black only
black only
2003-11-30 by jerdiakiw
really finding  Clayton's articles useful. ( Although I notice it
says revised  nov 2003 but still hase 2002 dates in article and
talks about using a 1280 not a 2200) -I wonder if clayton or anyone
else can comment on the difference between this apporach on
lunimous landscape  and clayton's approach.
  http://www.luminous-landscape.com/reviews/printers/2200-bw.shtml
Re: [Digital BW] black only
2003-11-30 by Carl Schofield
I suggested this method of using the Epson driver to print B&W on the
2200 when I first started using the printer.  Using the
"Photorealistic" driver setting does improve shadow detail and avoids
the non-linearity problem when using the driver in NCA mode with
profiles, but the major problem with this method is metamerism.  The
latter problem is a result of using all of the color inks (in large
amounts) to generate a neutral gray scale.  A good RIP (QTR, IJC/OPM,
ImagePrint) will do a much better job of controlling the specific inks
used and the amounts needed for a neutral (or toned) B&W print without
metamerism.
Carl Schofield
Re: black only
2003-11-30 by Clayton Jones
Hello Jerry,
I found in article #4 I missed changing the copyright date, got it
now, thanks for the sharp eyes.
>and talks about using a 1280 not a 2200)
Not sure what you mean by this.  The only place I mention a 1280 is in
the recommendations section of #3:
 "I recommend getting either the 1280 model or the 2200."
All of the detailed settings are for the 2200 in the "How To Do It"
section:
 "Here are the settings I use for Black-Only Printing with the 2200"
I don't think I mentioned the 1280 anywhere else.
Clayton
Re: black only clayton, wrong link
I just could;t get to the page you are mentioning  by clicking the
link in your messages On my comouter when I click your link at the
bottom of this message I get the older version with no ref to 2200
but got it another way thnaks  you may want to update this link
below
<cj@c...> wrote:
> Hello Jerry,
is in
> section:
2200"
> Regards,
> Clayton
Hello Jerry,
>On my comouter when I click your link at the bottom of this
I think your browser has cached the older page.  Just refresh your
browser and it should be ok.
Clayton
Re: black only (and 1280 vs. 2200)
2003-11-30 by Barrett Benton
Just in case this hasn't been brought up before: when
comparing output between the Epson 1280 and 2200 (whether
for color, quad/septone or b-o black-and-white), remember that
that the 1280 "best" output is 2880 x 720 dpi, while the 2200's is
2880 x 1440dpi.
I only mention this because, as near as I can tell, just about
everyone here has been mentioning "2880" in reference to both
printers, without mentioning "that other number".
- Barrett
>2880 x 1440dpi.
Good point, thanks.
Clayton
