I assume you'll be running a single line out into the PA mixer. If
so, the EQ mix on the board will have to stay pretty flat to give you
the highs of the cymbals and the lows of the bass.
If it's not too much trouble and you have another channel on the
board available, you might consider panning all your cymbals and
snare to the left and the bass and toms to the right. That way, you
can run two lines to the PA and mix accordingly.
Also, if you don't have the luxury of an amp or monitor, definitely
use a set of headphones or earplugs (although this can be a bit
confusing if you run two channels (bass and toms in right ear, snare
and cymbals in left).
Also make sure you have a 'friend' in the audience to let you know
how the mix sounds. Too often, the bandmember responsible for the
main mix doesn't give the drums the emphasis they need.
Stephen
