Lpc2000
Keil and LPC2294 - What am I doing wrong ?
2005-02-25 by Paulo de Almeida
I'm using Keil (UV3) with the Olimex LPC-H2294 board and I just can't
get any of my programs to work.
I made a very small program to turn on a led in the board using the
Keil suplied Philips startup ASM file and just 2 lines of C code to
setup the IO0DIR and to clear the desired pin. The program complies
fine and the HEX file looks Ok (as far as I can tell) , I use the
Philips LPC2000 Flash Utility V2.2.0 to upload the file and it works
ok, but when I do a "Compare Flash" the Philips LPC2000 Flash Utility
tells that the "file compare failed" and  the program does not run on
the board.
I have upload to the board (using the Philips LPC2000 Flash Utility )
the HEX file with the exemple program suplied by Olimex and I DONT get
"file compare failed" and the board works fine. So, the board is in
perfect working condition.
Can someone please give me some sugestion on what is going wrong , is
there any special issue with Keil and the  ?
Thanks
Paulo A.
Re: [lpc2000] Keil and LPC2294 - What am I doing wrong ?
2005-02-25 by Varuzhan Danielyan
Once or, maybe, even more in this forum was mentioned, that the
Philips Flash Utility has a bug, it does download, but do not work with
"Compare Flash" function.
Buy the way, V2.2.1 is now available, but again the bug is not corrected,
though, if Philips open its source code, any programmer can easily correct
this bug.
Varuzhan
  To: lpc2000@yahoogroups.com
  Sent: Friday, February 25, 2005 2:35 PM
  Subject: [lpc2000] Keil and LPC2294 - What am I doing wrong ?
  the board.
  Thanks
  Paulo A.
        Yahoo! Groups Sponsor
              ADVERTISEMENT
  Yahoo! Groups Links
    http://groups.yahoo.com/group/lpc2000/
Hi Varuzhan,
Thanks for your reply. The strange thing is that the Philips Flash
Utility works fine when doing a "Compare Flash" with the Olimex
suplied example HEX file.
Ok, ignoring the "Compare Flash" error with my program I still dont
understand why a stupid simple program like this:
#include <LPC22xx.H>
int main (void)  {
     // define P0.30 as output
      IODIR0  = 0x40000000;
      // bring  P0.30 low (led is conect betwen VCC and P0.30)
      IOCLR0 = 0x40000000;
      while (1);
which uses the Keil suplied startup ASM file for the Philips LPC22xx
does not work.
Any ideas ?
Paulo A.
>this bug.
>Varuzhan
>  ----- Original Message -----
>  From: Paulo de Almeida
>  Hi,
>  the board.
>  Thanks
>  Paulo A.
>              ADVERTISEMENT
>  Yahoo! Groups Links
>Yahoo! Groups Links
2005-02-25 by Bill Knight
Paulo
  P0.30 defaults to AIN3 at powerup.  You need to set its usage
to GPIO in PINSEL1 before using it.
-Bill Knight
R O SoftWare &
http://www.theARMPatch.com
On Fri, 25 Feb 2005 11:45:40 +0000, Paulo de Almeida wrote:
Hi Varuzhan,
int main (void)  {
      while (1);
does not work.
Any ideas ?
Paulo A.
>this bug.
>Varuzhan
>  Hi,
>  the board.
>  Thanks
>  Paulo A.
>              ADVERTISEMENT
>  Yahoo! Groups Links
>Yahoo! Groups Links
Yahoo! Groups Links
2005-02-28 by Paulo de Almeida
Bill,
Stupid me, I skipped that part in the datasheet :(
Everything is OK now and my program is up and running :)
Thanks to you and to Varuzhan.
Paulo A.
>Paulo
>Regards
>-Bill Knight
>R O SoftWare &
>Hi Varuzhan,
>int main (void)  {
>      while (1);
>does not work.
>Any ideas ?
>Regards
>Paulo A.
>>this bug.
>>Varuzhan
>>  Hi,
>>  the board.
>>  Thanks
>>  Paulo A.
>>              ADVERTISEMENT
>>  Yahoo! Groups Links
>>Yahoo! Groups Links
>Yahoo! Groups Links
>Yahoo! Groups Links
