rEalm's Live Set methodology
2003-08-13 by erik_magrini@Baxter.com
Hey all, some one on the 505 list asked about how I set up my live sets,
here's a copy of my reply.  Thought it might be interesting for a few
people, so I posted it here too:
I know how hard it is to set up a Live PA, and how helpful it can be to
read other people's methods, so here's mine:
The XL-7 is the main device, 95% of the tweaking and playing I'm doing
during my sets are on that machine.  The SP808 really is only functioning
as a sample playback unit, and occasionally as an effects device for those
samples too.  It's not even synced via MIDI except to provide MIDI clock
information for the effects.  As this is largely a hit and miss affair in
terms of the effects actually syncing to the XL-7's tempo properly, I may
not even bother with that MIDI cable in the future.
Tracks 1-7 on the XL-7 are my main percussion parts, BD's, snare's HH's,
and other drum stuff.  Track 8 is set up to Trigger samples on the SP808
(more on this in a bit), and tracks 9-16 are my instrumental tracks.  The
key here is that every Track has the same type of instrument for all of my
XL-7 Patterns.  This makes it very easy to know what each track is playing
while doing the live thing, and it also means I can switch to pretty much
any Pattern and know how it's going to be laid out.
All of my XL-7 Patterns are 8 measures long, I've tried other lengths, but
this one seems to work the best for me.  If I make them shorter, I don't
get to program that much variety into each one.  If I make them longer I
can add more variety, but it makes switching Patterns that much more
difficult for me.  I may set up for this really dramatic Pattern change,
only to find out it still has 8 (or 12, 16, etc) more measures to go
before the switch.  Then I'm just sitting there waiting, not much fun.
In addition to the 16 sequenced tracks available in each Pattern, I also
set up custom Triggers in my XL-7 too.  These are basically like the RPS
function on the 505's, I have 16 of them that can be Triggered at any time
during the set, regardless of what Pattern I'm playing.  Most of these are
simple arpeggiated ethnic and tribal drum sounds, though a few are snare
and HH based too.  These allow me to drop in different percussive elements
during the set, which serve two purposes:
1. They allow me to give the entire set more of a cohesive feel.  Since I
use a lot of the Triggers more than once in the set, they add a subtle
background element that helps give the whole thing sort of the same feel.
2. They help me maintain some semblance of continuity while switching
Patterns.  Because my Triggers are independent of the Pattern being
played, I can switch Patterns and have the same percussion sounds still
being sounded.  Helps to make transitions more seamless IMO.
The SP808 has two main roles; it plays back sequenced loops and other
samples that compliment the XL-7 Patterns, and it lets me manually drop in
vocal samples when I want to.  The sequenced loops were originally
constructed in Reason, using breaks I've collected or occasionally
modifying a refill here and there.  Because Reason can act as a MIDI
slave, I'd set the XL-7 to be the master and create my 8 bar Patterns in
the Redrum and Dr. Rex modules.  Once I was happy with how the loop was
complimenting the XL-7 patterns, I would set the L and R locators to 1
measure, and export these as audio files.  So my 8 bar Reason Pattern,
would in effect become 8 separate 1 bar audio files.  The downside to this
is that the tempo of the Reason stuff can't be changed after the fact, so
you have to decide on your Pattern/set tempo ahead of time.
At this point, I would use the 808 conversion software with an external
ZIP drive to transfer the samples to the SP808.  Each SP808 sample bank
corresponds to an XL-7 Pattern, with the 8 samples forming the loop being
placed on pads 1-8.  I would also place some random vocal samples on Pads
9-16 as I saw fit. The last two songs in the set use guitar fills which I
had recorded in Cubase SX, and then imported to the SP808 on the last 8
pads for that Sample Pad Bank.
As mentioned earlier, Track 8 on the XL-7 controls the SP808.  Because
each Pad Bank in the Sp808 can be recalled via simple program changes, I
just inserted the appropriate PC message at the beginning of each pattern
on that track.  The XL-7 has a GREAT feature where events placed at Tick 0
in the XL-7 are NOT repeated each time the pattern loops, so I didn't have
to worry about the samples reloading each time the Pattern loops.  This
way, every time I change patterns, the Sp808 automatically updates to the
correct Sample Pad Bank.  Then I inserted CC#7 (volume) commands to
control the volume of the Pad banks, since they varied greatly Pattern to
Pattern.
The last step was to insert note events at the beginning of every measure
that would trigger each of the 8 loop pads sequentially.  Why 8 pads for
the loop instead of just one?  Because this way I can mute the drum loop
from the panel of the XL-7, without having to wait until the pattern loops
around again before it starts playing again.  The most I have to wait now
is one measure.  I did have to play with the sample start times in the
SP808 to get everything to sync up correctly.  I think the data
compression Roland uses messes with the sample accurate loops I had set up
in Reason, though I can't confirm this.
Overall I'm pretty happy with the set up, it's flexible, small, and now
that the pre-production work is done it's pretty easy to set up and play.
rEalm
Re: rEalm's Live Set methodology
2003-08-13 by dwoodaman
since I am still in the throes of trying to make my live thing work
for me, I much appreciate the details you give here!
dana
sets,
few
be to
doing
functioning
for those
clock
affair in
properly, I may
HH's,
SP808
tracks.  The
all of my
playing
pretty much
lengths, but
don't
longer I
more
change,
go
fun.
I also
the RPS
any time
these are
snare
elements
Since I
subtle
same feel.
switching
being
still
other
drop in
MIDI
Patterns in
loop was
to 1
Pattern,
to this
fact, so
external
bank
loop being
on Pads
which I
last 8
Because
changes, I
pattern
at Tick 0
didn't have
This
to the
to
Pattern to
> Pattern.
measure
pads for
drum loop
pattern loops
wait now
had set up
and now
and play.
> rEalm
Re: [xl7] Re: rEalm's Live Set methodology
Glad it was helpful!  I know that when I first was toying with the idea of
doing a live pa years ago, it was incredibly furstrating.  I knew what I
wanted to do, I just didn't know how I was GOING to do it.  Reading
interviews with other live acts definitely helped me out, hopefully this
will help some people too...
rEalm
since I am still in the throes of trying to make my live thing work for
dana
2003-08-13 by Oscar Finch
Ditto too that one Dana .Thankyou for the info Realm very handy.I'm actually replacing my RS7000 w/ 2 SP808EX's and an MP7 with the roms I mentioned.So this reply was actually very handy for me.I already have 2 parallel midi out boxes , 1 into 4 parallel midi outs each so I'll have no troubles driving the Micro Q + Elevata at the same time.It will also mean no DAW in a live set (very handy).Can't wait ,two weeks to go and I get my Command Station (brand new OS 2.0 preloaded for $1600 AUD) - a damn site cheaper than my $3400 AUD RS7000 ever was BTW .I use to own the 808's so I know them very well already.Still haven't found a buyer in Oz for my RS7000 (mint cond. full ram etc etc so if any Oz residents are ineterested let me know as it's never been gigged) - $2000 AUD with 64 SM card ,SCSI type 1 cable 64 meg ,manuals ,TWE ,acid express etc etc etc oh and ColdCut's Bits & Pieces sample CD .Just thought I'd throw that one in.Once again thanks for the info.Great programming on the rythms Realm that Command station has a nice rythmic vibe.Excellent Stuff.--- On Wed 08/13, dwoodaman < dwoodaman@... > wrote:From: dwoodaman [mailto: dwoodaman@...]To: xl7@yahoogroups.comDate: Wed, 13 Aug 2003 18:03:34 -0000Subject: [xl7] Re: rEalm's Live Set methodologysince I am still in the throes of trying to make my live thing work for me, I much appreciate the details you give here!dana
_______________________________________________
2003-08-14 by robotchas
Yeah, that's nice and all, but let's stay on topic here: are you a
hot young blonde who's honest, yet daring and wild, and do you have a
huge RACK?
(Seriously, do you use outboard gear or is it just the XL and SP?)
idea of
what I
this
> rEalm
for
> dana
2003-08-14 by sincultura13
Thanks! I have a Sp-505 and am planning my setup right know... You
just gave me some really useful organizational tips that I'm
definitelly incorporating... For what I'm doing the Sp-505 is not
enough though. I have an ESi and an alesis, but haven't had time to
actually run everything together... I might drop one of the last two
in favor of a DJ cd player for scratch effects and dj like rhythm
freedom when I feel like it... Do you have additional roms on your Xl-
7? What kind of music do you do?
a
> huge RACK?
> idea of
> what I
Reading
hopefully
> this
> > rEalm
work
> for
> > dana
2003-08-14 by erik_magrini@Baxter.com
huge RACK?
>>>No, but I play one on TV. <<<
>>>Just the XL-7 and the SP808. <<<
rEalm
Do you have additional roms on your Xl-7?
>>>Yes, the Proteus Pop ROM and the new Proteus Drums ROM. <<<
>>No idea, take a listen and you tell me:
http://rEalm.iuma.com
http://www.acme.dj/rEalm.html   <<<
rEalm
rEalm's Live Set methodology & re: music style... & Some "?"sss
2003-08-20 by sincultura13
Your music is pretty cool... I like the logical way you develop ideas
and the samples from a comedian (which remind me of Bill Cosby
on "Himself") on 'jello speak' and the guitar-like melody on last
track which hits me in a similar way to one of U2's old songs. I
don't know what too call your music... Sort of electronic all the way
through but with really varied nonelectronic influences? I don't know
much about electronic music, so pardon if I stated the obvious...
My music is going in a different direction... I use alot of acoustic-
like sounds, build/develop ideas harmonically (instead of in a lineal
way)and use drums more sparingly. I guess more like ambient? In any
case I layer a lot and sometimes use really long samples... So I
built on your idea and started to not only do what you do in reason
with logic, but also straight on the Sp-505 (the sp-505 is cool that
way, chopping and resampling is really easy and effective). Now, I'm
going to get a Scsi card so I can load long samples to my ESi more
effectively and am experimenting with building 32 bars patterns. I
also plan to get two (or atleast one) cheap & flexible effect unit to
tweak things live... It should work out beautifully... Well, atleast
it doesin my head it does! :)
Any suggestions for a CHEAP & flexible effect unit for "live" use? I
really wanted the Line 6 unit with all the delay/echo effects... but
is more than what I have (or would want to since for not much more I
could get a basic laptop and use vsts) to spend... I like delays,
tape delay and echos the most...
BTW, Anybody here using a command station with a dj cd player live?
thanks...
> rEalm
Re: rEalm's Live Set methodology & re: music style... & Some "?"sss
2003-08-20 by dwoodaman
I have a TC electronics M300, really really great box
dana
ideas
way
know
acoustic-
lineal
that
I'm
to
atleast
I
but
I
> thanks...
> > rEalm
2003-08-20 by Justin Grimley
I
I recently got a Korg Kaoss Pad 2, and man that thing rocks!  To be
honest, I haven;t actually used it yet in any of my own tunes,
because I have been having so much fun running vinyl through it, I
keep losing track of time.  I have a send bus from my mixer going
into the line-in, and a Numark TT200 running straight into the phono
ins.  You can then toggle between inputs (has a mic input as well)
with a switch on the front panel.
-grimley
Re: [xl7] rEalm's Live Set methodology & re: music style... & Some "?"sss
2003-08-20 by erik_magrini@Baxter.com
Your music is pretty cool... I like the logical way you develop ideas and
the samples from a comedian (which remind me of Bill Cosby on "Himself")
on 'jello speak'
>>>Yeah, ummm...certainly my samples never came from that record.
Definitely not, I mean that wouldn't be right huh?  Definitely not from
that record, even though I have it in my collection and it sounds
amazingly similar to what I used.  Yeah, um.... sure. :) <<<<
and the guitar-like melody on last track which hits me in a similar way to
>>>Thanks, there's a different rendition of that song in my live set too,
more info on that shortly.  I started out playing the guitar, so it's
always nice when I can use that in one of my songs. <<<
I don't know what too call your music... Sort of electronic all the way
through but with really varied nonelectronic influences? I don't know much
>>>No problem, I actually take it as one of the best compliments when
people say they can't define my music, or that I have my own style. That's
one of the msot important things to me, and the reason why I never took
any lessons.<<<
>>>I really like the Korg Kaoss pad, don't have one myself, but it's a
really cool unit for fairly cheap. <<<
I like delays, tape delay and echos the most...
>>>I like delays a lot too, by far my favorite effect category.  Mmm...Ohm
Force OhmBoyz can keep me entertained for hours.... <<<
>>>Not yet, but I've been itching to get that new Denon CD deck really
bad.  I use one with regular tables though, so if you have any integration
questions, fire away. <<<
rEalm
2003-08-20 by Ravi Ivan Sharma
I have been using my command station with two cd dj decks live with a regular dj mixer for a few weeks now. Very simple, I mix in live work back to back with tracks. I will improve a bit with X-mix then when I bore myself, I will go back to a cd and play a few of those then go back to the command station. Most listeners don't even know what is going on. I have also brought in a guitarist to jam along. Often we will also play on top of the cds for the hell of it. I think I want to get a kaoss pad for this purpose as well just to have some overall hard effects . . .
  Sent: Wednesday, August 20, 2003 9:52 AM
  Subject: Re: [xl7] rEalm's Live Set methodology & re: music style... & Some "?"sss
2003-08-21 by erik_magrini@Baxter.com
Ditto, it would be cool to morph the whoel mix to hell and back, and I
think the KP2 is a pretty cool little box for this.  Have you played with
one yet Ravi?  I just like looking at them, IMO by far one of the coolest
looking boxes ever made...
rEalm
2003-08-22 by Ravi Ivan Sharma
no I haven't tried one yet, but that is exactly what I had in mind, I would run it as an insert to the final output so I could warp the command station allong with the guitarist or whatever else all at the same time . .
  Sent: Thursday, August 21, 2003 7:55 AM
  rEalm
        Yahoo! Groups Sponsor
              ADVERTISEMENT
2003-08-22 by biz
I've played around with one. Definitely cool. A couple of friends of mine have them as the last chain in their rigs.
Have you seen the video one they've been showing on H-C?
bIz
http://www.groovetronica.com - "The beats are ok, I suppose, but the vocals sound like the vintage jazz singers from my dad's record collection. It's not for me."
  Sent: Thursday, August 21, 2003 5:18 PM
    rEalm
                ADVERTISEMENT
              ADVERTISEMENT
2003-08-25 by sincultura13
The Kaoss 2 looks ideal for what I want... Has anyone tried the
scratch and/or echo delay effects on it? The reason I wanted a dj cd
player was for the scratching effect, if I can get that with the
Kaoss pad I'm almost sold on it...
and I
played with
coolest
> rEalm
have
