--- In DTXpress@yahoogroups.com, "slushycow" <slushycow@y...> wrote:
> Hi Again,
> I was wondering if it's a bad idea to mix different brands. For
> example; I found a cool Roland snare here in Japan. It's bigger
than
> the Yamaha pads and it comes with a stand.
> BTW I haven't been able to find it on the net. IS Roland a Japanese
> company?
Hi Jon,
Mixing brands is a wonderful idea--when it works, and it usually
does. But Yamaha modules are the toughest match in captivity for
alternative-brand components. Roland pads are generally okay with the
Yamaha module, but trying before buying is recommended, unless people
at this forum, or others, can endorse the product in question. I
assume that your Roland is a mesh head. Most likely you can find a
pad type in the trigger menu for it (maybe DT10/20).
Ed
