How to for newbie
How to for newbie
2003-12-05 by webc1958
After spending some time with the manuals I am unable to use my 2nd
DTXpressII brain (and kit) with my first DTXpressII brain (and kit).
I am attempting to hookup via midi, and all the posts I have searched
state it can be done but not 'how'.  Can someone post a link that
would explain this or perhaps explain it 'down and dirty'.  I have
limited experience with MIDI but I can read and comprehend the manual
and your messages.
Thanks very much
D.
Re: [DTXpress] How to for newbie
2003-12-05 by distortion@rogers.com
What are you trying to hook them up to at the same time?
If you are hooking them up to each other, why?
If you do that you would most definitly have to change ALL your note
number assignments for all of the kits in one of the DTX modules, or you
would have bothe units playing on heach pad hit, also the pad infor from
the second kit would not be sent out the OUT of the first kits' OUT..
only its t THRU, but the pads from THAT kit would not go out its
OUT...   ermmm..
Are you trying to record both into a sequencer at the same time? Then
you will need an interface with multiple midi ins or a Midi merge device
to bring both outs into one cable.
If all you do is play pads live then you really shouldn't need to hook
them up with midi, unless you want the kits to both change when you
change the 'master' kit.
We need to know more of the whole concept of what it is you need to do
and the whys to effectivly give an answer.
sorry.
gord
> and your messages.
> Thanks very much
> D.
> Yahoo! Groups Sponsor
> ADVERTISEMENT
> <http://rd.yahoo.com/SIG=12cdi2dv4/M=267637.4116732.5333197.1261774/D=egroupweb/S=1705031972:HM/EXP=1070720974/A=1853618/R=0/*http://www.netflix.com/Default?mqso=60178338&partid=4116732>
> Community email addresses:
>   Post message: DTXpress@yahoogroups.com
>   Subscribe:    DTXpress-subscribe@yahoogroups.com
>   Unsubscribe:  DTXpress-unsubscribe@yahoogroups.com
>   List owner:   DTXpress-owner@yahoogroups.com
> Shortcut URL to this page:
>   http://groups.yahoo.com/group/DTXpress
> Alternate DTXpress site:
>   http://www.dtxpressions.com
> Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service
> <http://docs.yahoo.com/info/terms/>.
Re: How to for newbie
2003-12-05 by emf
kit).
searched
manual
> and your messages.
> Thanks very much
> D.
D. and Gord,
This may well be a case in which someone thinks that the only way to
add a second module to a kit for more inputs is through MIDI.
Actually, this method is redundant at best and, well, . . . wrong at
worst. If you were to use a dedicated input to MIDI device, like
Roland's TMC-6, you would indeed use a MIDI connection from the slave
device to access MIDI note numbers on the DTXPress II module. But if
you simply want the benefit of two drum modules, each with its own
inputs, sounds, and audio outputs, what you need is an inexpensive
mixer--on the order of the Rolls MX28 or one of the (dare I say it)
Behringers, or others--which can accept audio output (not MIDI
output) from both modules, collect them, and send them out yet again
in a unified signal to headphones or amp. The mixer could also have
the benefit of other line/mic inputs for other voices/instruments.
With a little one for home use, all you'd probably need is one more
stereo input for a CD player, or some other source, for you to
practice with. Give us a call if you need further assistance with
this method--assuming that it meets your needs.
Ed
Re: [DTXpress] Re: How to for newbie
D. and Gord,
And THAT would use MIDI...  you contradicted yourself...  This would
also run the possiblility of having the DTX polyphony run out, depending
on the voice structure of the kit being played.
> But if
But we don't know what D. wants, as we can't tell from the question.
Offering all these solutions without truly knowing what D. wants could
just serve to confuse the issue.
The problem with tech questions is that we sometimes want to dive into a
solution without first totally identifying the TRUE needs, always needs
more WHYs to clarify and diagnose, then solve.
Reminds me of the story of a guy that bought a computer system from an
online retailer... he got it all shipped, and then complained that it
was all in pieces.. but he never did order a pre-built computer... just
the parts... he never explained his needs, and the retailer never
asked... a buddy just told him what components to get... he got what he
ordered, but not what he wanted.
A book for everyone wanting to properly learn the IN/OUT of midi
I suggest everybody buy this book...  It won't solve all your questions,
but it will definitely guide you into some greener pastures.. =)
http://www.amazon.com/exec/obidos/tg/detail/-/0825610508/ref=pd_sim_books_4/102-6792562-9409739?v=glance&s=books
gord.
2003-12-05 by emf
--- In DTXpress@yahoogroups.com, distortion@r... wrote:
> D. and Gord,
to
at
slave
would
depending
Gord.
I was making the distinction between a purely MIDI-connected device--
like the TMC-6, the Kat MIDIKITI, the Roland PM-16 et al.--which has
no sounds of its own, and a second sound module, of the DTXpress
sort, which does not need to access its sounds through a MIDI
connection. The DTXpress does have limited MIDI note numbers for the
purpose of a MIDI slave device used in conjunction with the DTXpress
itself, but many of us (including me, for years) have used such a
device to good effect for as many as six or more inputs. I fail to
see the self-contradiction (unless I were saying that the only way to
add inputs is via MIDI, and I'm not).
> > But if
it)
question.
could
into a
needs
an
it
just
what he
True, we don't know for sure, and all of us are capable of being
wrong, misinformed, and unclear about many things. But we've seen
this situation come up a lot over the years on this board. Hazarding
an informed guess at this point won't ruin anyone's day; nothing is
etched in stone. And if this is indeed what D was trying to do all
along, we may have skipped everyone an extra step or two.
Ed
> > D. and Gord,
way
> to
wrong
> at
> slave
> would
> depending
> Gord.
has
DTXpress
to
> > > But if
own
inexpensive
> it)
> question.
> could
> into a
> needs
from
> an
that
> it
computer...
> just
> what he
Hazarding
> Ed
Thank you for your feedback, I will clarify:  I have two full kits,
with brains, now.  I just want a bigger kit. I was under the
impression that you could connect one brain via midi  to the other
and monitor the entire kit from the 'last' brain (ie. brain 2)... I
suspectfrom reading some of the replies that it is ridiculously
difficult to attempt and that the inexpensive 4-6 channel mixer would
be the best option, yes?
Sorry for any confusion, but if there is a way to hook them up via
midi for this type of monitoring (function)great (I just don't know
how and the manual doesn't state it explicitly.
Thanks again!
D.
> Gord.
> sort, which does not need to access its sounds through a MIDI connection.
The fact that he ALREADY had a second DTX module at his disposal I guess
was missed by you. If he has one already, it makes no sense to go out
and buy another trigger device, as you were suggesting. Plus the added
polyphony... mmmmm polyphony...
You said "...thinks that the only way to add a second module to a kit
for more inputs is through MIDI. Actually, this method is redundant at
best and, well, . . . wrong" Then you went on to describe hooking up an
external trigger converter TROUGH MIDI. How else can you add inputs?
That is the contradiction. And again, he has got two DTX boxes, so why
bother with another one he would have to accquire?
I'm not sure I get what you mean by limited note numbers. Mine sends
every one from #0 to #127, and is held individually with each kit and
layer. What more do you want. Now I must admit that I have a DTXpress,
not the mkII so, I could be wrong about this same implimentation on the
mkII, but I should hope they didn't dumb it down...  Don't forget that
in my system, the DTX is/can control everything in my system, and can be
controlled by the sequencers too.. no problems here...
The inverse is also true.. you may confuse D. by giving premature advice
without fully understanding what D. wants to do is an un-informed guess.
Kind of like the advice you gave to LINKITOUT, you did not understand
what he wanted and thus gave an incorrect remedy, and like what I did
with CJA300 and mesh heads, I misunderstood and gave bad advice. A lot
of incorrect advice is worse than no advice at all. Not saying you were
wrong this time.. ok?  :-)    We are all guilty once and a while!
Love ya all!
Remember tomorrow is Krampusnacht
gord.
> Thanks again!
> D.
Ok,
Set up the kits to play... inputting all your desired pads.
Get a stereo 1/8" heaphone jack to two mono (left and right) 1/4"
adapter cord or make one using adaptors.
Take the left and right audio output from one module and feed it into
the aux input on front of the other module with the cord you just made.
PLAY MY FRIEND, PLAY!
No need for expensive things or MIDI, just a $10 cord from Radio Shack!
MIDI does not transmit any sounds, just data that says who did what,
where, how hard and for how long. Kinda like Penthouse Forum.
gord.
RE: [DTXpress] Re: How to for newbie
2003-12-05 by rdamon@mckinney-usa.com
Gord,
I started out with two complete DtxpressII kits. Using just two modules, I
did run a midi cable from module 1 to module 2 for the sole purpose of
sending a midi control change code for kit increment/kit decrement from a
BP80 connected to zone 9/10 on module 1 that would pass through to module 2.
By hitting the left pad of the BP80, both modules would go from kit 60 to
59, 59 to 58 etc. and by hitting the right pad of the BP80, both modules
would go from 58 to 59, 59 to 60, etc.   But even with that, all of the
sound was still sent out the left/right output jacks on the rear of the
modules to a mixer. My music sources were then fed directly into the mixer,
which gives me excellent control over sound levels between the three modules
and the music source.
When I got my third module and extra pads, I stop using the midi for that
purpose. (If your next question is "How did you do it?", at this point it
has been almost a year since I did it, I would be hard pressed to remember
the right settings without going back throught menus again.)
OGD
> From:	webc1958 [SMTP:delcamroy@...]
> Sent:	Friday, December 05, 2003 2:58 PM
> To:	DTXpress@yahoogroups.com
> Subject:	[DTXpress] Re: How to for newbie
> > > D. and Gord,
> way
> > to
> wrong
> > at
> > slave
> > would
> > depending
> > Gord.
> has
> the
> DTXpress
> to
> > > > But if
> own
> inexpensive
> > it)
> > question.
> > could
> > into a
> > needs
> from
> > an
> that
> > it
> computer...
> > just
> > what he
> Hazarding
> > Ed
> Thanks again!
> D.
> ADVERTISEMENT
> click here
> <http://rd.yahoo.com/SIG=12cav4hhq/M=267637.4116730.5333196.1261774/D=egro
> upweb/S=1705031972:HM/EXP=1070744081/A=1853618/R=0/*http://www.netflix.com
> /Default?mqso=60178338&partid=4116730>
> <http://us.adserver.yahoo.com/l?M=267637.4116730.5333196.1261774/D=egroupm
> ail/S=:HM/A=1853618/rand=176554961>
>    <http://groups.yahoo.com/group/DTXpress>
>    <http://www.dtxpressions.com>
> ________________________________________________________________________
> This email has been scanned for all viruses by the MessageLabs Email
> Security System. For more information on a proactive email security
> service working around the clock, around the globe, visit
> <http://www.messagelabs.com>
The information transmitted herewith is sensitive information intended only
for use to the individual or entity to which it is addressed. If the reader
of this message is not the intended recipient, you are hereby notified that
any review, retransmission, dissemination, distribution, copying or other
use of, or taking of any action in reliance upon, this information is
strictly prohibited. If you have received this communication in error,
please contact the sender and delete the material from your computer.
Ok...?
I didn't need this info, but thanx... it was D. who had the problem..
gord
rdamon@... wrote:
> Gord,
> module 2.
> mixer,
> modules
> OGD
> > > > D. and Gord,
> > way
> > > to
> > wrong
> > > at
> > > slave
> > > would
> > > depending
> > > Gord.
> > has
> > the
> > DTXpress
> > to
> > > > > But if
> > own
> > inexpensive
> > > it)
> > > question.
> > > could
> > > into a
> > > needs
> > from
> > > an
> > that
> > > it
> > computer...
> > > just
> > > what he
> > Hazarding
> > > Ed
> > Thanks again!
> > D.
> > ADVERTISEMENT
> > click here
> only
> reader
> that
> ADVERTISEMENT
> <http://rd.yahoo.com/SIG=12clm2d90/M=267637.4116732.5333197.1261774/D=egroupweb/S=1705031972:HM/EXP=1070745104/A=1853618/R=0/*http://www.netflix.com/Default?mqso=60178338&partid=4116732>
My apoligies, that was a OOPs on my part.
Gord's post are still moderated, which mean they get emailed to me (or
Ed/Vern) for prior approval before they are posted to the group.
So when his reply to your post was sent to me for approval, I ended up
making a direct reply to you, instead of to the group (first time it's ever
happened!) . I caught what I did after I hit the "send" button.
I corrected this by waiting for his post to show up at dtxpress and
responsed to that with the same messege that was accidentally sent to you.
Again, sorry for sending it to you directly.
OGD
> From:	distortion@... [SMTP:distortion@...]
> Sent:	Friday, December 05, 2003 4:11 PM
> Subject:	Re: [DTXpress] Re: How to for newbie
> Ok...?
> gord
> rdamon@... <mailto:rdamon@...> wrote:
> Gord,
> 2.
> mixer,
> modules
> OGD
> > From:       webc1958 [ SMTP:delcamroy@...
> <mailto:SMTP:delcamroy@...>]
> > To:       DTXpress@yahoogroups.com <mailto:DTXpress@yahoogroups.com>
> > --- In DTXpress@yahoogroups.com <mailto:DTXpress@yahoogroups.com>, "emf"
> > > > D. and Gord,
> > way
> > > to
> > wrong
> > > at
> > > slave
> > > would
> > > depending
> > > Gord.
> > has
> > the
> > DTXpress
> > to
> > > > > But if
> > own
> > inexpensive
> > > it)
> > > question.
> > > could
> > > into a
> > > needs
> > from
> > > an
> > that
> > > it
> > computer...
> > > just
> > > what he
> > Hazarding
> > > Ed
> > Thanks again!
> > D.
> > ADVERTISEMENT
> > click here
> <http://www.netflix.com>
> <mailto:DTXpress-subscribe@yahoogroups.com>
> <mailto:DTXpress-unsubscribe@yahoogroups.com>
> <mailto:DTXpress-owner@yahoogroups.com>
> >     < <http://groups.yahoo.com/group/DTXpress>>
> >     < <http://www.dtxpressions.com>>
> > < <http://docs.yahoo.com/info/terms/>>.
> > < <http://www.messagelabs.com>>
> only
> reader
> that
> ADVERTISEMENT
> click here
> <http://rd.yahoo.com/SIG=12c13ftci/M=267637.4116730.5333196.1261774/D=egro
> upweb/S=1705031972:HM/EXP=1070746457/A=1853618/R=0/*http://www.netflix.com
> ail/S=:HM/A=1853618/rand=180775688>
2003-12-05 by oldguydrummer
It has been a really long week I meant to say D's post are moderated.
OGD
(or
up
it's ever
to you.
> OGD
> > From:	distortion@r... [SMTP:distortion@r...]
> > Ok...?
problem..
> > gord
> > rdamon@m... <mailto:rdamon@m...> wrote:
> > Gord,
modules, I
purpose of
decrement from a
to module
> > 2.
kit 60 to
modules
of the
of the
> > mixer,
three
> > modules
for that
point it
remember
> > OGD
> > > From:       webc1958 [ SMTP:delcamroy@s...
> > <mailto:SMTP:delcamroy@s...>]
> > > > > D. and Gord,
only
> > > way
> > > > to
MIDI.
well, . . .
> > > wrong
> > > > at
device, like
from the
> > > > slave
module.
yourself...    This
> > > > would
out,
> > > > depending
> > > > Gord.
device-
which
> > > has
DTXpress
for
> > > the
> > > DTXpress
such a
fail to
only way
> > > to
> > > > > > But if
with its
> > > own
> > > inexpensive
I say
> > > > it)
> > > > question.
wants
> > > > could
to dive
> > > > into a
always
> > > > needs
system
> > > from
> > > > an
complained
> > > that
> > > > it
> > > computer...
> > > > just
never
got
> > > > what he
being
seen
> > > Hazarding
nothing is
do all
> > > > Ed
kits,
other
2)... I
would
via
know
> > > Thanks again!
> > > D.
> > > ADVERTISEMENT
> > > click here
egro
Service
__
Email
security
__
intended
> > only
> > reader
notified
> > that
or other
information is
error,
computer.
__
Email
security
__
Service
> > ADVERTISEMENT
> > click here
egro
.com
Service
__
Email
security
__
intended only
the reader
notified that
other
is
error,
computer.
__
__
2003-12-08 by Creighton Higgins
"Krampusnacht"?
The Christmas demon? You got me on this....
Help this American by cluing me in on this bit of lore. Bitte
Creighton
From: distortion@... [mailto:distortion@rogers.com]
Sent: Friday, December 05, 2003 3:45 PM
Gord.
The fact that he ALREADY had a second DTX module at his disposal I guess was missed by you. If he has one already, it makes no sense to go out and buy another trigger device, as you were suggesting. Plus the added polyphony... mmmmm polyphony...
You said "...thinks that the only way to add a second module to a kit for more inputs is through MIDI. Actually, this method is redundant at best and, well, . . . wrong" Then you went on to describe hooking up an external trigger converter TROUGH MIDI. How else can you add inputs? That is the contradiction. And again, he has got two DTX boxes, so why bother with another one he would have to accquire?
I'm not sure I get what you mean by limited note numbers. Mine sends every one from #0 to #127, and is held individually with each kit and layer. What more do you want. Now I must admit that I have a DTXpress, not the mkII so, I could be wrong about this same implimentation on the mkII, but I should hope they didn't dumb it down... Don't forget that in my system, the DTX is/can control everything in my system, and can be controlled by the sequencers too.. no problems here...
The inverse is also true.. you may confuse D. by giving premature advice without fully understanding what D. wants to do is an un-informed guess. Kind of like the advice you gave to LINKITOUT, you did not understand what he wanted and thus gave an incorrect remedy, and like what I did with CJA300 and mesh heads, I misunderstood and gave bad advice. A lot of incorrect advice is worse than no advice at all. Not saying you were wrong this time.. ok? :-) We are all guilty once and a while!
Love ya all!
gord.
; http://www.dtxpressions.com
