Lpc2000
LPC2294 External Bus Speed
2005-07-04 by itsjustimpossible
Hi
There have been a few messages about this, but I can't find anything
explicit so I thought I would ask a quick question.
In an FIQ I need to transfer 15 bytes to an external device in less
than 1uS.
Is this possible? Unless I am completely off track (probable), it
looks like it should be.
The bus is 8-bit with no wait states. We are using the PLL to give a
60MHz core clock and the peripheral clock is set equal to the core
clock. The MAM is enabled.
I can't seem to achieve anywhere near this figure.
Any thoughts would be greatly appreciated.
many thanks
Simon
Re: LPC2294 External Bus Speed
2005-07-04 by donhamilton2002
--- In lpc2000@yahoogroups.com, "itsjustimpossible" <simonjh@b...> wrote:
    I would like to clarify your request.
> Hi
> than 1uS.
   Does this mean :
   1) " Start transfering 15 with 1uS after the edge that causes FIQ"
   2) " Finish 15 bytes with in 1 uS after the edge that causes FIQ"
   As you can see the timing of these two cases is very dramatic.
> many thanks
> Simo
Thanks
donhamilton
2005-07-05 by itsjustimpossible
Hi
In an ideal world I would like to achieve number 2...
However I appreciate that may be a tall order when taking interrupt
latency into account.
At a push I would settle with being able to transfer 15 bytes in
less than 1uS. Not including the interrupt latency of the FIQ.
best regards
Simon
--- In lpc2000@yahoogroups.com, "donhamilton2002" <hamilton@d...>
> > Hi
anything
less
> > than 1uS.
>    Does this mean :
FIQ"
FIQ"
it
give a
core
> > many thanks
> > Simo
> Thanks
> donhamilton
Re: [lpc2000] Re: LPC2294 External Bus Speed
2005-07-05 by k b shah (lascaux)
Gentleman,
look at your BCFG value. it determines our read/write and wait state and idle time between two  read/write ...
You have to minimize this as you requirement is 15 byte per microsecond measns 66ns per byte time...
k b shah
  To: lpc2000@yahoogroups.com
  Sent: Tuesday, July 05, 2005 4:29 AM
  Subject: [lpc2000] Re: LPC2294 External Bus Speed
  Hi
  best regards
  Simon
  > > Hi
  anything
  less
  > > than 1uS.
  >    Does this mean :
  FIQ"
  FIQ"
  it
  give a
  core
  > > many thanks
  > > Simo
  > Thanks
  > donhamilton
  YAHOO! GROUPS LINKS
    a..  Visit your group "lpc2000" on the web.
    b..  To unsubscribe from this group, send an email to:
    c..  Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
Hi
Thanks for the suggestion but we already have it configured with zero
wait states etc. So the bus should be running as fast as possible.
I have been doing some experiments today and I think the bus access is
probably OK. I think the main source of delay is the interrupt latency
of the FIQ which seems to be about 800nS.
There is also some jitter on that, so all together I am not sure if
the ARM7 is capable of doing what I need in this instance.
Bit of a shame
Best regards
Simon
--- In lpc2000@yahoogroups.com, "k b shah \(lascaux\)" <kbshah@l...>
wrote:
> Gentleman,
> k b shah
2005-07-05 by donhamilton2002
> Bit of a shame
> Simon
Simon,
This pushes the software solution. A small FPGA would get this done.
I am sure you are calculating the 15 bytes well in advance of the FIQ.
Pre-loading the 15 byte into the memory of the FPGA, arm the FPGA
logic and wait for the FIQ. The FIQ will also tell the ARM7 that the
data has been transfered, so the next 15 bytes can be pre-loaded
for the next FIQ.
donhamilton
PS: This is why I love embedded work. Creative solutions to unusal
problems.
