Re: [Digital BW] 16 bit vs 8 bit difference, Re Glen Mitchell´s posting
2004-01-04 by Bob Frost
Anthony,
The Minolta 5400 and Nikon 5000 scanners claim to be 16-bit, and my graphics
card (Matrox P750) claims to be 10-bit.
Bob Frost.
>  No commonly available display or
> printing technology allows you to clearly distinguish more than 8 bits
> of tonality in the result.  No commonly available image capture system
> allows you to capture more than about 12-14 bits in the original image
> (with electronic cameras, the limitation is the image sensor; with film,
> the limitation is the scanner).
RE: [Digital BW] 16 bit vs 8 bit difference, Re Glen Mitchell´s posting
2004-01-04 by Austin Franklin
Hi Bob,
I know Nikon uses a 16 bit A/D, so that claim is true...but...they also
*claim* a density range of 4.8.  This density range claim just simply is not
true.  They are basing this *claim* on using a 16 A/D, not on any actual
results from the scanner.
What matters is how many bits of data are *usable*, and at best, they are
really only going to be able to get 14 usable bits.  You could put a 24 bit
A/D there...but it simply would not increase the density range capabilities
of the scanner.  What's more important than the A/D is the sensor, and the
analog front end...and if the sensor and analog front end can't provide a
low enough noise signal for the number of bits the A/D has, those "extra"
bits are simply unusable.
This has been a bone of contention in the digital imaging industry for some
time, and why the ISO has come up with a way of characterizing the actual
density range of a scanner using actual testing, instead of the
manufacturers erroneously using simply the bit width of their data path, or
of the A/D converter to make their density range claim.
Austin
> From: Bob Frost [mailto:bobfrost@...]
> Sent: Sunday, January 04, 2004 1:22 PM
> Subject: Re: [Digital BW] 16 bit vs 8 bit difference, Re Glen Mitchell\ufffds
> posting
> Anthony,
> my graphics
> Bob Frost.
> From: "Anthony G. Atkielski" <anthony@...>
> If you wish to receive no emails or just a daily digest, or you
> wish to unsubscribe, please edit your Membership preferences by
> visiting this same page.
> - As threads develop, trim off excess portions of earlier
> messages to keep them short.
> flames. Hostile, aggressive or argumentative users may be removed
> from the membership without notice.
> - Keep your posts and threads related to the group topic of
> digital B&W printing. Users who persistently make off-topic posts
> may be removed from the membership.
> - By posting on this forum you agree to abide by the group rules
> and guidelines, and to abide by the actions and decisions of the
> group Owner and Moderators. See \ufffdGroup Topic, Rules and
> Guidelines\ufffd in the Files section:
> BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW,
> THE PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT
> THE \ufffdOWNER\ufffd AND \ufffdMODERATORS\ufffd OF DIGITAL BW, THE PRINT YAHOO GROUP
> SHALL NOT BE LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL,
> SPECIAL, CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT
> LIMITED TO, DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR
> OTHER INTANGIBLE LOSSES (EVEN IF THE  \ufffdOWNER\ufffd AND \ufffdMODERATORS\ufffd OF
> DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE
> POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE
> INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii)
> UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR
> DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE
> DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER
> RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP.
> To visit your group on the web, go to:
> To unsubscribe from this group, send an email to:
>  DigitalBlackandWhiteThePrint-unsubscribe@yahoogroups.com
> Your use of Yahoo! Groups is subject to:
>  http://docs.yahoo.com/info/terms/
Re[2]: [Digital BW] 16 bit vs 8 bit difference, Re Glen Mitchell´s posting
2004-01-05 by Anthony G. Atkielski
Bob Frost writes:
> be 16-bit, and my graphics card (Matrox P750)
Graphics cards are largely digital devices so they can easily be any
number of bits; how good they are at actually generating 65,536
different voltage levels for each color channel on output is a different
matter.  No monitor can reliably display data with that kind of
resolution, anyway.
The same is true for a scanner.  It could be set up to provide 16 bits
of output, but whether those low-order bits are actually useful or not
is debatable.  Still, if a device isn't built to provide them, you're
guaranteed not to get them, whereas if it _is_ built to provide them,
you've at least got a chance of getting them (the hardware design
doesn't limit you, although the build quality might).
