1290 (=1280) as replacement for 1160
2002-11-09 by Bernie Ess
Hello everybody,
I am currently printing on an 1160 with MIS FSN, mostly on EAM and
Photorag. I am considering getting an 1190 as replacement or to use
it parallel to the 1160.
1. Would the 1290 give me finer results with FSN as the 1160.
2. Will I get better results in Sepia toned prints when using the
1290 and archival colour inks like the MIS Perpetuals (= Sepia
printed with colour inks) than with a VM Sepia set on a 1160?
I have tried out the VM inks on the 1160 before, but was not too
happy neither with the blueish nor with the warm tone.
Thanks for replies,
Bernhard from cold and rainy Berlin
Re: 1290 (=1280) as replacement for 1160
2002-11-11 by Jeff Randall
Bernie:
What work flow are you using on your 1160 -- PiezoBW, Woolf,
Randall, ???.
If you intend to use either of the Epson workflows with your 1290,
you will need to get the FS-E hex inksets where the Pc and Pm inks
are 3:1 dilutions of the C and M inks, respectively while the regular
FS hex inkset for the PiezoBW workflow has only 4 ink shades C=Pc and
M=Pm.
You will need to call MIS to see if they have the FSN-E hex inkset.
If you intend to use the PiezoBW workflow with your 1290, then you
probably shouldn't have problems.
Quality is arguably similar between 1160 and 1290, but your milage
may vary.
Jeff Randall
--- In DigitalBlackandWhiteThePrint@y..., "Bernie Ess"
<albatros.bee@w...> wrote:
> Hello everybody,
> Thanks for replies,
