Cakewalk .INS question
2006-08-26 by sounddaddy2
I have loaded several .ins files into Sonar ... I see everything
fine .... But when I go to a bank and click a preset in Sonar My MP7
pops up ROM NOT INSTALLED ???? on whatever channel I am working on ...
what's wrong ??
Also I have not been able to find definitions for the PROM or WORLD
ROMS ... If anyone can help me that would be awesome ... thanks !
Re: Cakewalk .INS question
2006-08-26 by steve_the_composer
Diagnostic questions:
Which ROMS do you have installed?
Do USER presets have the same problem?
Do all installed ROMS have the same problem?
Have you looked at the *.ins files in this folder:
http://groups.yahoo.com/group/xl7/files/Command%20Station%20Data/
Compare your *.ins definitions with those in p2k-all.ins file. It
sounds like you are not using the right bank switching values for the
ROMs you have. When Sonar tells the MP7 to switch to a bank that you
don't have a ROM for, that's the message you get (ROM NOT INSTALLED).
EXAMPLE [exceerpts from *.ins file using AOrch ROM in P2500]:
.Patch Names
[E-MU P2k: Advanced Orchestra: Bank 0 (8448)]
0=cmb:AdvancedOrch
1=cmb:Traditional
2=str:LegatoString
3=cmb:Orch Split
etc.
.Instrument Definitions
[E-MU Proteus 2500]
Patch[8449]=E-MU P2k: Advanced Orchestra: Bank 1 (8449)
Patch[8448]=E-MU P2k: Advanced Orchestra: Bank 0 (8448)
AOrch MSB = 66 [Find MSB of ROM by pressing audition]
66*128 8448
Therefore, Bank 0 of the AOrch ROM is accessed as Patch[8448].
Bank 1 is Patch[8449].
If you try to switch to bank 8457, the E-Mu will look for bank 9 in
the ROM whose MSB is 66 and you will get the ROM NOT INSTALLED message.
If you try to switch to bank 9, the E-Mu will look for bank 9 in User
memory.
You may know all this, but maybe not. Hope it helps.
--Steve
on ...
> what's wrong ??
I have an MP& with PROM.. MOPHAT .. WORLD and DRUM and an XL7 with
the XL ROM.
I have downloaded the .ins from your link and sane deal.
I also have a Yamaha RS700 and that works perfect ... I
dowloaded .ins and it works.
Any Clues ??
you
INSTALLED).
> .Patch Names
> 0=cmb:AdvancedOrch
> 1=cmb:Traditional
> 2=str:LegatoString
> 3=cmb:Orch Split
> etc.
> [E-MU Proteus 2500]
> 66*128 8448
message.
User
> memory.
> --Steve
MP7
> on ...
> > what's wrong ??
WORLD
Re: [xl7] Re: Cakewalk .INS question
2006-08-26 by Aaron Eppolito
The ins files don't match the ROM(s) you have, thus the NOT INSTALLED message.  If you press the Audition button while in the Preset main screen, it will show you the MSB and LSB of the current preset.  Like Steve said, if MSB*128+LSB doesn't match the bank number in the ins file, it will give the above error.
-Aaron
the XL ROM.
Any Clues ??
you
INSTALLED).
> .Patch Names
> 0=cmb:AdvancedOrch
> 1=cmb:Traditional
> 2=str:LegatoString
> 3=cmb:Orch Split
> etc.
> [E-MU Proteus 2500]
> 66*128 8448
message.
User
> memory.
> --Steve
MP7
> on ...
> > what's wrong ??
WORLD
Yahoo! Groups Links
 All-new Yahoo! Mail - Fire up a more powerful email and get things done faster.
2006-08-27 by steve_the_composer
After typing an extensive reply, I got a server not available
message when I went to send it. I will have to try to reconstruct it
later. Sorry.
> the XL ROM.
> Any Clues ??
It
for
> the
> you
> INSTALLED).
> > .Patch Names
> > 0=cmb:AdvancedOrch
> > 1=cmb:Traditional
> > 2=str:LegatoString
> > 3=cmb:Orch Split
> > etc.
> > [E-MU Proteus 2500]
> > 66*128 8448
in
> message.
> User
> > memory.
> > --Steve
everything
My
> MP7
working
> > on ...
> > > what's wrong ??
> WORLD
thanks !
later. Sorry.
> the XL ROM.
> Any Clues ??
It
for
> the
> you
> INSTALLED).
> > .Patch Names
> > 0=cmb:AdvancedOrch
> > 1=cmb:Traditional
> > 2=str:LegatoString
> > 3=cmb:Orch Split
> > etc.
> > [E-MU Proteus 2500]
> > 66*128 8448
in
> message.
> User
> > memory.
> > --Steve
everything
My
> MP7
working
> > on ...
> > > what's wrong ??
> WORLD
thanks !
2006-08-27 by sounddaddy2
--Thanks Steve ... Hopefully you can re-send it later ... i would love
to see your input.
Ok so here' s where I'm at ... i downloaded the PatchPro and created
.ins from my actual MP7 unit and ROMS ... I then loaded in Sonar...
All show up and are perfect ... The problem I am having now is that
the the MP is not switching ROMS ... I can call up a preset in Sonar
for say World ROM bazouki on 012 bank 3 on channel 4 and the mp
switches preset and bank but not ROM ... I have to manually change the
ROM on the MP7.
When I close Sonar it remembers the patches I set but on reload it
does not recall the proper ROM on the MP7 ... seems to just revert to
slot 1 ... which is Mo Phat User/MP7 sounds.
> later. Sorry.
> > the XL ROM.
> > Any Clues ??
> It
> for
> > the
> > you
> > INSTALLED).
> > > .Patch Names
> > > 0=cmb:AdvancedOrch
> > > 1=cmb:Traditional
> > > 2=str:LegatoString
> > > 3=cmb:Orch Split
> > > etc.
> > > [E-MU Proteus 2500]
> > > 66*128 8448
> in
> > message.
> > User
> > > memory.
> > > --Steve
> everything
> My
> > MP7
> working
> > > on ...
> > > > what's wrong ??
> > WORLD
> thanks !
2006-08-31 by sounddaddy2
Hi Guys can you help me out .... I have everything loaded up but the
MP doesent recall patches when I open a project in Sonar 5 ... I have
a Yamaha RS7000 with .ins in Sonar at it works fine.
On the MP I have to scroll to the proper rom and see the patches as I
make changes in Sonar from the .ins files ... They are acurate and
match each other perfectly.
The only way I have been working around this is saving a multi of the
song on the MP and restoring it ... But i know there must be a way
that I can't figure out ... any help or guidance ??
If I create a pattern in the MP and save it via e-loader and then
open it up in Sonar it asks if I want to send sysex data and I say
OK !!! ... The MP plays all of the presets fine.
Just to be clear the problem I am having is when I write and go
fishing for sounds From/In Sonar .... They don't recall on the MP7
when I re-open in Sonar.
I have Sonar 5 with an MP7 with 4 ROMs (POP,DRUM,PHATT,WORLD) an XL7
with just the XL rom and an RS7000 .... I also have another MP7 that
I use to control Sonar and the soft syths.
love
> to see your input.
> ROM on the MP7.
to
it
> > later. Sorry.
with
> > > the XL ROM.
> > > Any Clues ??
20Data/
file.
> > It
> > for
> > > the
that
> > > you
> > > INSTALLED).
> > > > .Patch Names
> > > > 0=cmb:AdvancedOrch
> > > > 1=cmb:Traditional
> > > > 2=str:LegatoString
> > > > 3=cmb:Orch Split
> > > > etc.
> > > > [E-MU Proteus 2500]
> > > > 66*128 8448
bank 9
> > in
INSTALLED
> > > message.
in
> > > User
> > > > memory.
> > > > --Steve
> > everything
Sonar
> > My
> > > MP7
> > working
> > > > on ...
> > > > > what's wrong ??
or
> > > WORLD
> > thanks !
2006-09-01 by steve_the_composer
I think my lost post might have helped diagnose the problem. Presently,
my computer (and Sonar) is not MIDIed to my E-Mu [P2500 w/ XL-1 ROM].
So I have not been able to reconstruct the diagnostic steps. Perhaps
over the long weekend I will be able to do it.
My guess is that you do not have Sonar setup properly. Why don't you
either post (in the Files section) your master.ins file from Sonar. I
(and others) can try to figure out what's not working properly.
Internally E-Mu sequences have a short sysex command that sends preset
data to the internal synth. When you save that as a *.mid file and open
it into Sonar, Sonar stores that as sysex bank 0. It is designated as
autosend, so you are asked if you want to send it when you first load
the song into Sonar (unless you change the default query to "Don't ask
me any more; just do it!")
(Select View | Sysx, highlight Bank 0, then press Enter to see the
command.)
Don't despair; unless Sonar 5 is seriously buggy, you should be able to:
(1) change presets via Sonar on a track by track basis
(2) save your Sonar project with you desired presets.
--Steve
2007-04-22 by sounddaddy2
I never got this figured out ... all my .ins match my presets in the
MP7 ... I have the Composer...World and Drum ROMS ... .ins files
where made with the PROTEUM software and match up perfectly with the
BOX.
i switch banks in SONAR and everything works fine in the USER
BANK ... it just doesnt switch ROMS hen I make the change in SONAR.
I have just been saving MULTIS in the box and recalling them after I
load a song in SONAR 6 PE.
Any Clues I would REALLY like to figure this out.
Thanks !
Presently,
ROM].
Perhaps
you
Sonar. I
then
say
preset
open
as
load
ask
> command.)
able to:
> --Steve
2007-04-23 by D. Clowers
Try this page:
http://www.tweakheadz.com/how_to_build_a_cakewalk_ins_file.htm
DC
> BOX.
> Thanks !
> Presently,
> ROM].
> Perhaps
> you
> Sonar. I
> then
> say
> preset
> open
> as
> load
> ask
> > command.)
> able to:
> > --Steve
how to import midi file in song track
2007-04-24 by Dacian Victor
Hi everyone,
  is there a way to upload midi file in song track, longer than 32
  I succed to record it, live or record it from a midi outside player.
But i will like to import it somehow!!!
  thank's
  Daci
Ahhh...imagining that irresistible "new car" smell?
 Check outnew cars at Yahoo! Autos.
how to import midi file in song track?
Hi everyone,
  thank's
  Daci
Re: [xl7] how to import midi file in song track?
2007-04-24 by jip lip
There may be an easier way, not sure, but one way i
can think of is to break the midi file into 32 length
patterns and then use e-loader to upload those
patterns. From there you can add the midi segments as
patterns in individually to a song.
--- Dacian Victor <dacian_victor@...> wrote:
>   Hi everyone,
> longer than 32
>   thank's
>   Daci
> removed]
Do You Yahoo!?
http://mail.yahoo.com
2007-04-25 by Dacian Victor
  I use this one(to split the chanel) and also i record directly in to the song track.
  Also how i insert a new event in the song edit event chanel ???
  But i would like to know if there is anyone who did it.
  thank's//Daci
Re: how to import midi file in song track?
2007-04-25 by gonzinigonz
You should be able to import a midi file longer than 32bars into song
mode with E-Loader.
As for editing, the same sort of functionality as pattern mode, but
just one track.
Is this what you mean?
--- In xl7@yahoogroups.com, Dacian Victor <dacian_victor@...> wrote:
> Hi,
to the song track.
>   thank's//Daci
many thanks to gonzinigonz ! //
2007-05-03 by Dacian Victor
Many thanks to  gonzinigonz !, for the answer ... and i have more question
      and also i need more advises for live performance
  1. can i play a song before the last one ended??? (very important)
2. can i set the keypads from the station to be more sensitive,
    more similar to a normal keboard (i need it for live stuff)
      Daci
[xl7] can i set the XL7 keypads to be more sensitive?
2007-05-05 by Dacian Victor
Hi everyone, i have more questions about xl7
1. how can i play a song, before the last one ended??? (very important)
2. how can i set the keypads from the station to be more sensitive,
more similar to a normal keboard (i need it for live stuff), also if you have more experience with live stuff, i need some advise
  3. can i eq different instruments or chanels, i have to much bass for example on one track
  4. how can i set to the knobs to the LFOsync, shape, rate....
thanks, Daci
8:00? 8:25? 8:40?  Find a flick in no time
 with theYahoo! Search movie showtime shortcut.
Re: can i set the XL7 keypads to be more sensitive?
2007-05-06 by steve_the_composer
I can't answer all your questions; I hope others can.
3. Different EQ
You cannot EQ "tracks" internally. If you want to do it externally,
you can use the main outs and sub outs.
On the preset level, you can use different filters and different
settings on different layers. Each preset can have up to 4 layers
(not including linked presets). You have the following types of
filter "types:"
LPF - Low Pass Filter
HPF - High Pass Filter
BPF - Band Pass Filter
EQ+/EQ- - EQ FIlters
VOW - Vowel FIlters
PHA - Phasing Filters
FLG - Flanging Filters
REZ - Resonance Filters
WAH - Wah-wah Filters
DST - Distortion Filters
SFX - Special Effects Filters
With each filter you have settings: Freq: & Q:
Each layer also has a filter evelope (AADDRR).
Using patch courds, you can also rout various "sources" to to
various "destinations"--including FiltFReq [Freq] and 'FiltRes [Q].
4. Using knobs
QUICK EDIT MODE [knobs]:
In Preset Edit mode, Patchcords have MidiA through MidiP as sources.
These allow you to send the knobs to various destinations. You have
24 layer level patchcords and 12 preset level patchcord.
PROGRAM MODE [knobs]:
Also, using the controller button, you can access the Programmable
Knobs (K1-K16).
You can switch between Quick Edit, Program, Volume, and Pan modes on
the fly.
Hope this helps.
--Steve
important)
sensitive,
> thanks, Daci
Re: many thanks to gonzinigonz ! //
2007-05-07 by gonzinigonz
No worries glad to of been some help :o)
> and i have more question and also i need more advises for live
> performance
No i dont so. Maybe XMIX can help you there though.
Look at the velocity curve settings in the global menu.
Theres a number of differant responce curves for the pads.
>       Daci
Re: [xl7] Re: many thanks to gonzinigonz ! //
2007-05-07 by Dacian Victor
Thank's to all for the quick answers, you where very helpfull.
Is there a list with people, bands who use xl7?
  Just a curiosity@:),.. thanks again
  Bye
Don't pick lemons.
See all the new 2007 cars at Yahoo! Autos.
2007-05-10 by gonzinigonz
>   Bye
Dont know about that one.
