Ok, I got the printer working after doing what Epson Tech Support told me to
do...that is go through 10 nozzle cleaning cycles with the Epson color carts.
I have reinstalled the MIS VM carts and am using Somerset Photo Enhanced
Velvet. I tried printing a file out of PhotoShop (toned it, converted to grayscale,
applied Roark curve for neutral and converted back to RGB). The image looks
awful. After I applied the Roark curve, it lost a lot of shadow and highlight
detail and became very contrasty.
What am I doing wrong? The image looks better w/o the Roark curves, but
exhibits some posterization/metamerism-look on the Somerset.
Should I use the ICC profiles off the Legion paper site?
Thank you in advance for any help.
JB
-- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Joel Beeson" <
bluzdoctor@y...> wrote:
> Hi All:
> Yes, it appears the nozzles are piercing the rubber/plastic seals as there is
> some ink leaking out...
> I don't know if it is still on the warranty; trouble is I bought it and it has been
> sitting in the box as we moved across country and then I started teaching, so
> this is the first time I opened the box.
> But I will try to convince Epson.
> I will let you know what happens. I appreciate the helpful advice.
> Best,
> Joel
> --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Martin Wesley" <
> mwesley250@e...> wrote:
> > * -----Original Message-----
> > * From: Joel Beeson [mailto:bluzdoctor@y...]
> > * Sent: Wednesday, November 26, 2003 3:40 PM
> > * To: DigitalBlackandWhiteThePrint@yahoogroups.com
> > * Subject: Re: [Digital BW] I'm on a deadline...Epson 1280
> > * doesn't print...help!
> > * How do I clean out the color ink when I do switch back to the hextone
> > * cartridges?
> > Joel,
> > The MIS-VM and Epson inks are compatible and the Epson carts make
> good
> > cleaning carts for this system.
> > Since you are not getting anything out of the Epson carts (and if the outlet
> > seals are getting properly broken as Eileen mentioned) then you may
need
> to
> > deal with Epson customer support. If nothing is coming through on any
> > channel or nozzle it if probably an electronic problem.
> > If you are still within the one year warranty and if you call they will ship
> > you a refurbished printer and you send the defective one back in the box
> > new one came in. I did this once and the new printer arrived within 24
> > hours. With the holiday you probably wouldn't get it until Monday or
> Tuesday
> > but nothing to lose by calling them now and starting the process.
> > These things always seem to happen when you have a deadline. When
> mine went
> > I wound up going to the nearest CompUSA and paying full list for another
> > one.
> > Keep up posted on how it turns out.
> > Martin
