Re: [motm] MIDI sucks (get your attention?)
2000-08-11 by ivancu@aol.com
In a message dated 8/10/00 9:53:06 PM, elhardt@... writes: << I still have a possible future interest in the Kurzweil, so can anybody confirm that it can actually pitch bend without glissando? >> Yes, I bought a Kurzweil Expressionmate, then sold it a month later. Here's the facts about MIDI, folks (and why I don't use it to control analog synths): MIDI only outputs NOTE information, not continuous pitch information. The Kurzweil Expressionmate can output not information as you slide your finger along the ribbon, but it comes out as a glissando. That is, individual "key" notes are played. Yes, you can program it for different scales, and you can even use part of the ribbon to play notes and another part of it for pitch bend. But any MIDI controller like this, including the Tactex, will still only play notes, not a everything in between the notes. This is the reason that the Big Briar MIDI theremin and the Rosedene theremin MIDI converter (http://www.fullerton.demon.co.uk/midicv.htm) are so expensive. They are using MIDI note, pitch bend, and portamento to SIMULATE a real continuous controller. To quote the Rosedene info, "The pitch bend controller (1-48 semitones definable) is used in conjunction with RPN (54H) portamento control to follow the pitch of the Theremin." This is why, in my not so humble opinion, I think that MIDI sucks. It really pisses me off that I can't play continuous pitches on my SidStation, for example. I'm contemplating buying a Rosedene unit, but it is a lot of money for a specialized piece of equipment (I believe around $600+). It is also why I don't think that MIDI has much of a place with analog synths. A whole facet to the beauty of analog synths is that they are continuously variable instruments. I do use MIDI for its sequencing capabilities but I look forward to having a MIDI-syncable analog sequencer (DoMOAS/MOAS). Ok, I would guess that I've irritated enough people for one night... back to your regularly scheduled programming. Ivan
