freeing up Photoshop while printing
2003-11-11 by Bob Michaels
Is there any way to free up Photoshop by spooling a print? A typical
print taking about 7 1/2 minutes through the printer keeps Photoshop
busy for 7 minutes of that time. I can answer e-mail, surf the web or
anything BUT PS. I'd like to start tweaking the next print during that
time.
It can't take Photoshop that long to send the file to the printer. I
don't think it's the CPU,, memory or USB 2 hub because I can print
from another application to another printer (same hub) without slowing
things down. It's like Photoshop just won't spool off to a print
buffer for some reason.
PS 7.0, XP, 1.5 P4 w 1 gb of memory printing using an Epson 1280 via
USB 2 hub.
Ideas?
RE: [Digital BW] freeing up Photoshop while printing
2003-11-11 by Paul D. DeRocco
> From: Bob Michaels [mailto:bob@...]
> time.
Dunno about XP, but in Win2K there's a radio button in the Advanced tab of
the printer Properties dialog for that.
Re: freeing up Photoshop while printing
2003-11-11 by amateriat
Hmm..not sure about this in XP, although I'd find it hard to
believe there isn't an option available to get around this (then
again, I know someone who recently bought an older PC to set
up as a print server. He's running Win 2000 Pro). On the Mac you
can get right back to work in PS as soon as spooling is done,
provided Background Printing is enabled.
- Barrett
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Bob
typical
Photoshop
web or
that
> time.
print
slowing
1280 via
> USB 2 hub.
> Ideas?
Re: [Digital BW] freeing up Photoshop while printing
2003-11-11 by Bob Frost
Bob,
Have you set the Printer Properties to spool files? Or is it set to print
direct?
Bob Frost.
> time.
> USB 2 hub.
Yes I have print spooling enabled. But it certainly acts like it
doesn't spool at all. That's what baffles me. The once simple
unidirectional dumping a file off to a buffer (I even remember the 64K
hardware in line buffers for DOS) now gets so convoluted that I can't
figure out if it's Photoshop, the Epson print driver, the Epson status
monitor or what is waiting for some feedback from the printer before
it send more data from Photoshop.
I'm still stumped.
Bob Michaels
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Bob Frost"
<bobfrost@b...> wrote:
> Bob,
print
> direct?
> Bob Frost.
> From: "Bob Michaels" <bob@b...>
> > time.
> > USB 2 hub.
2003-11-12 by Paul D. DeRocco
How much disk space do you have? It may fall back to not spooling if you're
running low. You might also see if you can figure out where it dumps spool
files (I expect somewhere under c:\windows\system32\spool) and make sure
nothing is interfering with this, such as a folder incorrectly marked
read-only, etc.
2003-11-12 by Bob Michaels
Paul, thanks. C:/windows/system32/spool/printers WAS set to read only.
Now I certainly have no idea how it got that way.
These new operating systems are getting to complex for me. I was
beginning to understand DOS and Microsoft has been putting me farther
and farther behind for the last ten years.
Bob Michaels
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Paul D. DeRocco"
<pderocco@i...> wrote:
> > From: Bob Michaels [mailto:bob@b...]
you're
spool
> read-only, etc.
> Paul                mailto:pderocco@i...
RE: [Digital BW] Re: freeing up Photoshop while printing
I have no idea either. In fact, I have no idea how I knew that. ;-)
2003-11-12 by Bob Frost
Bob,
I have a faint recollection of someone else with a similar problem that I
think was solved by unchecking Advanced Printing in Printer
Properties/Advanced. Might be worth a try!
Bob Frost.
> I'm still stumped.
2003-11-12 by flyfishingusa2002
I have to same problem and I ended up with a Mac, no such problem
with OSX. I am going to try a Linux based machine as a print server.
Barry
only.
