From: jggallow Sent: Friday, March 04, 2005 3:03 PM
To: DTXpress@yahoogroups.com
Subject: [DTXpress] Re: RHH130 Hi-hat upgrade for DTXPRESS II
Thanks for the response. I have some follow-ups:
I don't recall having any cancelling issues with the snare and hi-
hat when I used the stock TP65 pad that came with the kit. I've
only noticed it with since I changed to the Pintech zenbal. Was
this problem with the module noticible only when other
manufacturer's components were mixed with the kit? Also, was there
ever a fix or patch for the "flaw"? I really would like to find a
solution to my current problem and not have to buy another cymbal.
I actually like the Pintech cymbal; I just hate the low volume and
the cancelling with simultaneous snare hits. That's a show-stopper
in my book!
Still a little confused on the RHH130 and the stand integration. My
question is how does the standard hi-hat stand pedal manipulate the
hi-hat closing/opening sound? what is the pedal action physically
doing to the cymbal? If I were to start tapping out a beat
with the hi-hat peddle, how does that register a sound since there
is no more hi-hat foot controller pedal that pugged into the
module. I assume that connection actually connects somewhere into
the RHH130 itself (I presume the RHH130 has two cable connections
then). Is this correct. If you could please describe how it
connects.
--- In DTXpress@yahoogroups.com, "emf" <liberatusvirus@y...> wrote:
> --- In DTXpress@yahoogroups.com, "jggallow" <jggallow@y...> wrote:
> > It's been disappointing. First off, without any module
> modification,
> > the zenbal cymbal carried very low volume. For months I've been
> > modifying the settings to get it to play loud. I just can't
push
> the
> > module any higher. I can't get adequate volume out of the
cymbal.
> > On top of that, simultaneous hits with the snare and the hi-hat
> > eliminate the hi-hat strikes. This has bummed me out. I again
> have
> > modified the rejection settings on the module but can't keep it
> from
> > continuing. I'm out of ideas unless someone out there has a
> similar
> > setup and has it working well. Please let me know your tricks
if
> > you're out there.
> The problem of the snare cancelling the hi hat entailed a flaw in
> specific rejection setting out of the box when the II came out. If
> I'm not mistaken, we discovered it on this board and called
Yamaha's
> attention to it. It wouldn't have mattered whether the hi hat
> component were a Yamaha or any other company's, since the problem
was
> with the module. Your difficulty seems too similar for
coincidence,
> though you've presumably had yours long enough to have rectified
it
> in the usual way.
> > This foul path has led me to some conclusions that may or may
not
> be
> > entirely true. My first thought is that mixing drum components
> from
> > different manufacturers is tricky and troublesome.
> This idea has more merit with mixing/matching on a Yamaha base
than
> on any other company's. Most after-market e-drum gear is
> manufactured, first and foremost, to be compatible with Roland's.
> Most of the time, use with Yamaha gear won't be a total failure,
> although it has been at times, but perfect compatibility with
Yamaha
> has been elusive enough at least to cause inconvenience. Pintech
has
> always been one of the brands most adaptable to a Yamaha context.
> > My second thought is, naturally, it is better in my case to use
a
> Yamaha-based product
> > to ensure compatability. So if that is true, what Yamaha pad is
> the
> > right pad for me?
> > That has led me to research the RHH130 pad now included in the
> > DTXPRESS III. It has the right "Look." But I have these
questions:
> > 1) Is this pad compatable with the DTXPRESS II module? Will I
have
> > volume issues?
> > 2) How does this pad work? The write-ups on the web say it
> attaches
> > to a standard hi-hat cymbal stand (which I have, albeit an old
> one).
> > How does a standard hi-hat stand peddle manipulate this pad? Is
> the
> > pad split into two parts are the top and the upper and bottom
> halves
> > trigger the pedal activity? What happens to my current hi-hat
> > pedal? I assume that's not used anymore.
> Staying within the Yamaha camp is safest, unless you have good
> information or personal experience otherwise. The RHH130 is
> compatible with the II. I don't know of any volume issues. It
> connects and behaves like your HH65. Most hi hat stands appear to
> accommodate it; it just needs proper room to clamp. The pad itself
is
> stationary on the hi hat stand; it does not work like an acoustic
hi
> hat, with two cymbals that open aand close. Since you use the
stand
> for the foot action, your current HH65 would go to pasture, ebay,
> another board member, or perhaps to another input as a second kick
> pedal.
> Ed
Community email addresses:
Post message: DTXpress@yahoogroups.com
Subscribe: DTXpress-subscribe@yahoogroups.com
Unsubscribe: DTXpress-unsubscribe@yahoogroups.com
List owner: DTXpress-owner@yahoogroups.com
Shortcut URL to this page:
http://groups.yahoo.com/group/DTXpress
Alternate DTXpress site:
http://www.dtxpressions.com
Yahoo! Groups Sponsor
ADVERTISEMENT
click here
<http://us.ard.yahoo.com/SIG=129e6c8er/M=298184.6018725.7038619.3001176/
D=grplch/S=1705031972:HM/EXP=1110053023/A=2593423/R=0/SIG=11el9gslf/*htt
p://www.netflix.com/Default?mqso=60190075>
<http://us.adserver.yahoo.com/l?M=298184.6018725.7038619.3001176/D=grplc
h/S=:HM/A=2593423/rand=358749896>
Yahoo! Groups Links
* To visit your group on the web, go to:
http://groups.yahoo.com/group/DTXpress/
* To unsubscribe from this group, send an email to:
<mailto:DTXpress-unsubscribe@yahoogroups.com?subject=Unsubscribe>
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service <http://docs.yahoo.com/info/terms/> .
______________________________________________________________________
This email has been scanned by the MessageLabs Email Security System.
For more information please visit http://www.messagelabs.com/email
