bass
bass
2005-03-31 by lifeistheformofenergy
I should have been more specific with what I am using - I want learn
how to sequence these basslines on my xl 7 - (no other roms) and mean
while external gear will utilized as well but I just want to know what
parameters I need to change because the knobs in quick edit don't do
enough of what I am trying to do - like amp release up (amp vel up as
well - to get it as loud as I can) sustain up and delay all the way up
as well - I was under the impression that I could take a bass drum
sound like kick 2 and tweak it so that instead of its quick attack and
quick release that happens over only around one or two eight notes at
most, instead I could tweak its parameters so that it's note on value
endures at around the same velocity curve (or the same velocity would
be great too) through out a whole couple of 4 bars or what ever I tell
it to depending on the values it would be assigned to - what I am
wondering is if that would be sysEx information I need to change (which
is what I was assuming - as apposed to just altering the ADSR envelopes
and LFO ) - and if so could someone please help me out changing the
sysEx information so I know how to do it in the future - please please
please -
Re: bass
2005-03-31 by malik
why dont you hit the preset edit button then press track buttn 4 to
put amp on the 4 layers?
--- In xl7@yahoogroups.com, "lifeistheformofenergy"
> please -
Re: bass re malik
2005-04-03 by lifeistheformofenergy
well thanks a lot - that did help get the volume level I was looking
for - But I still need to be able to "sustain" a note at a given
velocity for a given time ...
learn
mean
know what
don't do
up as
way up
drum
attack and
notes at
value
would
I tell
am
(which
envelopes
please
> > please -
Re: bass re malik
2005-04-03 by malik
oooh ok. hmm might be the sample being played back? well try this go
into preset edit mode and press button 4 again for amp then turn the
knob a few times and mess with  or at least check out the decay
sustain andd release settings for all for layers and LA might help...
let me know what happens
> learn
> mean
> know what
> don't do
> up as
> way up
> drum
> attack and
> notes at
> value
> would
> I tell
> am
> (which
> envelopes
> the
> please
> > > please -
Re: bass re malik
2005-04-03 by malik
all for meaning all four :)
> > learn
> > mean
> > know what
> > don't do
> > up as
> > way up
> > drum
> > attack and
> > notes at
> > value
> > would
> > I tell
> > am
> > (which
> > envelopes
> > the
> > please
> > > > please -
Re: bass re malik
2005-04-04 by lifeistheformofenergy
ok well first off I just want to say thanks - > I just want to
address this before I continue - I am seriously not trying to be rude
or anything like that when I say this please don't take it the wrong
way - but seriously I am not that much of a noob - I do know what the
envelopes and oscilators do and I know what the FX do - (I tried all
of those basic things first)which is why I came here with my
question - but I literally think that there has to be a way to take
even the smallest of a given rom sample (one lasting only two or
three 16th notes at most - which in my case happens to be the kick 2
from the XL7 rom) and tweak it so that instead of its usuall basic
sample length of only one or two 16th notes - it could be played to
last even up to lets say 5 whole bars of 4/4 with the same velocity
going strong - I did check all the decay sustain release settings for
all the four layers - and that helped get some of the "sustain" type
of idea I had in mind - but only by a few extra beats (two or three
more 16th notes - which I was looking for a few extra whole bars ((16
whole 16th notes))not just 16th notes) - I was thinking that this
could be done with some sort of sysEx programming or something else I
haven't tried - once again I really am eager to learn - maybe this
question is too technical or that I am asking it in the wrong way - I
hope not - I just want to take what I do know and broaden and expand
my awarenesses - please don't take it the wrong way because I do
appreciate the help -
help...
looking
4 to
want
> > learn
and
> > mean
> > know what
> > don't do
vel
> > up as
> > way up
> > drum
> > attack and
> > notes at
on
> > value
velocity
> > would
ever
> > I tell
I
> > am
change
> > (which
> > envelopes
changing
> > the
please
> > please
> > > > please -
Re: bass
help...
looking
4 to
want
> > learn
and
> > mean
> > know what
> > don't do
vel
> > up as
> > way up
> > drum
> > attack and
> > notes at
on
> > value
velocity
> > would
ever
> > I tell
I
> > am
change
> > (which
> > envelopes
changing
> > the
please
> > please
> > > > please -
Re: bass
2005-04-04 by malik
hehe none taken i kinda figured that if you went inthat menu alreasy
then you already knew how to use a synth but i was out of ideas and
wanted to make sure you knew what you were doing. as for what you want
to do, i really havent taken wave samples and extended them in
hardware before. but in wavelab i've taken an 808 drum and zoomed in
on the waveform and set a loop point that would make it loop until i
triggered a note off message.
was talking to a buddy about the best way to acheive this with vocals
yesterday and he said to try fading the same sample in and out. so
maybe the best way to acheive that on the xl-7(or whatever command
station) is to sequences a couple of kicks maybe 1/16 or 1/8 apart?
hen use the envelope to fade it in or out? but if you have an xl-7
shouldnt you be able to program your own? i have an mp-7 i think i
might be able to program one with it myself tho.
i have a bad memory and tho i did read your message i'm now cfonvinced
that you want to make a kick drum sustain. lol i will try to create my
own and if it works i'll let you know.
> help...
> looking
> 4 to
> want
> > > learn
> and
> > > mean
> > > know what
> > > don't do
> vel
> > > up as
> the
> > > way up
> > > drum
> > > attack and
> > > notes at
> on
> > > value
> velocity
> > > would
> ever
> > > I tell
> I
> > > am
> change
> > > (which
> > > envelopes
> changing
> > > the
> please
> > > please
> > > > > please -
