buying dtxpress III sp
2005-08-30 by walkacrossfire
I'm interested in some details I can't seem to find out before I buy.
What's the diameter of the snare pad?  Can you play a rim shot and
straight on hit without changing the voice?
Thanks for your help
Re: buying dtxpress III sp
2005-08-30 by Keith
--- In DTXpress@yahoogroups.com, "walkacrossfire"
The same as the tom pads - around 8.5" overall diameter, 7" playing
surface.  I am not sure I understand the second part of your question.
 The built in kits come with the rim programmed up for one voice and
the main pad for another voice (and the cross-stick for another
voice).  You can change these if you want and save the kit.
Keith.
Re: [DTXpress] Re: buying dtxpress III sp
2005-08-31 by geek
I suggest instead of getting the Special you should go
for the standard DTXpressIII kit and add on in the
future if u feel like it ..... I just got mine 2 weeks
back .... and Oh BOY !! :) am really satisfied at my
decision.....  I had similar qs in the mind like u
..... to answer your second qs:
The snare is a 3 zone pad ... u can play rimshot,
accents, ghost notes, cross sticks etc. just in a
style you would play an acoustic snare ....  you would
be surprised how realistic it is ... even though the
normal setups are correct u can even adjust the
sensitivity and velocity of the pads ( i mean how hard
you should hit to have the desired vol etc. ).... the
only thing i miss is the positional sensing .... :(
You can get more information at
http://dtxperience.com/dtxpressIII.php
http://www.dtxpressions.com/
This is a decent review and description of the package
dimensions and components model numbers:
http://www.kraftmusic.com/catalog/drums/2966
Go for it ....u would not regret .... and if at all u
can always add a couple of acoustic percussion to it
regards..
> play a rim shot and
> of your question.
> for one voice and
> for another
> the kit.
> Keith.
____________________________________________________
Start your day with Yahoo! - make it your home page
http://www.yahoo.com/r/hs
