Lpc2000
IAR interrupt problem
2004-09-21 by ducatman2000
I'm trying to enable interrupt with timer1 on the LPC2106. I
configured Timer1 as IRQ source when its value correspond with the
match register 0... but interrupt routine service doesn't run and is
never reached. Here is a piece of my code:
  __disable_interrupt(); // IAR intrinsic
//VIC enable registers
  VICProtection=0x0;
//clears bits in the Interrupt Enable register
  VICIntEnClear=0xffffffff;
  VICIntEnable=0x20;    //Timer1
  VICIntSelect=0x00;    //all interrupts are IRQs
  VICVectCntl0=0x25;
  VICVectAddr0=(unsigned long)&Timer1ISR;
  __enable_intrinsic();
  Then I also initialize Timer1:
  T1_IR=0x00;
  T1_MR0=TIMERMATCH;
  T1_MCR=0x03;  // reset timer and fire interrupt
  T1_PR=0x0;
  T1_TC=0x00;
  T1_TCR=0x01;  // start the timer
__arm __irq void Timer1ISR(void) //Timer1 ISR
T1_IR=0x01; //reset interrupt flag
VICVectAddr=0; //reset VIC
return;
My questions are:
- what is wrong with this code?
- could it be a problem with the intrinsic functions of IAR
__enable_interrupt() and __disable_interrupt(); they seem not to
work; does anybody their asm code??
Any help would be appreciated!
thanx
Re: IAR interrupt problem
2004-09-21 by Leighton Rowe
I'm curious about 2 things.
1. "__enable_intrinsic()"
   Is this really the function you used or do you really mean
__enable_interrupt().
2. Where is your IRQ Handler? The only time I used "_irq" was to
define the IRQ handler...not the ISR.
something like...
__arm __irq void IRQ_handler(void)
 ISRAddress = VICVectAddr;     //load source address
 (*ISRAddress)()               //function call
 return;
That way ISRs get called by the handler whenever any enabled
interrupt channel is activated.
Some example code should come with your IAR compiler...somewhere in
the /ARM/src directory. Make sure u look at those. They'll come in
very handy.
Leighton
--- In lpc2000@yahoogroups.com, "ducatman2000" <545545@b...> wrote:
> Hi,
is
>   VICProtection=0x0;
>   VICVectCntl0=0x25;
>   T1_IR=0x00;
>   T1_MR0=TIMERMATCH;
>   T1_PR=0x0;
>   T1_TC=0x00;
> return;
> My questions are:
> thanx
Simple tone generators for lpc
2004-09-21 by Curt Powell
Can anyone steer me towards some simple tone generators that can easily be
interfaced to the lpc using gpio (as few pins as possible) or i2c?  Nothing
fancy, we need to control frequency and duration (volume will be controlled
manually if at all).
Re: Simple tone generators for lpc
2004-09-21 by markcrow
--- In lpc2000@yahoogroups.com, "Curt Powell" <curt.powell@s...>
easily be
Nothing
controlled
Take a look at using a PWM output.
2004-09-22 by ducatman2000
You are right, I made a mistake writing my previous mail, it was not
__enable_intrinsic() but of course __enable_interrupt().
Now I have introduced the IRQ Handler exactly as you told me. In that
way, the Timer1 ISR should be called by the irq_handler whenever an
interrupt occurs. BUT, it sill not work! In debug mode I can see the
timer incrementing and when it reaches the match value register, it
resets and put the IR1 bit to '1' but the ISR is never reached... I
think there is a problem with the IAR intrinsic __enable_interrupt()
and __disable_interrupt(). In step by step mode, when the
__enable_interrupt() is executed, that blocks the programm... Any
idea of the problem, or do you know the asm code of __enable_interrupt
() ans __disable_interrupt ?
(the code follow at the end of this mail)
Thank you very much !
--- In lpc2000@yahoogroups.com, "Leighton Rowe" <leightonsrowe@y...>
> something like...
>  return;
> very handy.
> Leighton
> >   VICProtection=0x0;
> >   VICVectCntl0=0x25;
> >   __enable_interrupt();
> >   T1_IR=0x00;
> >   T1_MR0=TIMERMATCH;
> >   T1_PR=0x0;
> >   T1_TC=0x00;
> > __arm __irq void irq_handler(void) //Timer1 ISR
> >   return;
> > void Timer1ISR()
> >  IR1 = 0x01;
2004-09-22 by Leighton Rowe
not
that
an
it
I
() and __disable_interrupt().
I remember this happening to me before, but at the time I wasn't
sure why. I'm still learning the IAR library functions. Do you have
the vectors in cstartup configured?
org     0x00
pc,=?cstartup
org	0x18
ldr	pc,=irq_handler
If u did, then check the status of cpsr after both intrinsic
enable/disable functions. If the I & F bits (global IRQ & FIQ flags)
don't change correctly, then those 2 library functions may very well
be the fault.
> do you know the asm code of __enable_interrupt () ans
...that you can do for enable/disable with 3 asm instructions.
read cpsr --> register
modify I F bits
store register --> cpsr
As long as you configure your processor to the required priviledge
level (see ?cstartup examples & the ARM7TDMIS Documentation), you
can easily modify the I & F bits of the cpsr register to
enable/disable IRQ and FIQ global interrupts.
Good luck!
Leighton
GPIO documentation?
2004-09-23 by Peter Jakacki
Has anyone ever received a conclusive reply from Philips concerning the
reason for the slow GPIO? I just would like to know why this port is so
slow, I am curious. Initially I thought it had to do with the set/reset
logic and the goal of  synchronizing the output port. But the port is
still slow even if I write directly to the IOPIN or IODIR registers.
The sequence below where r6 and r4 are loaded with bit patterns while r0
holds the IOPIN address runs 7 times slower than the CPU clock with a
VPBDIV=1.
    str    r6,[r0]
    str    r4,[r0]
    str    r6,[r0]
    str    r4,[r0]
    str    r6,[r0]
    str    r4,[r0]
Something that I miss from the LPC21xx datasheets is a good old logic
diagram for the GPIO which most micro datasheets normally feature.
Peter Jakacki
Re: GPIO documentation?
2004-09-23 by embeddedjanitor
so
> slow, I am curious.
Peter
This is not conclusive stuff from Philips, but the main reason I can
see for the problem is that the GPIO is a peripheral hanging off the
relatively slow peripherla bus. The major time seems to be taken up by
the sychronisation between the core and this bus.
If the bus had been designed more like an external memory bus then
we'd probably see full-speed (or at least much faster) GPIOs.
-- CHarles
