Index last updated: 2026-04-29 00:01 UTC
Discrete Input on TPU
2002-08-28 by Charly Mauron
Hi !
What is the best function to choose if I want to use a TPU (Mask Set G)
channel to capture a state (discrete input).
Thanks fort the answer
Charly
_____________________________
Charly Mauron
R & D Monitoring Systems
charly.mauron@...
Direct Phone : ++41 (41) 766 43 17
Fax : ++41 (41) 761 08 80
SCHILLER AG Switzerland
Altgasse 68
CH-6341 Baar
www.schiller.ch
Re: [68300] Discrete Input on TPU
2002-08-28 by Andrei Chichak
Charly,
Use masm to assemble DIO, drop it into emulation RAM and away you go.
You could use PTA as long as the signal stays in the asserted state for
long enough to generate an interrupt. You could use NITC with a MAX_COUNT of 1.
Tie your input to a PORTE or PORTF bit?
My real answer would be the DIO in emulation RAM. Using the emulation RAM
is a nice tool to have in your toolbox. If all of your functions are
downloaded, you don't have to care about which mask you are using, and
reverse engineering the code becomes harder as someone would have to
disassemble your microcode.
Andrei
>Charly
Andrei Chichak               #200 10835-120 Street
Senior Software Developer    Edmonton, Alberta
Pulmonox Medical Inc.        Canada
                              T5H 3P9
                              (W) (780) 451-3660
                              (F) (780) 452-0169
