On 3/25/05 4:52 PM, "wparch" <wparch@...> wrote:
> on the majority of my tracks i use 1a through 16a. when i go to 12b
> or 15b or to enter information....it defaults to 12a or 15b...
> so the question is how do i use all 32 of my tracks to add more
> sounds to one track?
This is confusing TRACKS with MIDI CHANNELS. There are 32 MIDI channels -
Port A has 16 and Port B has 16. However, there are only 16 sequencer
tracks. Each track can address up to 16 channels, though - you can bounce
down multiple tracks to a single track that outputs to "Multi A" or "Multi
B". A track set to one of the Multi outputs can send info to all channels on
that particular port, so you can use all 32 MIDI channels in a sequence, but
you still only have 16 tracks total in the sequencer.
I hope that helps. :D
Mibrilane
