grain reduction
grain reduction
2011-08-27 by sjef.janssen
I use my Nikon Coolscan 5000 to scan my fomapan 100 film to dng files. Now, a 100 iso film should have very fine grain but the scans are very grainy. I use Vuescan on a win 7 machine. I tried the grain reduction but to minor results. Another scanner? Different scanning software (silverfast?). Nikonscan is not running on win7 64 bit so that's out of the question. Is there another solution?
Re: [Digital BW] grain reduction
2011-08-27 by Lew Schwartz
I'm using a 5000 to Vuescan FP+ developed in XTol 1:3. The scans at 4000 dpi
are terrific imo, no grain reduction necessary. What's your complete setup?
2011-08-27 by Tina Manley
I like Silverfast software by Lasersoft.  I get great B&W scans and they
have targets for Kodachrome which give me better results than I've gotten
with anything.  It's expensive, but in this case, you get what you pay for.
Tina
Tina Manley, ASMP
www.tinamanley.com
RE: [Digital BW] grain reduction
2011-08-28 by E.Neilsen
YEs, Nikon scan does run on Win 7 64 bit. the answer has been posted here, I
posted it on my forum, and if you Google it, I am sure it will pop up. I
installed it NO problem. What developer on your 100 iso film?
Eric Neilsen
Eric Neilsen Photography
4101 Commerce Street, Suite 9
Dallas, TX 75226
www.ericneilsenphotography.com
skype me with ejprinter
www.ericneilsenphotography.com/forum1
Let's Talk Photography
  _____
sjef.janssen
Sent: Saturday, August 27, 2011 10:01 AM
Subject: [Digital BW] grain reduction
2011-08-28 by Tony Sleep
This is very likely grain aliasing, as discussed here recently - an
aliasing effect that arises in the interaction between grain and scanning
frequency. Nikon scanners with LED lightsources have always been
particularly prone as the illuminant is semi-collimated. Diffuse sources
mitigate the issue.
A different dev and/or film, or a different scanner, are the only real
solutions.
Tony Sleep
http://tonysleep.co.uk
2011-08-28 by sjef.janssen
I develop in diafine using fomapan 100 at iso 100.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "E.Neilsen" <e.neilsen2@...> wrote:
> Eric Neilsen
> Dallas, TX 75226
>   _____
> sjef.janssen
Re: grain reduction
2011-08-28 by wrkrparasite
I'm brand new here, but I thought I'd chime in my two cents.
I personally find Fomapan 100 to be on the grainier end of the 100 ISO  spectrum. It's up there with Adox CHS/Efke.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "sjef.janssen" <sjef@...> wrote:
Re: grain reduction
2011-08-29 by Michael-K
I question whether it is a cause of the software used. I'm inclined to look at hardware issue as Tony suggested. I've also found that I can reboot my entire system, i.e., scanner and computer, and get a slightly different scan. You might also try reversing the film from it's normal scanning orientation; one may never know for sure what works until you try even the implausible ideas.
2011-08-29 by sjef.janssen
Thanks for your reply, Eric. I googled and tried to look at your forum but for your forum I should log in. Maybe you can point me at the thread on this forum where the procedure of installing Nikon scan om Win 7 is described.
Thanks!!
> Eric Neilsen
> Dallas, TX 75226
>   _____
> sjef.janssen
2011-08-29 by E.Neilsen
Sorry, I have been getting spam attacks on my forum and switched to a
password to even get on. 10 bogus requests from spammers from all over the
world every day got to me. I am in the process of redirecting to a new page
to request one.  Email me directly for a pass word.
I will be quite business once my day starts rolling. I haven't used that
film dev combo, so I am sorry I can speak to grain specifically from it. My
first thought would be to try another film  strip from your archive to judge
against to make sure the scanners not all mucked up. Of course , it's not
the best solution because specific patterns is what's the problem : (
Eric Neilsen
Dallas, TX 75226
(request a password)
  _____
sjef.janssen
Sent: Monday, August 29, 2011 7:20 AM
Subject: Re: [Digital BW] grain reduction
Thanks!!
<mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com> , "E.Neilsen"
I
> Eric Neilsen
> Dallas, TX 75226
> _____
<mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com> ] On Behalf Of
> sjef.janssen
Now,
I
Re: grain reduction
2011-08-29 by Eric
I assume you're scanning in RGB otherwise it will be grainy.  Also, check what the sharpening level is set at as that increases the appearance of grain as well.
Once in pshop, pick the channel that looks the best (R, G or B) and delete the rest.
Eric
