file system, Telnet, dynamic HTTP
and fits (when all activated) into about 15k..20k of FLASH and need
about 3k of RAM (depending on the resource defined).
There are a few demos on line at www.mjbc.ch (login always using
user name "anon" and password "anon"). These use the NE64 as basis
since the ATMEL is still only avilable in limited quantities and so
there are not enough here for permanent demos. The NE64 devices have
limited resources and so do not use transmission windowing.
Apart from the published demos there is also a development device in
a DMZ at 212.254.22.36 which can be (anonymous) FTP'ed to (not PAS
mode) if anyone wants to see it working. On the FTP server are the
individual web page files which can be updated, copied and deleted
(but please don't change anything...). Since the FTP here is
designed for maintenance (web page mods etc.) it supports only a
single connection at a time whereas the web server
(http://212.254.22.36:8084 will do loads in parallel). In fact this
device also supportes software uploads and also debugging via the
internet and is being used for real development whenever there is an
Internet connection available - saves having to carry the hardware
around if on the move...). It can also be Telnet'ed to, but both web
server and Telnet are password protected; I wonder whether someone
can still get in...?
The advantage of this solution (although it presently doesn't have a
wide platform support) is that it includes a simulator which means
that real network traffic can be recorded using Ethereal and played
back through the code. It makes for much improved development and
debug support since it is possible to debug occurances at remote
locations as long as there was an Ethereal recording of the events
which can be supplied - playing back through the code using the
simulator allows all details to be analysed and code improvements
and corrections even to be verified. It is also very helpful when
learning the protocols and code since the frames can be easily
displayed in the debugger and each step analysed - very useful for
educational establishments...
Mark Butcher
Re: tcpip / ATMEL AT91SAM7X
2006-01-18 by Mark Butcher
Hi Richard
I know that you ported FreeRTOS to the SAM7X - we did have a few
mail exchanges about it and other things in the past.
It seems as though the AT91SAM7 Yahoo group no longer exists - at
least I haven't been able to find it for a few weeks now - I get
only an error message and searching for it also turns up a blank
(very strange because it was an interesting group).
As it happens I have 'finally' got the SAM7x chips (engineering
samples) and they are soldered onto new boards and beginning to do
some stuff.
I am hoping to complete a port by the beginning of next week but my
first experiences have shown that things don't always work out as
well as expected and it may well take a biiiit longer. I have a
couple of questions:
1. Do you know where this topic is now being discussed. I don't
really know of any other good active group.
2. Did you do a project for IAR? I am using this with J-Link
debugger and have lost a lot of time because as soon as I had
stopped the code my PIT interrupt would never come again. Firstly it
made it difficult to know what was going on when initially getting
the interrupt up and running (not knowing that the debugger was
causing problems...) and then having to restart after a breakpoint
was also very annoying.
I think that I know why because after closing a memory window it
seems to work (quite) well. It seems as though the memory window
update was causing the PIT registers to be read and resetting
(interrupt related) things in the process. Do you know of this
problem and work-arounds???
3. Presently I am loading part of the project into RAM so that the
debugging works well but the code size will not always allow this -
it will soon have to go into FLASH. Do you have any experience /
tips about how it is best to go about this ? [I would like to
generally use the serial debug interface and debug difficult cases
in FLASH with J-Link].
4. My project needs serial and Ethernet and I have a Micrel PHY. I
supose you used the DAVICON on the Eval board. Do you have any tips
about things to watch out for in the process?
Sorry that not directly LP2000 related (ATMEL standing in until the
new LPC Ethernet part is available) but I think that a lot of ATMEL
group members are also lurking around here..
Mark Butcher
www.mjbc.ch
--- In lpc2000@yahoogroups.com, "FreeRTOS Info" <nospam@F...> wrote:
> > > Here too.
> > > Win XP Pro.
> > > Firefox 1.5
document contains
worked
> and
wonder?
> > XP
> > Firefox 1.0.7
task
code).  If
takes a
generating several
hence the
> intermittence.
Also I'm
> Regards,
> Richard.
2006-01-18 by PeterElliot
Try the following:
http://groups.yahoo.com/group/AT91SAM/
PJE
Re: [lpc2000] Re: tcpip / ATMEL AT91SAM7X
2006-01-18 by FreeRTOS Info
Seems to work for me:  http://groups.yahoo.com/group/AT91SAM/
Not as active as the LPC group.
>some stuff.
Odd how long that has taken.  I thought they were more available than that.
>I am hoping to complete a port (non-pre-emptive port, so rather
>easier) by the beginning of next week but my first experiences have
>shown that things don't always work out as well as expected. I have
>a couple of questions:
You could try http://www.at91.com.  There is a forum, but I have not
used/read it more than once or twice so I don't know how active it is.
I have used the J-Link without too many problems.  It occasionally hangs up
and requires me to shut down the IDE in order to make a connection again,
but this is only when downloading code.  Check the .mac file that you are
using (the macros that are run on debug events).  There seem to be a lot
around and some are not full implementations.  Original versions did not
reset interrupts properly so the debug session would only work once per
board reset.
>I think that I know why because after closing a memory windows it
>seems to work (quite) well. It seems as though the memory windows
Should have read that before writing the above ....
Never come across this problem.  I use the memory window quite extensively,
but maybe not over the PIT register region.
I have not used the serial debug interface, and think there may be some
conflict with using the PIT for the timer.  Can't quite remember without
checking the data sheet.
Sorry, never used a Micrel PHY.  I know the original SAM7X Atmel eval boards
had a timing error in the design that meant RMII interface did not work
properly, so I hope you didn't copy the design ;-)   MII works fine.
Richard.
2006-01-18 by Don Ingram
> Try the following:
Also for SAM7X + I/P
The discussion can be seen in the archive at the bottom of the page here:
http://www.egnite.de/pipermail/en-nut-discussion/2006-January/thread.html
The group is also eagerly waiting to see the LPC offering with ethernet.
Don
