KP60 again
2002-02-07 by liberatusvirus
Searching through the archives I found a lot of the same kinds of problems with the KP60 that I asked about last week, particularly dropouts, regardless of gain, rejection, and min. vel. settings. Is the Pintech Verikik more reliable? What else have people done? Ed
2002-02-07 by lockhart69t
--- In DTXpress@y..., "liberatusvirus" <edtyct@m...> wrote: > Searching through the archives I found a lot of the same kinds of > problems with the KP60 that I asked about last week, particularly > dropouts, regardless of gain, rejection, and min. vel. settings. Is > the Pintech Verikik more reliable? What else have people done? > > Ed I found with my KP60, that a hard beater instead of felt one, along with the right tweek of the parmeters, works best. Hope that helps ya. lockhart69t
2002-02-07 by wgardus
Hi Ed, Here's my two cents worth - I have both a Vertikik and a KP60 (although it was nuetered by a previous owner, removing the polarity and sensitivity electronics), and I would say they are dead even in performance, and I have not had dropouts with either. Walt --- In DTXpress@y..., "liberatusvirus" <edtyct@m...> wrote:
2002-02-07 by T. Bach Melick
--- wgardus <wgardus@...> wrote: > Hi Ed, > > Here's my two cents worth - > > I have both a Vertikik and a KP60 (although it was > nuetered by a > previous owner, removing the polarity and > sensitivity electronics), > and I would say they are dead even in performance, > and I have not had > dropouts with either. > > Walt Regarding your post, what is a Vertikik? Thanks, Bach Melick tmelick@... __________________________________________________ Do You Yahoo!? Send FREE Valentine eCards with Yahoo! Greetings! http://greetings.yahoo.com
Hi Bach, I thought I had sent a reply, but I didn't see it post so let me send it again. It is a Pintech kick pad, similar to the KP60. Here's a link: http://www.pintechusa.com/New_Pintech_Si/vk10.html Walt --- In DTXpress@y..., "T. Bach Melick" <tmelick@y...> wrote:
> --- wgardus <wgardus@y...> wrote: > > Hi Ed, > > > > Here's my two cents worth - > > > > I have both a Vertikik and a KP60 (although it was > > nuetered by a > > previous owner, removing the polarity and > > sensitivity electronics), > > and I would say they are dead even in performance, > > and I have not had > > dropouts with either. > > > > Walt > > Regarding your post, what is a Vertikik? > > Thanks, > > Bach Melick > tmelick@y... > > > > __________________________________________________ > Do You Yahoo!? > Send FREE Valentine eCards with Yahoo! Greetings! > http://greetings.yahoo.com
2002-02-08 by liberatusvirus
Hi Walt,
I remember you writing about your neutered KP60 before. Frankly, I
wouldn't be surprised if your good fortune were related to what your
KP60 is missing. Anyone with experience in audio knows that the less
complicated the signal path is, the more faithful the signal will
be. I don't know whether that's what's going on with mine, though.
My first KP60--not this one--was a complete dud. Midwest Percussion
put me directly in touch with Yamaha ("Dave," but not the earlier
Yamaha "Dave" from the archives). He suggested that applying a hot
soldering iron to the connections might do the trick; it didn't. He
then sent a new sensor, and when that failed, he sent a new unit
altogether. Something in the circuit board obviously wasn't right.
Yamaha was very nice and very prompt about everything. But the KP60
appears to be a weak link. My new one is by no means terrible, but a
dropout at any time is frustrating. Hopefully, as lockhardt
suggests, the right tweak is waiting. otherwise, if I get cranky
enough, so long to my sensitivity and polarity controls--and
probably my warranty. But don't get me wrong. I love this thing.
--- In DTXpress@y..., "wgardus" <wgardus@y...> wrote:
> Hi Ed,
electronics),
had
> Walt
of
particularly
Is > > the Pintech Verikik more reliable? What else have people done? > > > > Ed
2002-02-08 by Walt
Hi Ed,
I agree, especially if the tolerances on the pots
isn't especially tight - banging on them could easily
cause a drop out in my mind...
--- liberatusvirus <edtyct@...> wrote:
> Hi Walt,
> before. Frankly, I
> knows that the less
> the signal will
> mine, though.
> Midwest Percussion
> not the earlier
> applying a hot
> sent a new unit
> wasn't right.
> terrible, but a
> lockhardt
> I get cranky
> controls--and
> this thing.
> wrote:
> > Hi Ed,
> nuetered by a
> sensitivity
> electronics),
> and I have not
> had
> > Walt
> the same kinds
> of
> week,
> particularly
> min. vel. settings.
> Is
> have people done?
> > > Ed
Do You Yahoo!?
http://greetings.yahoo.com2002-02-08 by Joseph Palacki
the pintect vertikick is extremely reliable. I also found that the kick trigger that comes with the roland v-club kit is very reliable as well, its also pretty sensitive for as cheap as it is. Unfortunately you need a bent-shaft beater for it, I don't know if that would be included with it if you bought one. Another thing that works well is if you have a remo tunable practice pad with a pedal mount. Replace the coated head with a mesh one take all of the foam out of it and buy a small hart brand 1/2" trigger and mount it to the mesh head just how the instructions say. It's cheap and won't miss-trigger or cut out but you have to be careful if you use it for gigs, you will need a spare mesh head with a pick up already mounted incase you break it. --- liberatusvirus <edtyct@...> wrote: > Searching through the archives I found a lot of the > same kinds of > problems with the KP60 that I asked about last week, > particularly > dropouts, regardless of gain, rejection, and min. > vel. settings. Is > the Pintech Verikik more reliable? What else have > people done? > > Ed > > __________________________________________________ Do You Yahoo!? Send FREE Valentine eCards with Yahoo! Greetings! http://greetings.yahoo.com
Thanks, Joseph. It's good to know what's out there that works, including diy. Ed --- In DTXpress@y..., Joseph Palacki <palacki808@y...> wrote:
> the pintect vertikick is extremely reliable. I also > found that the kick trigger that comes with the roland > v-club kit is very reliable as well, its also pretty > sensitive for as cheap as it is. Unfortunately you > need a bent-shaft beater for it, I don't know if that > would be included with it if you bought one. Another > thing that works well is if you have a remo tunable > practice pad with a pedal mount. Replace the coated > head with a mesh one take all of the foam out of it > and buy a small hart brand 1/2" trigger and mount it > to the mesh head just how the instructions say. It's > cheap and won't miss-trigger or cut out but you have > to be careful if you use it for gigs, you will need a > spare mesh head with a pick up already mounted incase > you break it. > > > --- liberatusvirus <edtyct@m...> wrote: > > Searching through the archives I found a lot of the > > same kinds of > > problems with the KP60 that I asked about last week, > > particularly > > dropouts, regardless of gain, rejection, and min. > > vel. settings. Is > > the Pintech Verikik more reliable? What else have > > people done? > > > > Ed > > > > > > > __________________________________________________ > Do You Yahoo!? > Send FREE Valentine eCards with Yahoo! Greetings! > http://greetings.yahoo.com
No problem. Electric drums aren't very common and unfortunately that means people who have a great deal of knowledge are in short supply. That's why if I can answer the question I will give up every bit of info I can. I have built several triggers of my own in the past year and have learned a good bit. If you have any more questions about triggers don't hesitate to email me. I'll do my best to find an answer. Unfortunately though I know close to nothing about midi. I may be asking you and some of the other users in the group alot of questions in the up and coming year. -Joe --- liberatusvirus <edtyct@...> wrote: > Thanks, Joseph. It's good to know what's out there > that works, > including diy. > > Ed > > --- In DTXpress@y..., Joseph Palacki > <palacki808@y...> wrote: > > the pintect vertikick is extremely reliable. I > also > > found that the kick trigger that comes with the > roland > > v-club kit is very reliable as well, its also > pretty > > sensitive for as cheap as it is. Unfortunately you > > need a bent-shaft beater for it, I don't know if > that > > would be included with it if you bought one. > Another > > thing that works well is if you have a remo > tunable > > practice pad with a pedal mount. Replace the > coated > > head with a mesh one take all of the foam out of > it > > and buy a small hart brand 1/2" trigger and mount > it > > to the mesh head just how the instructions say. > It's > > cheap and won't miss-trigger or cut out but you > have > > to be careful if you use it for gigs, you will > need a > > spare mesh head with a pick up already mounted > incase > > you break it. > > > > > > --- liberatusvirus <edtyct@m...> wrote: > > > Searching through the archives I found a lot of > the > > > same kinds of > > > problems with the KP60 that I asked about last > week, > > > particularly > > > dropouts, regardless of gain, rejection, and > min. > > > vel. settings. Is > > > the Pintech Verikik more reliable? What else > have > > > people done? > > > > > > Ed > > > > > > > > > > > > __________________________________________________ > > Do You Yahoo!? > > Send FREE Valentine eCards with Yahoo! Greetings! > > http://greetings.yahoo.com > > __________________________________________________ Do You Yahoo!? Send FREE Valentine eCards with Yahoo! Greetings! http://greetings.yahoo.com
2002-02-09 by Ken Anthony
Mine was intermittent ( drop outs, etc. ). At first i thought the piezo was bad so I replaced it -- no go.. I resoldered the whole PCB - no go... I replace the resistors on the PCB - that did it.. I remember many years ago an insertion machine in a factory that was putting stress on the leads of some diodes, causing intermittent failures in the field - this may be a similar issue. either way - $1 worth of radio shack parts and life is good. It's actually better now than ever... BTW- i use a felt beater. lockhart69t wrote:
> --- In DTXpress@y..., "liberatusvirus" <edtyct@m...> wrote: > > Searching through the archives I found a lot of the same kinds of > > problems with the KP60 that I asked about last week, particularly > > dropouts, regardless of gain, rejection, and min. vel. settings. > Is > > the Pintech Verikik more reliable? What else have people done? > > > > > Ed > > I found with my KP60, that a hard beater instead of felt one, along > with the right tweek of the parmeters, works best. Hope that helps > ya. > > lockhart69t > > > Community email addresses: > Post message: DTXpress@onelist.com > Subscribe: DTXpress-subscribe@onelist.com > Unsubscribe: DTXpress-unsubscribe@onelist.com > List owner: DTXpress-owner@onelist.com > > Shortcut URL to this page: > http://www.onelist.com/community/DTXpress > > Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
