MIDI Type 0
MIDI Type 0
2004-04-27 by Paul McCarthy
I'm having some difficulties using the XL-7 w/computer-based
sequencers. I have the same problem on my MC-505, but I have
successfully accomplished this with my CS6X synth.
I am trying to run Cubase SX with 16 midi channels running the XL-7.
The problem is that all the data goes to one midi channel regardless
of which midi channel it is assigned to. It seems like it is using
midi type 1 which routes all midi data to 1 channel. So how would I
get it into type 0? I have tried to change the midi settings within
the XL-7, but nothing seems to be working the way it is suppose to.
Any suggestions?
Re: [xl7] MIDI Type 0
2004-04-28 by Mark Fitt
Midi type 0 is all channels on a single track.
   Type 1 is 16 channel/multi-track support.
   So you need to export the MIDI file as type 1 to maintain tracks.
	Mark.
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.670 / Virus Database: 432 - Release Date: 27/04/2004
Sorry ignore that, I've got the wrong end of the stick ;)
	Mark.
Re: MIDI Type 0
2004-04-28 by Paul McCarthy
No, you were right for what I need to do. I export as a type 0 midi
file for the cs6x, but for using the computers sequencer, I would
want type 1. Either way I can find it in the midi menu.
I am going to try to set the XL-7 and the MC-505 in song mode.
Perhaps it will work this way. On the CS6X, it has to be in
performance mode, so maybe on the grooveboxes w/built-in sequencers,
it has to be in song mode to work with the computer's sequencer.
I'll post the results when I get back home tonight.
> 	Mark.
Re: [xl7] Re: MIDI Type 0
   On SX 2.0 (possibly 1.0) select "Export\MIDI file...",
   Set your filename,
   Then the Export Options appear, if you untick "Export as Type 0" and it
should export Type 1.
         Mark.
2004-04-28 by Aaron Eppolito
If you're trying to play the XL-7 from Cubase, you'll need to turn
rechannelize off.
If you're trying to import MIDI files from Cubase into the XL-7, either
type 0 or type 1 should work fine.
For type 0, the tracks will be forced to their respective channels
(i.e. track 1 to channel 1, etc.)
For type 1, each track will retain whatever data is on it (i.e. if you
have channel 2 data on track 7, track7 will be forced to channel 2.
likewise, if there's more than one channel's data on a track, it will
be forced to Multi A).
-Aaron
--- Paul McCarthy <dj_alcapaul@...> wrote:
> Hi,
> Any suggestions?
Do you Yahoo!?
Win a $20,000 Career Makeover at Yahoo! HotJobs
http://hotjobs.sweepstakes.yahoo.com/careermakeover
Re: MIDI Type 0
2004-05-01 by Paul McCarthy
Thanks for the help. Turning off rechannelize did the trick.
2004-05-03 by erik_magrini@Baxter.com
I export as Type 0 in SX all the time and it saves the correct track
assignments.
rEalm
"Mark Fitt" <mark@...>
04/28/2004 11:17 AM
Please respond to xl7
        To:     xl7@yahoogroups.com
        cc:
        Subject:        Re: [xl7] MIDI Type 0
                 Mark.
Yahoo! Groups Links
The information transmitted is intended only for the person(s)or entity
to which it is addressed and may contain confidential and/or legally
privileged material. Delivery of this message to any person other than
the intended recipient(s) is not intended in any way to waive privilege
or confidentiality. Any review, retransmission, dissemination or other
use of , or taking of any action in reliance upon, this information by
entities other than the intended recipient is prohibited. If you
receive this in error, please contact the sender and delete the
material from any computer.
For Translation:
http://www.baxter.com/email_disclaimer
