Subject: Re: [CZsynth] CZ1 keyboard issue
To: CZsynth@yahoogroups.com
Date: Monday, 4 July, 2016, 23:35
I don't know about CZ1,but my CZ1000 loses the stored settings,and I have to push the 'P' reset button underneath because the backup is not working. I have never tried MIDI access during this condition.
If MIDI is working normally then it probably is not this. If it has been left for a long time,it maybe as well to check any internal backup backup system and perform a master reset?
L
I have sent this answer to Vintage Synth
group, still probably it didn't come, so once more
here:
Your description is not quite
exact... I think it's you who should have an idea what
happened :-) There's always some reason for such
behavior.
One of them,
for example, can be that if it was not in use for longer
time period, maybe contacts are dirty or oxidized. I would
reseat and clean all connectors as a first simple step.
Focus on keyboard cables and connectors, I suppose there are
some.
Sometimes after
the long sleep it's good to leave the machine on for
longer time - three days and nights, but keep eye on it and
switch off again when you can't stay near
it.
Daniel Forro
On Jul 5,
2016, at 4:15 AM, roberflas@...
[CZsynth] wrote:
Hello,
I have a CZ1 , that was my first synthesizer , but one day I
turn it on and if you touch any key , it sounds a very high
note and hold on , if you play more keys it adds up but with
high notes.
Some keys sound with erratic
tune and the other keys sound with high tune and stay hold
on after the key is depressed until power off the synth.
If you play throught MIDI , all is correct,
all notes , program change , etc.
Anyone have any idea what can happen ?.
Thank you in advance
#yiv2754629414 #yiv2754629414 --
