Strange ISP Problem
2005-01-24 by Nice Guy
I'm using an olimex 2106 header board and I'm having problems getting ISP to work. The philips ISP program will not do a thing, simply says unable to communicate with board when I try to read device ID or any other opperation. The lpc21isp program will not sync either, even if I go in terminal mode the 2106 seems to freeze up. However if I use HyperTerminal I can type "?" and get the "Synchronized" response, I respond with "Synchronized" then "14746" and can get part ID and Bootloader version with no problems at all. Still I didn't have a way to load a program and test things out, So I moved to a differt computer running linux. I used the lpc21isp program under linux. At first there was no problems, I was able to load a program to blink a led and that worked. Later on I wrote some code and was going to try it. I started lpc21isp up on the linux box and it wouldn't sync. So I started lcp21isp up in term only mode and was able to send "?", but only get back "Synchro". Every time I try term only mode I get the same results and still no luck on the windows box either. To get from TTL to RS232 levels I'm using a box with a max232 chip that worked fine last semester with a msp430. I have tried speeds from 9600 to 38400 and that has no effect. Anyone have any Idea what could be wrong? What I really don't understand is why Hyperterm will work on the windows box, but the lpc21isp in term only mode won't.
