MP7 preset saving
MP7 preset saving
2005-03-26 by productofournitlesmunitions
Hi i've just got my mp7 from ebay.
I'm using it in fact like a sound expander driven by cubase. So far away everything is
working, i assign every midi track from cubase to the mp7 : track1 for kick, track2 for
snare, track3 for hihats ..... I save the pattern and switch off the mp7. But when i come
back and switch on the mp7, select my pattern... and the presets i've choosen are gone!!
I precise : i don't know how to edit presets so i keep the original ones: just select the patch
and assign it to the track. It's kind of boring cause when i want to load a new song from
cubase the machine dont play the sounds i've originally choosen. I need to retrieve all the
presets. Can someone help me please?
I hope my explainations where understandable.
THX
Re: [xl7] MP7 preset saving
2005-03-26 by BEAUFILS Adrien
I've the same problem when i use the trigger buton to play notes. In fact, if nothing is record on a track the preset will stay the same of the last pattern. My solution is to save a multisetup wich remains the presets on each tracks. After you must insert a program change at the beginning of each pattern to remains the multisetup you want ( i think it's possible in cubase or go in the pattern edit menu go to the screen who show events and insert the number of the set up you want with this value msb: 0 lsb: 80 and it will work... if you're running on os 2.0 for me on 1.31 this feature doesn't work correctly...shit).
If you're talking french go to audiofanzine.com on the xl7's forum, all that things are clearly explains.
hope that help.
 Découvrez le nouveau Yahoo! Mail : 250 Mo d'espace de stockage pour vos mails !
Créez votre Yahoo! Mail
2005-03-26 by Szonyi Andras
Yes, a MIDI track should contain any data to store
the presets for it. An empty track will always forget
the preset settings!
It's enough to record one of the realtime controllers movement,
or anything else which can not be heard.
The fastest way (for me) to test it is moving to another pattern
(maybe a factory preset which has all 16 tracks used), and after
move back your actual pattern.
zoot
> hope that help.
