Hart Dynamics pads
Hart Dynamics pads
2004-12-04 by pdsonline2002
Hello again.
After much hard Internet searching I have finally found a site in
the UK that supplies Hart Dynamics pads. www.edrumonline.co.uk. Does
anyone have any advice as to how compatible these pads are with
DTXpress 2 modules.
Re: Hart Dynamics pads
2004-12-04 by emf
--- In DTXpress@yahoogroups.com, "pdsonline2002" <philldrew@t...>
wrote:
> Hello again.
Does
> DTXpress 2 modules.
Is this the store that Simon (aka flurbs) runs? I'd contact them
through one of the email addresses on the site and ask. Once upon a
time, using certain Hart equipment--particularly, the hi hat, ECII
ride cymbal, and Acusnare--with a Yamaha module ran the risk of poor
trigger response. I've heard relatively recently that the danger is
greatly reduced, but I haven't verifed it myself. If edrumonline
can't give you a satisfactory answer, try emailing Hart Dynamics
International for an answer. A summit meeting between Hart and Yamaha
(in the person of Tony Verderosa) took place a while back for the
express purpose of checking compatibility issues. No public
statements about the outcome have emerged, to my knowledge, but maybe
Hart has information on the subject now for potential Yamaha
customers.
Hart used to be relatively indifferent to these concerns. That's why
you don't see the company represented by many users on this site. A
couple of years ago, a number of us started trying out Hart equipment
and ran into the problems that I mentioned above. At the time,
despite Hart's expressed intention to look into the matter, nothing
came of it. I don't think that they can resist the Yamaha market much
longer, and Yamaha itself has begun to join the e-drum community a
little more, apparently realizing that they cannot make all things
for all people themselves. It was a hard road.
Ed
2004-12-04 by peterpan
Yes this is indeed the store that simon (flurbs) represents. I have
bought a number of things from him, I'd defnitely say give them a
call or email to ask directly, thay are very helpful chaps down
there. FWIW I have been using one of my Hart Pro Toms as a mono snare
with my DTXpress 1 brain for a while, until I find a permanemt
replacement. It have perfoemed fine, wouldn't say it is optimal, but
I only use the Xpress for practice at home, so top sounds & fantastic
triggering are not particualrly important.  However the current Hart
pads now come with the newer & improved TE3.2 trigger system, this
may have made using a Yamaha brain fully possible. Hopefully Simon
will be able to clear this issue up.
> wrote:
> > Hello again.
> Does
> > DTXpress 2 modules.
poor
Yamaha
maybe
> customers.
why
equipment
much
> Ed
2004-12-05 by vl2000_us
I am running a DTXtreme IIs with the original 5 Yamaha pads plus 8
Hart toms and a Hart snare.
I am nothing short of thrilled with the performance of the Hart
products, albeit it takes a little extra experimentation because they
play, respond and trigger a little differently than the Yamahas.
The only problems I have experienced are on 1 of the toms and on the
snare, some occasional dropped hits.
After working thru a gazillion settings changes and combinations of
rejection settings, I am thinking its a head tightness issue.  I am
in the process now of kind of overtightening the heads, to see if
a) there was too much deep vibration maybe causing the trigger to
cancel itself, or
b) if the softer head tension was allowing my stick to somehow
overdrive the trigger.
Again, this has only been on 2 of the drums, and overall they have
performed, and look great.
Hope that helps.
vlus
wrote:
> Hello again.
Does
> DTXpress 2 modules.
Re: [DTXpress] Re: Hart Dynamics pads
2004-12-05 by Don
vlus:
Any quick advice on what tweaking of the module setting gave the
optimum results?
donn
>  cancel itself, or
>  Hope that helps.
>  vlus
>  wrote:
>  > Hello again.
>  Does
>  > DTXpress 2 modules.
> Community email addresses:
>    Post message: DTXpress@yahoogroups.com
>    Subscribe:    DTXpress-subscribe@yahoogroups.com
>    Unsubscribe:  DTXpress-unsubscribe@yahoogroups.com
>    List owner:   DTXpress-owner@yahoogroups.com
>  Shortcut URL to this page:
>    http://groups.yahoo.com/group/DTXpress
>  Alternate DTXpress site:
>    http://www.dtxpressions.com
> Yahoo! Groups Sponsor
> ADVERTISEMENT
> <122603_LREC_bkup_BR_Ashanti.jpg>
> <l.gif>
> 	• 	To visit your group on the web, go to:
> http://groups.yahoo.com/group/DTXpress/
> 	• 	 To unsubscribe from this group, send an email to:
> 	• 	 Your use of Yahoo! Groups is subject to the Yahoo! Terms of
> Service.
Thank you!
Don Pokorny
2004-12-05 by pdsonline2002
Thanks for all the advice, Its been very helpfull. I have fired off
an email to edrummingonline asking for the "Official word" on
compatability and settings.....fingers firmly crossed. I post the
reply if it is of any help and then start the hint dropping to my
good lady.
--- In DTXpress@yahoogroups.com, Don <contract731@c...> wrote:
>   vlus:
> optimum results?
> donn
plus 8
because they
on the
combinations of
I am
if
to
> >  cancel itself, or
have
> >  Hope that helps.
> >  vlus
<philldrew@t...>
> >  wrote:
> >  > Hello again.
site in
> >  Does
with
> >  > DTXpress 2 modules.
> > ADVERTISEMENT
> > <l.gif>
> > Yahoo! Groups Links
Terms of
> > Service.
> Thank you!
> Don Pokorny
2004-12-06 by vl2000_us
donn... man its been a long and ongoing process.  i imagine it will
also be somewhat different for different setups.  for example i use a
gibralter rack (rock solid) and have a rock solid drum riser, so i'm
getting away with little if any rejection settings from crosstalk.
now, if you set up on a loose stage or riser, you may have to tighten
down the rejection settings.
i am basically working with self rejection set to the min which is
5ms on pretty much everything.  wish i could get it to zero, in fact.
i have found that i get best results with gains set nearly maxed on
the harts.  that may change with more tweaking, but i have for most
of my kit programs, my yamaha toms set at 32, my hart toms at 57, my
hart snare at 57 and my yam snare at either 45 or 63 depending on
what i'm trying to do with it.
i use the hart snare as my main.  i use the yam snare as either a
specialty snare (ex: big fat 80s rock sound) at which case i run it
at 45, because the yamahas seem 'hotter' than the hart.  i have to
run the hart at 57 to be approx same vol as the yam at 45.
on the other hand sometimes i use the yam snare as a special fx
trigger (ex: hand clap, bells, etc) so i run the gain to 63.  when i
do that, i'll also set the volume where i want it for the voice, and
i'll usually set the velocity at min-126 max -127, that way i always
get full force FX even if i mis-strike the pad
i had a full band rehearsal today after really torquing the heads
down tite on the harts.  the reason for this, as i posted earlier, is
i had one tom and the snare, periodically drop a hit.  really throws
me off when that happens and it was buggin the shit out of me.
i tried every rejection combination, against itself, the rack, other
drums, etc... i'm finally convinced (well almost convinced) that
these heads like to be a quite a bit tighter than i've ever had my
acoustics, almost to the point where i feel like they're too tight.
but... no dropped hits today, and i was hammering unusually hard
today because bass player was cranked.
i'm not sure if the looser head was causing the stick to over drive
the trigger, or, if the looser head was creating too much extra
vibration that was within the 5ms minimum self rejection setting and
hence cancelling the next hit.  (thats why i mentioned earlier about
wishing i could take self reject to zero just to experiment)
what else... i've managed to get the kit where i'm running all the
special rejections at 0 from any other drum, as well.
I built my own snake for cable management so i can very quickly wire
the whole set properly.  (i dont use any of the channels as labeled :-
let me know i can help with anything else.  right now the only thing
i want to figure out is if i can put wipe or spray something on that
beautiful chrome finish on the harts.  they are going to occasionally
spend a few days in the cold band truck and i dont want the
condensation to start pitting the surface.  thinking some kind of wax
or something.
overall i'm thrilled with my combo hart/yam kit.
good luck-
vlus
http://www.MonstersOfRock.info
>   vlus:
> optimum results?
> donn
2004-12-06 by Don
Thank you,
Don
>  or something.
>  good luck-
>  vlus
>  >   vlus:
>  > optimum results?
>  > donn
> ADVERTISEMENT
> <111704_1104_g_300250a.gif>
> <l.gif>
> Service.
Thank you!
Don Pokorny
