Further Adventures w/7600+ImagePrint: B&W Problem
2003-02-20 by Mitch Alland
In the last report on my experiences with ImagePrint 5 and the 7600, I
dealt with color printing with Photo Black on Epson Premium Semi-Matte
and stated that I was very happy with the results, concluding that I
found the IP profiles slightly more accurate than Bill Atkinson's,
particularly in the shadow detail. Since then, I recommended IP to
several people.
Now, I have started trying to print B&W and have run into a brick wall
when trying to print "legacy" files, that is, old files that I
previously printed using PiezographyBW on the 1160: I have not been
able to get decent prints with IP to match the old Piezo prints. The
problem is that, when I place these legacy files in ImagePrint, the IP
Preview is "washed out," with lower contrast and higher brightness than
the view of the legacy file in Photoshop; and the new IP prints are
also washed out and not at all like the Piezo prints.  I've seen some
postings that other people are having the same problem.
The trouble is that whatever I try to do -- and I've tried all the
combinations that I can think of, including saving the
(Piezography-type) Custom Dot Gain as an ICC profile and opening the
file in IP with this profile; converting the profile in PS from Custom
Dot Gain to Gamma 1.8 or 2.2; assigning profiles, etc.  -- the Preview
in IP, and the IP print, are still washed out, always having much less
contrast and much more brightness than the Piezo print. Yet I suppose
that there must be a way of getting the legacy file to print the same
way they did with Piezography. Does anyone have a solution?
I've posed this question to Colorbyte last week but have not had a
response and now, out of desperation, I also sent a message asking Jon
Cone. Meanwhile, I'm stuck.
--Mitch/Bangkok
Re: Further Adventures w/7600+ImagePrint: B&W Problem
2003-02-20 by jim hayes <jimhayes@frii.com>
I have been having luck either assigning (not converting) gamma 2.2 to
file, OR dropping the profile in IP5- while making sure it's default
greyspace is set to gamma 2.2
I have no idea why this works. In some cases a few values are a little
off, but I've been pleased with the output even when this happened. I
had to give up and do a levels adjustment to one image and comb it a
tad. Printed a modest number of old files so far.
And it DOES look washed out in IP5 window. I just ignore this. Always.
I just let it use gamma 2.2 and well, I get good prints that
way<shrug>.
Windows2000 SP3, 2200, photorag, Eclipse Satine, 1440 and 2880 dpi.
From legacy files using custom dotgains and dotgain % values.
JIm H.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Mitch Alland
I
Semi-Matte
> several people.
wall
IP
than
some
Custom
Preview
less
suppose
same
Jon
> --Mitch/Bangkok
2003-02-20 by cschaible94111 <cschaible@cooley.com>
Mitch:
I realize this may not be the kind of helpful response you were
hoping for, but why would you expect to be able to print legacy files
without adjustment, given that you are printing with both different
ink and different software on a different printer?
I've recently had a similar experience.  When Cone first started
selling Warm Neutral Piezotones in carts for the 1280, there was a
problem with one of the grays resulting in lighter-than-expected
midtones.  I printed with those carts anyway, and liked the prints.
Recently, hearing that the earlier problem had been fixed, I bought
some WN PT carts and attempted to print those same files.  Not
surprisingly, in order to match the earlier prints, I had to adjust
those files to compensate for the "different" ink.
Anyway, the differences that you are dealing with are far greater,
and I expect you will simply have to create new master files tagged
for the 7600.  One positive side effect may be that you will like
your new files even better than the old, having had months or years
in which to reflect on the qualities you really wanted in those
prints.
Or not.
Good luck!
Chuck
7600, I
Matte
I
> several people.
wall
The
IP
than
some
Custom
Preview
less
suppose
same
Jon
> --Mitch/Bangkok
Re: [Digital BW] Re: Further Adventures w/7600+ImagePrint: B&W Problem
2003-02-20 by Robert Morrison
This brings to light a serious deficiency in the old PiezoBW workflow...it
wasn't really color managed...meaning...you couldn't simply edit in a
standard "color" space (Gamma 1.8 or 2.2) and expect to get screen to print
match.  What this really reflects is that the profiles were bad and required
further tweaking via custom dot curves to actually match the screen.  Of
course this was always passed off as being individual differences in
printers...which may be true to an extent...but it certainly doesn't appear
to be a major problem with the Imageprint workflows that I've
tried...profiles made from other people's targets are usually right on the
money on my printer.
As a result your older files will have to be redone now that you have moved
to a color managed workflow.  Of course, if you have the original files from
either your scanner or digital camera then these are probably tagged with
either 1.8 or 2.2 (or their equivalent in the color world, e.g., colormatch,
sRGB or Adoble 98, etc) and you can work from there.
Robert
On 2/20/03 9:43 AM, "cschaible94111 <cschaible@...>"
<cschaible@...> wrote:
> Mitch:
> prints.
> Or not.
> Good luck!
> Chuck
> 7600, I
> Matte
> I
>> several people.
> wall
> The
> IP
> than
> some
> the
> Custom
> Preview
> less
> suppose
> same
> Jon
>> --Mitch/Bangkok
> Please visit the Group Homepage to check the Files, Bookmarks, Polls and other
> resources as they are often being updated. The page is at:
> page.
> them short.
> &amp;amp;quot;flames.&amp;amp;quot;
> resources on the homepage.
For: Jim Hayes
> file,
Thanks. I tried assigning Gamma 2.2 and it works! Very close to the
original PiezoBW print.
Do you mean saving the file w/o a profile and then placing in IP while
the default grayspace is set to Gamma 2.2?
Now, what do you do for new files that you've just prepared in PS? How
do you make sure the PS view matches the print from IP5?
--Mitch/Bangkok
Chuck:
I guess you're right; after all, I am using "printer targeting"
adjustments to print legacy files that I used to print on the 1290.
However, Jim Hayes' suggestion of assigning a Gamma of 2.2 to the files
that had a Custom Dot Gain works.
For new files, what do you do to get the view in Photoshop to match the
IP5 B&W print?
--Mitch/Bangkok
I had some interesting responses on the DigitalBlackandWhiteThePrint
list to my question of how to get "legacy" PiezographyBW files to print
correctly in IP5, parts of which I will quote below. First on the
nature of the issue:
> ...why would you expect to be able to print legacy files
and:
> workflow...it
> print
> required
I think that both these posting are essentially correct. After all, for
color, I'm using "printer targeting" adjustments to print 1290 legacy
files on the 7600 with IP5. But there was also a solution posted:
> greyspace is set to gamma 2.2.
This was in line with a (gracious) response I got from Jon Cone:
> Well I would take the file without a profile attached, or ignored the
> profile. That's #1.  Then I would use one of the ColorByte Gamma
> profiles
> for lightness/darkness adjustment. Then print through the inks/paper
> profile
> in ImagePrint.
I tried assigning both 1.8 and 2.2 gammas to the PiezoBW legacy files
and found that the Gamma 2.2 assignment resulted with a print that was
very close to the Piezo print.
Now that the problem of printing PiezoBW legacy files is solved, I am
moving on to printing new B&W files prepared for IP5. The issue here is
that the unlike their color profiles, the ColorByte grayscale profiles
canned be "previewed"
in the Photoshop "Proof Setup" facility. How are you dealing with this?
Or is the normal PS view very close to how the print looks?
--Mitch/Bangkok
2003-02-21 by jim hayes <jimhayes@frii.com>
<malland@x> wrote:
> For: Jim Hayes
2.2 to
> > file,
Weird huh? I've learned not to question why anything works in the last
2 1/2 years...
I find that I have had to rarely make a minor adjustment, usually the
middle slider in levels on a minority of my prints.
while
No, I mean keep the saved file intact with the original embedded
custom dotgain tagged to it. Then yes, set the default greyscale space
in system tab to "gamma 2.2" in IP5 and either "prompt" or ignore for
what it does if the image has a profile coming into IP5 from Pshop.
Make sure that the custom dotgain is ignored (or "not used" if
prompted). IP5 will then use "gamma 2.2"....the profile in the system
tab. I least that's how it's supposed to work.
I suggest this second method in case you want to keep the old custom
dotgain associated with the file for record keeping. Once you assign
gamma 2.2 to everything, of course how will you know it's history,
unless you maybe add a note to the image (I like those yellow things)
with a history of it's prior embeded curve.
How
Here's what I do, see if it works for you-
After I figured out the above, I standardized on using gamma 2.2 for
my embeded and working space. I found it matched my particular
monitor/windows2000 very closly with the 2200/IP5/gamma 2.2 output
print. I got lucky.
BUT, if I found that I needed to have a custom dotgain curve to get
the print to match monitor I would go ahead and  print an image/ step
wedge with the gamma 2.2 in IP5. After drying sample I would compare
it to monitor and start generating a custom dotgain curve to match the
sample done in Imageprint/gamma 2.2. Then I would save the profile and
use it as default greyspace in pshop, and embed it into all my images.
BUT, importantly, I would ALWAYS ignore profile when opened in IP5 and
make sure that the system tab was always set to gamma 2.2. In this
way, you always get output in IP5's gamma 2.2 space for your original
sample and subsequent prints into the future. SInce this output
corresponds to your monitor now with the custom dotgain you worked up,
it will match.
In this event your third option might be to save the file not by
assigning gamma 2.2 to it, nor keeping your original dotgain embedded
curve, but choose instead to assign (not convert) your new to-be
used-in future custom dotgain curve to your old files as they come up
for printing one by one. You would be moderenizing them to view
properly on your current monitor, matched to IP5/gamma 2.2 output. Of
course you must ignore profile once in IP5 in favor of gamma 2.2.
Of course, keep your basic monitor calibrated (Photocal, Adobe gamma)
and keep updating the file in imageprint by copying the file over if
you use a CRT since they do drift over time.
This procedure is outlined by someone and written up as "softproofing
in greyscale" or some such, except that there gamma 1.8 is the space
of choice.
Jim H.
> --Mitch/Bangkok
Oh and P.S.: Don't worry about the IP5 preview ever matching pshop.
Just ignore it; you don't need it to match the print here anyway, just
in pshop where the tonal adjustment tools are.
Jim H.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "jim hayes
> <malland@x> wrote:
> > For: Jim Hayes
> 2.2 to
> > > file,
last
> 2 1/2 years...
> while
space
for
system
things)
> How
> print. I got lucky.
step
and
images.
and
original
up,
> it will match.
embedded
up
Of
gamma)
"softproofing
> of choice.
> Jim H.
> > --Mitch/Bangkok
2003-02-21 by cschaible94111 <cschaible@cooley.com>
Mitch:
I'm still using the Cone driver on a 1280. I've considered moving to
IP5 but find my existing setup still works pretty well.  One thing it
doesn't provide, however, is any direct correspondence between what I
see on the screen (Sony LCD) and what comes out of the printer.
However, by limiting my inks (Piezotone Selenium, mostly) and papers
(PhotoRag)I find I have a pretty good idea what the prints will look
like.  (More than I ever had in the darkroom, anyway.) I actually
think that, given the luminosity of screen images, it's asking too
much to expect a one-to-one correspondence between a black and white
image on screen and the print of that image.
Chuck
<malland@x> wrote:
> Chuck:
files
different
files
> IP5 B&W print?
> --Mitch/Bangkok
2003-02-22 by Mitch Alland
For: Robert Morrison
>  My main complaint is
> that the shadows in imageprint tend to be compressed...
I'm surprised. I guess I should ask, "compressed compared to what?"
because I find the shadow detail to be quite good, with gradation
similar to PiezographyBW, and, for color prints, the shadow detail is
much better than the that of the Epson driver with Bill Atkinson's
profiles.
--Mitch/Bangkok
Chuck: [cschaible94111 <cschaible@...>]
But why not? Why work "in the dark?" The PiezoBW documentation explains
how to create a "Custom Dot Gain" curve to make the monitor image match
the print -- and, as the PiezoBW documentation states, you don't even
need a (hardware) calibrated monitor for this.
My PiezoBW setup on the 1290, with the Custom Dot Gain set in Photoshop
Color Settings gave an excellent correspondence between the monitor
image and the print. Just have a look at the PiezoBW manual. This is
very easy to set up.
--Mitch/Bangkok
2003-02-23 by Mitch Alland
--Mitch/Bangkok
profiles.
--Mitch/Bangkok
2003-02-23 by Robert Morrison
Sorry not to respond earlier, Mitch.  The Imageprint profiles are less
compressed in the shadows than those that I've seen from the Epson
driver...but they are significantly compressed compared to the piezoBW
profiles.  For instance on a recent BW profile that colorbyte made for me
there is no measurable difference between the 95% and 100% patch in a
standard stepwedge...while I have no problem seeing the difference on a
piezobw stepwedge or on the screen.  I had this discussion repeatedly with
colorbyte and they are resistant to changing it.  I think this is because it
make the images look "washed out" when they use the correct curve for people
that don't know what they are doing with shadows.  Regardless, this is the
wrong policy...output needs to match a calibrated monitor and follow a
standard Ames curve. I've been using the new Ink Jet Control beta to make
profiles for both quads and my 2200 and the shadows are right on the money
with 1% separation throughout the shadows.
Robert
> profiles.
> --Mitch/Bangkok
> page.
> them short.
SV: [Digital BW] Ink Jet Control (Was Further Adventures w/7600+ImagePrint: B&WProblem)
2003-02-23 by Sören Lindqvist
*       I've been using the new Ink Jet Control beta to make
money
Robert,
Any news on Ink Jet Control software for Windows?
Is there any website with information about the software (have searched
but can’t find any)
Soren
-----Ursprungligt meddelande-----
Från: Robert Morrison [mailto:rmorrison@...]
Skickat: den 23 februari 2003 10:21
Till: DigitalBlackandWhiteThePrint@yahoogroups.com
Ämne: Re: [Digital BW] Re: Further Adventures w/7600+ImagePrint:
B&WProblem
Re: SV: [Digital BW] Ink Jet Control (Was Further Adventures w/7600+ImagePrint: B&WProblem)
> but can’t find any)
I don't think so...but contact ijc@... for more information.
The posts on IJC are under the thread called:
New software for mono printing
I just printed a photo with IJC for the 2200 and I'm getting spectacular
shadow detail that was completely absent in the Imageprint output.
Robert
SV: SV: [Digital BW] Ink Jet Control (Was Further Adventuresw/7600+ImagePrint: B&WProblem)
Robert,
Thanks I read that post also.  I searched and found this:
Sounds like this is the place ?
http://www.bowhaus.com/news/quad.htm
Soren
Skickat: den 23 februari 2003 11:31
Ämne: Re: SV: [Digital BW] Ink Jet Control (Was Further
searched
> but can’t find any)
Robert
Yahoo! Groups Sponsor
ADVERTISEMENT
<http://rd.yahoo.com/M=245454.2994396.4323964.2848452/D=egroupweb/S=1705
019182:HM/A=1457554/R=0/*http:/ipunda.com/clk/beibunmaisuiyuiwabei>
<http://us.adserver.yahoo.com/l?M=245454.2994396.4323964.2848452/D=egrou
pmail/S=:HM/A=1457554/rand=300539166>
same page.
keep them short.
header.
&amp;amp;amp;quot;flames.&amp;amp;quot;
Your use of Yahoo! Groups is subject to the Yahoo!
<http://docs.yahoo.com/info/terms/>  Terms of Service.
Re: SV: SV: [Digital BW] Ink Jet Control (Was Further Adventuresw/7600+ImagePrint: B&WProblem)
Yes.  But this doesn't tell you much about the software product, but I would
contact them for current information on the product.
Robert
On 2/23/03 2:35 AM, "Sören Lindqvist" <soren.lindqvist@...> wrote:
> Robert,
> Regards
> Soren
> searched
>> but can’t find any)
> Robert
> ADVERTISEMENT
> same page.
> keep them short.
> header.
> page.
> them short.
