Lpc2000
olimex LPC-E2294 with ethernet
2005-02-07 by Gus
Hello,
I spent all weekend trying to get the ethernet to work on olimex LPC-
E2294 board http://www.olimex.com/dev/lpc-e2294.html with no luck
Looking at the board schematics, they have the Ethernet
chip "selected" all the time through R57!!! This is WRONG!! I don't
understand why!!! So I removed R57 and installed R56 instead. Now,
when I read the chip, I always get the "chip ID" no matter what
register I select!
Was anyone able to read the registers from CS8900A? Any hints? Even
with thier test code, I wasn't able to get things going. The plan is
to get uIP going on that board http://www.sics.se/~adam/uip/
Gus
RE: [lpc2000] olimex LPC-E2294 with ethernet
2005-02-07 by Paul Curtis
Gus,
I ported uIP to the E2124 and it works on that part, but that's in
polled mode.  I don't have a port of uIP for that board as I don't have
the board.
If you have any success with it, please let me know--I'd be interested
to see what you make of the board as it's way over specified to run uIP,
better would be lwIP.
Paul Curtis, Rowley Associates Ltd  http://www.rowley.co.uk
CrossWorks for MSP430, ARM, AVR and (soon) MAXQ processors
> From: Gus [mailto:gus_is_working@...]
> Sent: 07 February 2005 15:39
> To: lpc2000@yahoogroups.com
> Subject: [lpc2000] olimex LPC-E2294 with ethernet
> Hello,
> Looking at the board schematics, they have the Ethernet chip
> don't understand why!!! So I removed R57 and installed R56
> instead. Now, when I read the chip, I always get the "chip
> ID" no matter what register I select!
> hints? Even with thier test code, I wasn't able to get things
> going. The plan is to get uIP going on that board
> Thanks,
> Gus
Re: olimex LPC-E2294 with ethernet
2005-02-07 by Gus
I sm actually starting out with your code. The major work here is
that, in this case, the ethernat chip is connected to the external
bus as 16-bit. So, I have to change your driver to use the external
bus. It seems easy to me but I always read the "chip id" no matter
what I do!!!! I think the write_register() code is not working in my
case.
The big goal is to run IwIP in the fututre or any full TCP/IP stack.
Gus
--- In lpc2000@yahoogroups.com, "Paul Curtis" <plc@r...> wrote:
> Gus,
have
> the board.
interested
run uIP,
> > From: Gus [mailto:gus_is_working@y...]
> > Hello,
LPC-
> > Thanks,
> > Gus
> > Yahoo! Groups Links
RE: [lpc2000] Re: olimex LPC-E2294 with ethernet
Gus,
> LPC-
> instead. Now,
> > > register I select!
For register reads, I believe that is really doesn't matter that the
chip is always selected using /CHIPSEL as it will only present or latch
data on an IOR or IOW strobe.  However, I have not used the chip in its
16-bit mode; it looks like the registers are memory mapped to
0x0000'0300.
Can you post a small piece of code that reads and writes the registers?
2005-02-07 by Gus
Paul,
> latch data on an IOR or IOW strobe.
Yes that is correct but we have FLASH and RAM on the bus!!! when RD
is strobed for RAM read, the ethernet chip will access the data bus.
I could be wrong somehow!
I am trying to do it in 8-bit now, was 16!! I just want to get it to
work for a starter. I am using the code posted on olimex website
unsigned short cs8900a_read(unsigned addr)
  unsigned short Data1,Data2;
  pAdd_CS = (unsigned char*)(CS8900A_BASE+addr);
  Data1 = *pAdd_CS;
  Data2 = ((*++pAdd_CS) << 8);
  return(Data1|Data2);
  // the folowing should work as well since we have 16 bit bus
 // return *((unsigned short *)(CS8900A_BASE+addr));
void cs8900a_write(unsigned addr, unsigned int data)
  *pAdd_CS = data;
  ++pAdd_CS;
  *pAdd_CS = data>>8;
void cs8900a_init(void)
int i;
// I am using this since the folowing code will not work
BCFG2=0x00003501;
  // CS8900A 8bit;
  BCFG2_bit.MW = 0;
  // IDCY = 1+1 ~ 33ns
  BCFG2_bit.IDCY=1;
  // WST1 = 8+3 (read)  ~183ns
  BCFG2_bit.WST1=8;
  // WST2 = 6+1 (write) ~ 117ns
  BCFG2_bit.WST2=6;
  // RBLE = 1 - ako e 0 ne zapiswa
  BCFG2_bit.RBLE = 1;
  // WP =0, BM = 0
  BCFG2_bit.WP = BCFG2_bit.BM = 0;
// this code was not changed from the example
  // P3.25 - CS2 (CS8900A)
  // P3.0 - A0
  PINSEL2 |= 0x00804000;
//read chip id
 cs8900a_write(ADD_PORT,0);
  i = cs8900a_read(DATA_PORT);
  if (i != CRYSTAL_SEMI_ID)
    while(1);
// read revesion
  cs8900a_write(ADD_PORT,0x2);
  i = cs8900a_read(0xC);
// i will still be the "manufacture id" no matter what register I
select
Gus
> Gus,
olimex
> > LPC-
luck
don't
> > instead. Now,
what
> > > > register I select!
latch
in its
> 0x0000'0300.
registers?
Gus,
> when RD is strobed for RAM read, the ethernet chip will
IOR and IOW are gated using CS2 (look down by the copyright symbol)
hence even though CHIPSEL is always selected, you won't get an IOR or
IOW strobe unless CS2 is selected, I think--I'm not particularly good
with this type of thing.
> get it to work for a starter. I am using the code posted on
> olimex website
> unsigned short cs8900a_read(unsigned addr) {
>   Data1 = *pAdd_CS;
> bus  // return *((unsigned short *)(CS8900A_BASE+addr)); }
> void cs8900a_write(unsigned addr, unsigned int data) {
>   *pAdd_CS = data;
>   ++pAdd_CS;
>   *pAdd_CS = data>>8;
This sort of looks OK modulo volatile.
> int i;
> BCFG2=0x00003501;
>   // CS8900A 8bit;
>   BCFG2_bit.MW = 0;
>   BCFG2_bit.IDCY=1;
>   BCFG2_bit.WST1=8;
>   BCFG2_bit.WST2=6;
>   BCFG2_bit.RBLE = 1;
>   // WP =0, BM = 0
>   // P3.0 - A0
> //read chip id
>     while(1);
> // read revesion
> register I select
Need to assume that the bitfield stuff workds of course.  It seems you
probably haven't written the address correctly in the first place and
the address port defaults to zero.  What's your cs8900a_write function
like after you modified it?
Also, have you reset the CS8900A and waited for it to come out of reset?
  // Reset the CS8900A
  cs8900a_write(ADD_PORT, PP_SelfCTL);
  cs8900a_write(DATA_PORT, POWER_ON_RESET);
  // Wait until chip-reset is done
  cs8900a_write(ADD_PORT, PP_SelfST);
  while ((cs8900a_read(DATA_PORT) & INIT_DONE) == 0)
I don't know whether this makes any difference or not, or is the
manufacturing data only available after a POR or somesuch?
2005-02-07 by Gus
Paul,
I didn't see that LOL!! But why olimex did that anyways? weard!
I removed the changes and trying to use this one unmodefied
  *pAdd_CS = data;
  ++pAdd_CS;
  *pAdd_CS = data>>8;
Gus
> Gus,
or
or
good
> > olimex website
> >   Data1 = *pAdd_CS;
> >   *pAdd_CS = data;
> >   ++pAdd_CS;
> >   *pAdd_CS = data>>8;
> > int i;
> > BCFG2=0x00003501;
> >   // CS8900A 8bit;
> >   BCFG2_bit.MW = 0;
> >   BCFG2_bit.IDCY=1;
> >   BCFG2_bit.WST1=8;
> >   BCFG2_bit.WST2=6;
> >   BCFG2_bit.RBLE = 1;
> >   // WP =0, BM = 0
> >   // P3.0 - A0
> > //read chip id
> >     while(1);
> > // read revesion
> > register I select
you
and
function
reset?
Re: [lpc2000] olimex LPC-E2294 with ethernet
2005-02-07 by Anton Erasmus
On 7 Feb 2005 at 15:38, Gus wrote:
> Hello,
> register I select!
They qualify the IOR and IOW signals with CS2, hence one will only read from, write
to the chip when CS2 is active. They probably could have achived the same by
connecting CS2 to the CS8900 Chip select pin, and OE to IOR and WE to IOW.
   Anton Erasmus
A J Erasmus
Hi Gus,
>   *pAdd_CS = data;
>   ++pAdd_CS;
>   *pAdd_CS = data>>8;
Looks fine; I guess the next step is to scope the waveforms arriving at
the CS8900A.
2005-02-08 by Gus
I got it to work last night. The problem is that olimex board has
the chip connected to 16-bit data bus but it will NOT work. It works
in 8-bit mode only.
What are the negative things about uIP? I used telnet and http last
night and it worked fine!
Gus
> Hi Gus,
> >   *pAdd_CS = data;
> >   ++pAdd_CS;
> >   *pAdd_CS = data>>8;
arriving at
> the CS8900A.
2005-02-08 by Paul Curtis
Gus,
> has the chip connected to 16-bit data bus but it will NOT
> work. It works in 8-bit mode only.
> http last night and it worked fine!
The negative things?  The fact you need to intertwine the application
with the stack; no socket interface; only one packet in flight at any
one time; not a "standard" programming interface; lacks many features
such as DHCP client... And so on.
Re: [lpc2000] Re: olimex LPC-E2294 with ethernet
2005-02-08 by 42Bastian Schick
> in 8-bit mode only.
AFAIK, the cs8900a starts in 8bit mode, and has to be switched to 16bit
mode.
But did read this only in a Phytec manual for the mpc565.
42Bastian Schick
2005-02-08 by Gus
As far as I understand, this is imposibble on the olimex board
because of the SBHE# pin.
If I am wrong, please correct me.
why olimex is not responding to this post?
Gus
--- In lpc2000@yahoogroups.com, 42Bastian Schick <bastian42@m...>
works
> > in 8-bit mode only.
16bit
> mode.
> 42Bastian Schick
Gus,
I fear you may be 100% correct.  SBHE is held high, sigh.  I think
you're buggered for 16-bit mode, mate.  Perhaps Olimex didn't test the
Ethernet interface in 16 bit mode, only 8 bit mode.  It might have been
useful if one of the INTRQ lines was connected up too.
You might want to take a look at
http://www.thearmpatch.com/lpc-sbc2.html which has a CS8900A on it.
We've just received one, courtesy of Bill Knight, and I'll take a look
at it at some point, but I'm sure CrossWorks will sprout a BSP for it
real soon.
> Sent: 08 February 2005 15:43
> Subject: [lpc2000] Re: olimex LPC-E2294 with ethernet
> board because of the SBHE# pin.
> Gus
> works
> > > in 8-bit mode only.
> 16bit
> > mode.
> > 42Bastian Schick
Gus,
Checking the LPC-SBC2 and talking to Bill Knight confirms that this
board is ready to rock when it comes to Ethernet in 16 bit mode (and
interrupt driven even).  Probably a better bet than the Olimex board;
bit of a shame about the Olimex board, though.
Rgds,
> Gus
> works
> > > in 8-bit mode only.
> 16bit
> > mode.
> > 42Bastian Schick
2005-02-08 by tsvetanusunov
> Hello,
LPC-
> register I select!
Hi Gus,
Sorry for the late reply, but I have full time job also :)
The CS8900A is connected correctly, so you don't have to swap R56 and
R57, anyway it will work in both cases.
In the current version CS8900A will work in 8-bit mode only and with
polling (no interrupts). This is the way this boards was intend to
work (our engineers decided to make it "compatible" to LPC-E212x) ,
the 16 bit data bus was wired by mistake ;) it doesn't make any
problems though. I catched this issue on very late stage when 300
boards were alerady assembled.
Our new OKI-E5003 which now is routing will have 16-bit mode and
interrupts supported.
Best regards
Tsvetan
PCB prototypes for $26 at http://run.to/pcb
(http://www.olimex.com/pcb)
PCB any volume assembly (http://www.olimex.com/pcb/protoa.html)
Development boards for ARM, AVR, PIC, and MSP430
(http://www.olimex.com/dev)
read from, write
the same by
to IOW.
not really, according to CS8900A datasheets CHIPSELECT is used only
in Memory mode, in IO and DMA mode *should* be connected to ground.
Best regards
Tsvetan
