--- In DTXpress@yahoogroups.com, "Keith" <keith@...> wrote:
> --- In DTXpress@yahoogroups.com, john@ wrote:
> > Hi ppl
> > At band practice last night, the 'sound man' was saying that he got a
> > buzz ing sound from my kit, but not from anything else. If my
> > Behringer amp was inbetween the kit and the PA, there was no buzz. So
> > he said that new, digital equipment isn't earthed properly.
> > Does he have a point, and if so, what can I do about it?
since the DTXpress is only supplied by an external small DC voltage
and has no internal power supply, it`s unlikely that your problems are
caused here.
I`m also not an expert in this, but have had these troubles as well
with other equipment. So more likely is that you have used some badly
soldered, faulty or even wrongly connected cables. Check all
connectors and make sure that the internal shield inside the cable is
(if at all) only connected at the side of the signal generating unit!
Lots of noise problems are generated by this, especially when you
switch to XLR during the signals travel.....
Good luck,
Wolfgang
