Lpc2000
decent reset device
decent reset device
2004-06-06 by itsjustimpossible
Hi
We have just received the IAR LPC2106 eval board, and are having
trouble with power-up resets. I am using the NOHAU PSU that came
with our other eval board which doesn't have a particularly fast
rise-time.
I need to lay a board out, but can anyone recommend a decent reset
device that they have used. MAXIM do some good ones but their lead
time can be very long.
cheers
Simon
Re: [lpc2000] decent reset device
2004-06-06 by Shannon Holland
The Microchip MCP120T is really easy to use. digikey has them in stock,
they have an open drain reset output so they are really easy to
interface to existing circuits (just don't for get the pullup!).
Shannon
On Jun 6, 2004, at 12:51 PM, itsjustimpossible wrote:
> Hi
> rise-time.
> cheers
> Simon
2004-06-06 by Robert Wood
 time can be very long. <<
LM809 works for me and is easy to get hold of.
Re: decent reset device
2004-06-13 by itsjustimpossible
Thanks for both the suggestions, this gives me a couple of options
to look at.
cheers
Simon
reset
2005-02-07 by maestral64
> Shannon
> > Hi
> > rise-time.
> > cheers
> > Simon
> > Yahoo! Groups Links
> >Yes, Microchip has few more devices like MCP809/810 and you caln
also find ON SEMI MAX809TTR.
My problem is that I would like to use 'faster' reset, with reset
delay time up to 100ms. By datasheet 2114 needs min 10 ms. For
Microchip circuit time delay is 140 ms min, up to 0.5 sec(!) max.
Any idea/recomendation? Again, I am little bit sceptical to use rC
circuit reset in professional stand-alone application.
Miodrag
2005-02-07 by charlesgrenz
Miodrag,
Try a Texas Instruments TPS3306-20-Q1. It resets with a 100ms pulse.
There are also other versions that have a reset of different values.
regards,
Charles
stock,
> > Shannon
> > > Hi
> > > rise-time.
> > > cheers
> > > Simon
> > > Yahoo! Groups Links
> Regards,
> Miodrag
Re: [lpc2000] Re: decent reset device
2005-02-08 by Peter Jakacki
>Regards,
>Miodrag
Shouldn't this have been a new thread???
The problem with reset chips is that they are overly expensive (why?)
and customized. I find it cheaper to employ an 8-pin micro
(PIC12F,LPC900)complete with power-on timer/brown-out detect etc. I can
configure these for my reset threshold, reset time etc. These micros are
typically stand-alone, not requiring any external circuitry such as
crystal etc to operate.
PLUS!, there is always the bonus of having it monitor the coms line and
being able to reset or ISP the main processor as well as being able to
operate as an independant configurable watchdog.
Summary:
Configurable intelligent watchdog/reset/monitor *costs less* than a
fixed reset chip.
my2cents
*Peter*
Checked by AVG Anti-Virus.
Version: 7.0.300 / Virus Database: 265.8.6 - Release Date: 2/7/05
2005-02-08 by jan_c_weber
stock,
> > Shannon
> > > Hi
> > > rise-time.
reset
lead
> > > cheers
> > > Simon
> > > Yahoo! Groups Links
> Regards,
> Miodrag
How about the Texas Instruments TPS383x (x = 6, 7, 8) series?
HTH,
Jan
2005-02-08 by maestral64
> stock,
> > > Shannon
> > > > Hi
> > > > rise-time.
> reset
> lead
> > > > cheers
> > > > Simon
> > > > Yahoo! Groups Links
> > Regards,
> > Miodrag
> HTH,
> Jan
Well,
I found something that looks like perfect solution (and I am always
concerned when I think something is perfect) - TPS70751 and TPS70851.
5V to 3.3V and 1.8V (dual output) plus  MR and Enable input and RESET
output. 1.2$/1K, 2.18Euro in Digikey. I am checking voltage thresholds
 for reset at the moment.
Again, that has no sense with new LPC213xx (I am thinking a lot should
I just switch SCH which is almost at the end to new micro.)
TPS383x is nice IC ( I used it with MSP430) but has one bad feature -
threshold voltage for reset is 2.93V nominal(2.84-2.99).
ARM in general(LPC21xx as well)works from 3-3.6V so 2.93V it could
cause bad reset.
Miodrag
Charles,
Reset threshold for that device is 2.93V for 3.3V(as standard for TI
supervisors)which is too low for ARM processors (3.0V min). I am not
sure about 1.8V threshold- did you try this with LPC211x?
Miodrag
--- In lpc2000@yahoogroups.com, "charlesgrenz" <charles.grenz@s...> wrote:
> Miodrag,
> regards,
> Charles
> stock,
> > > Shannon
> > > > Hi
> > > > rise-time.
> > > > cheers
> > > > Simon
> > > > Yahoo! Groups Links
> > Regards,
> > Miodrag
This is definitely very interesting idea I heard some time ago.
I am considering that as well.
There is also 68HC908 which is automotive approved.
Only critical thing is reset of this small devices (micros) reliability.
It will be bad if small micro would not be properly reseted.
If I have some time in future I will try to apply test with few
thousands resets - ideally on different temperatures(-20, +70) to see
what is reliability (or there is guarantie from manufacturer about this?)
Miodrag
> >Regards,
> >Miodrag
are
> Summary:
> fixed reset chip.
> my2cents
> *Peter*
2005-02-08 by Robert Adsett
<snip>
>Summary:
>fixed reset chip.
But to how low a voltage do they operate.  A good reset chip will provide a
low output down to about 0.8V.  It would be a real problem if the 8 pin
micro's brown-out circuitry kicked in and caused the reset line to float at
say 1.7V.  I suppose you could reverse the problem and use a resistive
pulldown and override that with a positive output but then you need to know
how high a resistance you can use and still provide a reset voltage
(particularly at low VCC), is that specced anywhere?
Robert
" 'Freedom' has no meaning of itself.  There are always restrictions,
be they legal, genetic, or physical.  If you don't believe me, try to
chew a radio signal. "
                         Kelvin Throop, III
Yes, I always use a resistive pulldown for that very reason, but why do
worry about how high a resistance? Granted, I usually use between 10K
and 100K which is never a problem with a CMOS input. There are in fact
two CMOS inputs in this state, the reset micro's reset output(input),
and the main reset input. The reset line can only see a low as there is
no voltage source from the reset micro even down to very low voltages.
I've scoped this before under all kinds of nasty power up/downs. A
circuit that is intrinsically in reset unless all systems are go is a
very safe way to handle the reset.
This way works extremely well and permits ISP/reset over remote links.
Well, that's the way I handle things in this area and others may have
their own ideas. But that's what these discussions are good for, it's a
real melting pot of ideas and experiences. Although.... there's the
occasional flame that shoots up and chars a few bits too... :)
*Peter*
If it's that high I don't worry.  I just want to keep the input below 1/2 a
volt or so (at 10K that's 50uA, sounds doable).  A good deal of my
hesitance is that I simply haven't sat down and worked it through.  This helps.
<snip>
That's good to hear.
>A circuit that is intrinsically in reset unless all systems are go is a
That's what I'm looking for.
I've always liked that idea.  Also if you incorporate a real watchdog in
the processor it should be simple to add an output latch so you can flag
that the watchdog has fired (nice for some timing related debugging).
Melt away :)
Robert
                         Kelvin Throop, III
