Sent: Saturday, May 03, 2003 12:29 PM
Subject: Re: [Digital BW] New MIS black clogs
Paul,
After checking my supply, I am not sure what is in there. I ordered
new inks from MIS a few weeks ago, but now realize that the black I
put in was a few months old as I have both packages of the newer
black on the shelf. The new boxes are marked MIS QVM black. As the
older package was sealed, shelf life issues should not be a problem.
I wonder if there is an issue with this particular item. It took
three cleaning cycles to clear it this morning. Do you think it
would be worth installing one of the newer carts on the chance that
the one that is in there is defective? It is unlikely that the one
in the printer is the Eboni ink given its age.
So, I seem to have jumped to a conclusion based on others' comments
on the list that may not be justified. The problem may have nothing
to do with Eboni. It is strange though as I (knock wood) have not
had problems to this point.
I do remember the smell of the older inks when I installed them.
However I switched both black and the color carts at the same time,
so hard to tell what I smelled.
As always, thanks for your help.
Steve
<paul.roark@v...> wrote:
> Steve,
> Does the new black ink have the "solvent" smell of the old VM/FS
black? If
> not, then it could be the new Eboni ink. MIS is eager to get rid
of the old
> VM/FS ink due to its co-solvent base that is often said to cause
more
> clogging.
> I've been using Eboni for some time now with no problems, but some
have
> reported clogging issues. Some of the problems have been due to
faulty
> carts, others have related to the new ink's apparent sensitivity to
> pollution by residual dye ink. I have not seen enough reports to
know what
> other patterns of problems may exist. I'm about to load another
cart of
> Eboni now that is from a different/new batch of ink. Hopefully
there are
> not inconsistencies among ink batches.
> Paul
> http://www.PaulRoark.com
> _________________________________
> From: Stephen Kobrin [mailto:skobrin@h...]
> Sent: Saturday, May 03, 2003 7:59 AM
> Subject: [Digital BW] New MIS black clogs
> I have been printing with a 1200 and the MIS VM inks since early
> October without a problem. However, after putting in a new black
> cart (I use prefilled carts)I have consistent clogs in the black ink
> when I first turn on the printer. Up to now, they disappear with a
> one or two cleaning cycles, but I concerned that the problem is
going
> to get worse over time. Furthermore, cleaning uses ink.
> I recall some discussion of a new MIS black on the list which I did
> not follow as closely. Is MIS using the new black in all of its
> inksets? If so, this is a bummer. Is anyone else running into this
> problem? Again, the only change is a new cartridge.
> Would switching to the Gen 4 (?) black slove the problem? Any
advice
> appreciated. The only clog is in the black position -- the other
> nozzel tests are consistently perfect.
> Steve
> Please visit the Group Homepage to check the Files, Bookmarks,
Polls and
> other resources as they are often being updated. The page is at:
> If you wish to receive no emails or just a daily digest, or you
wish to
> unsubscribe, please edit your Membership preferences by visiting
this same
> page.
> - As threads develop, trim off excess portions of earlier messages
to keep
> them short.
> - As the topic of a thread changes remember to change the subject
header.
> &amp;quot;flames.&amp;quot;
> - Before posting a question, search the message archives and the
various
> resources on the homepage.
> Your use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/
Yahoo! Groups Sponsor
- Good manners are required at all time. No personal attacks or &amp;quot;flames.&amp;quot;
