The easiest way that I have found to do this (so far) is to create a pattern
with all of your necessary external channel assignments set first, then
record at least one note on each of the 'external' tracks, and the save it
as a base pattern (works best if its pattern 000 in whatever bank). Then to
start a new one, go to that track, hit save and select where you want to
start the new one, and then go into the pattern edit and select to delete
all track data (being sure all the tracks are 'ON'). Then they all stay set
to the designations....this is a bit tedious as well, but is quicker still
than going track by track everytime. I hope they fix that in the next OS :))
Byron
Chaos exists as raw material from which to create order.
-Reverend Mother Superior Darwi Odrade
Sent: Saturday, July 20, 2002 1:23 PM
To: xl7@yahoogroups.com
Subject: [xl7] Sequencing question??
When I use the XL-7 to sequence a midi module. It seems like I have
to select external in the "channel assignment " each time for each
individual track. Is there a short cut or any advice to make it
easier to using the XL-7 just as a sequencer for my external gear? I
know that with the 1.31 operating system the unit reverts to
internal on the midi channel assignment page. I just want it to stay
external. Also I am open for any tips in this area of sequencing and
any advice to making my life easier. I am still learning the unit.
Thanks, Billy
