Help with Epson Photo Stylus Ex
2003-05-12 by spsguru
I just received some quadtone inks from MIS - their variable
quadtones. They allow you to print cooler tones - and I have printed
the 21 step grayscale for testing they have on site. I cannot get
rid of the cool tone - moving the sliders in color management
(yellow or magenta) does not change anything, They do not have
curves available for this printer ....
Net - I am a complete newbie at using these inks - have tried to
follow their suggested workflows (for other printers, dont have EX)
and cannot get anywhere.
Any one can help?
Thank you
Sean
Re: Help with Epson Photo Stylus Ex
2003-05-13 by Tom
Howdy Sean,
I was in the same situation when I first started using the MIS VM set
with my 2000P. I ignored all the negative talk about my printer and
tried various curve sets until I found one that produced a nice clean
21 step test.
are you trying to print greyscale or rgb?
I am surprised reducing the magenta via the slider has no effect. I
know nothing about the EX (4 or 6 color?, dye or pigment inks?), but
would suggest seeing if there is a set of curves for a similar printer
and start there. For me, it was the set for the 1290.
hope this helps,
Tom De Carlo
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "spsguru"
> Any one can help?
> Thank you
> Sean
2003-05-13 by spsguru
Tom - thanks for the help. Photo Ex is a 6 ink - the numbers onthe
cartridges are the same as for the 700.
I am not sure what I am looking for in the curves.
i am printing rgb
I suppose teh objective is to print the 21 step - see if I have 21
steps in the print - if not - tweak the curves until I do - the
question is - which curve? Do i mess with the composite only or twek
the r or g or b?
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Tom "
<pouty_bob@y...> wrote:
> Howdy Sean,
set
clean
> 21 step test.
but
printer
> hope this helps,
> Tom De Carlo
printed
get
EX)
> > Any one can help?
> > Thank you
> > Sean
2003-05-14 by Tom
Ha!
my highly non-technical approach of going through each curve supplied
with the 1290 downloads came about precisely because I spent some time
trying to adjust a curve myself and had your exact questions..!
if others can answer this all nice and succinct for forum style
enjoyment, that would be nice...  but I suspect much time spent
messing with curves is the only way I'll learn about curves.
did you get yours from here?:
http://www.inksupply.com/index.cfm?source=html/workflow_roark.html
if so, which set did you pick?
or were you just starting from scratch!?!
yes, the goal is to print nice clean 5% steps (then move on to 1% ones!)
I created a smaller 21 step file to save my precious ink and fit about
8 to a page.
wish I had better advice!
good luck,
Tom
> i am printing rgb
> the r or g or b?
> > Howdy Sean,
> set
> clean
> > 21 step test.
> but
> printer
> > hope this helps,
> > Tom De Carlo
> printed
> get
> EX)
> > > Any one can help?
> > > Thank you
> > > Sean
2003-05-14 by spsguru
Thanks again Tom - you have given me enough to get started. Greatly
appreciate the time
Sean
> Ha!
supplied
time
ones!)
about
> 8 to a page.
> good luck,
> Tom
onthe
> > i am printing rgb
21
twek
> > the r or g or b?
> > > Howdy Sean,
VM
> > set
printer and
nice
> > clean
> > > 21 step test.
effect. I
inks?),
> > but
> > printer
> > > hope this helps,
> > > Tom De Carlo
> > printed
cannot
> > get
management
have
tried to
have
> > EX)
> > > > Any one can help?
> > > > Thank you
> > > > Sean
