OBERHEIM SYNTH group photo
OBERHEIM SYNTH
Index last updated: 2026-04-28 23:39 UTC
R: Re: [oberheim] Re: M6r troubles
2010-09-13 by ste.mari@libero.it
In case you can buy a new CEM 3396 here :
http://www.maad.net/ms6/
This makes
 sense to me...I"ll it and let you know.
Sent via BlackBerry from T-MobileFrom:  "synergeezer" <synergeezer@...>
Sender:  oberheim@yahoogroups.com
Date: Sun, 12 Sep 2010 22:39:23 -0000To: <oberheim@yahoogroups.com>ReplyTo:  oberheim@yahoogroups.com
Subject: [oberheim] Re: M6r troubles
Try re-seating the chip or chips.  IIRC many of them are socketed, so, CAREFULLY, unplug each one and, CAREFULLY, plug it back in (don't bend the legs)!  I fixed mine, this way.  If it doesn't work, then leave voice 6 out.
- synergeezer
--- In oberheim@yahoogroups.com, atmospherics4@... wrote:
> this sounds  vague to me as I don't know about electronics...are you saying that if I were to open the M6r, that I would find a discreet chip labeled for each voice and that pulling out the bad chip would allow the machine to function as a five voice...M5r?
> From: "eightiescrisis" <eightiescrisis@...>
> Date: Fri, 10 Sep 2010 04:49:15
> Reply-To: oberheim@yahoogroups.com
> pull out the chip!
> --- In oberheim@yahoogroups.com, atmospherics4@ wrote:
> > Hi guys
> > My M6r has voice #6 crapping out! Whenever this voice is triggered, it sounds
> >  as if the patch is white noise with a sharp percusive  attack. My other M6r doesn't have this problem and they're triggered as one instrument via my Lync LN4...this happens with all controllers.
> > Any way to disable voice six until I can get it repaired?
> > Thanks
> > Derrick
Re: Re: [oberheim] Re: M6r troubles
2010-09-13 by analog gear
are you sure? afaik, this guy sells NARROW bodied 3396 chips only. they go into matrix-1000. m6r requires WIDE body 3396 chips, make no mistake. wide-body versions are an order of magnitude more difficult to get.
sorry for the bad news,
margus
This makes
- synergeezer
> this sounds vague to me as I don9;t know about electronics...are you saying that if I were to open the M6r, that I would find a discreet chip labeled for each voice and that pulling out the bad chip would allow the machine to function as a five voice...M5r?
> pull out the chip!
> > Hi guys
> > Thanks
> > Derrick
