Wow. What a firestorm. Even a claim of gratuitous "name dropping"!! hmph.
I will stand by the following facts (verified by me and others -- yes, my amigo Bruce
Frazer too -- many years ago):
1.) almost all high-end scanners today scan INTERNALLY at 10, 12 or 14-bits (only
the cheapest consumer scannersnow scan at 8 bits internally. Almost NO scanners
actually scan at 16 bits))
2.) assuming that the SCAN curve is optimal for the negarive in question (i.e. the
instructions to the scanner, including white point, black point, and shape of curve)
there will be ABSOLUTELY NO DIFFERENCE between an optimal "8 bit" scan and a raw
"16 bit" scan that has been manipulated to equal the "look" obtained by the above
optimized curve -- regardless of the number of bits.
It can best be diagrammed as such:
scanner (12bit) + optimal curve --> optimal file (8bit) --> printer (8bit)
scanner (12bit) --> expanded file (16bit) --> manipulate (16bit) --> optimal file
(any bit) --> printer (8bit)
All things being equal, the above two workflows will produce the EXACT SAME IMAGE
at the printer (i.e. there will no perceptible difference at all)...
...However, I *WILL* conceed the following scenario where manipulating in 16 bits has
a theoretical advantage (it is certainly not true for most B&W images):
- specifically, the case where one wants to push the image WAY BEYOND what an
optimal 8-bit scan would deliver, especially using algorithmic means (e.g. equalize,
extreme curves, etc,). An example of such extreme manipulation might be what
Ansel Adam would have needed to do with "Moonrise Over Hernandez" -- where he
burned the (light) sky practically black in his (anlaogue) enlarger. Were he to do the
same in Photoshop today in 8 bit, then yes, one MIGHT see enhanced noise and
posterization -- however, much of this "might" is determined by what you are
attempting to do and HOW you go about doing it. It is NOT TRUE AT ALL that if you
perform extreme manipulations in 8 bits, then you are destined for posterization and
enhanced noise. Again, it depends more on the user, not the technology. For
example, actual "manual" Photoshop burning and dodging in 8bits gives perfect
gradations, devoid of any banding. No advantage at all doing burning/dodging in
16bits
So the sum of this is this:
- if you are trying to obtain an optimal digitization of a negative using modern
scanning equipment, and your goal is to print this optimized image file as is, then
there is no advantage to capturing, storing, printing in 16 bits. In oher words, for the
vast majority of images (and users), 8 bits together with an optimal scan is more than
adequate, in spite of all the theorists arguments to the contrary
- however, if your goal is to manipulate -- to an extreme degree -- an image way
beyond its optimal "zone", then capturing and manipluating in 16 bit may have some
advantages.
- As others have noted, printing in 16 bits is a total waste.
Michael Sullivan
author of "Make Your Scanner a Great Design & Production Tool" published waaay
back in 1994, now out of print
P.S. assuming someone has unlimited memory & harddisk space then go ahead, scan
away at 16 bits -- at least there is no harm! However, my own experience with most
users is that they do in fact have limited memory and harddisk space. For these
people, I would instead recommend to them to learn how to do GREAT scans and save
the files in 8bit
P.P.S in my experience, a lot of the 16bit vs 8bit argument involves a perverse form of
bragging -- those with the horsepower (and latest tools) tend to brag about it. We've
all heard a version of this before: "my car can blow the doors off of your car" kind of
thing. Tedious. Boring. In the end, RESULTS is all that counts, not HOW you did it.
