Scanning Tri-X
Scanning Tri-X
2004-01-09 by sandersm@aol.com
Mark Hahn asked about scanning Tri-X.
Mark, I have used two consumer scanners that handled Tri-X well.   If you're
shooting 120 roll film, the Epson 2450/3170/3200 will do a good job, at least
if you put the filmstrip directly onto the glass, emulsion side down (to avoid
Newton rings).   It has a diffuse light source, that seems to yield pleasing
results when scanning b+w negatives.   Many have panned it as a tool for
scanning 35mm film, but as I scan 120 roll film and 4x5 sheets, I cannot speak to
that from experience.
If you are willing to spend the extra money, the Microtek 120tf film scanner
and its predecessor, the Polaroid 120 Sprintscan, both work really well with
Tri-X and other b+w emulsions.   Again, people who understand the machines
attribute their ability to handle b+w films to the nature of their light source.
I have an Epson 3200 as well as the Microtek, and each has its strengths, but
both handle Tri-X quite nicely.   I do not claim to be a pro, but if you
visit my photographs at www.mcnew.net, all of them are scans of film from one or
the other of these two machines (most of them with the Microtek), and most of
them are shot onto Tri-X, developed mostly in HC-110.
Sanders McNew
www.mcnew.net
Re: Scanning Tri-X
2004-01-09 by Don
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, sandersm@a...
If you're
at least
(to avoid
pleasing
for
cannot speak to
Sanders,
Do you really just lay the negatives down on the scanner?  Not in the
holder?  wowo.  How do you keep the negatives flat?  I would like to
try that on my 2450 but I didn't think it possible...
Don Karner
Re: Scanning Tri-X
2004-01-09 by sandersnyc
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Don" <elixirs4me@y...>
> Don Karner
It is!  But you need to be clever about it.
If you look at the holders, you will notice a notch that runs along the top.  When the
scanner sees the notch, it knows that the item being scanned is a transparency, not
reflective media, and configures itself for transparency scanning.  So you have to use
something to replicate the notch on the glass to make this work.
I do this several ways.  For scanning a frame of film, I took an 8x11 piece of matting
board -- really, any similar material will do -- and cut out a notch at the top, and cut
an opening the size of one film frame somewhere in the middle.  I then position the
negative to be scanned on the glass, lay the board on top so the right negative frame
appears in the cutout, close the lid and scan away.  You can cut the board so the
opening's edges overlap the film's rebates (edges), or else you can cut it wide enough
so that the rebates get scanned as well -- for an example of a full-frame scan, see
this image of mine:
http://www.pbase.com/image/20916529
http://www.pbase.com/image/20920361
I also use the Epson flatbed to do rough scans of whole strips at a time, as a
substitute for contact sheets.  I scan a strip at 600 dpi and that gives me plenty of
detail for deciding which images to print and which to pass over.  For this, I have a
thin strip of cardboard with the notch cut into it, that I position at the top of the
scanner glass.  Then I just lay the strip on the glass, close the lid and scan it.  The
strip won't be perfectly flat but even with moderate curl the scanner gives a good
image of the negative, good enough at least for proofing purposes.  If the curl is
excessive, I've been known to weigh the negative down with pennies at the edges --
not elegant, but it works.  Or, you can sleeve the negatives and scan through the
sleeves.  Again, the image is more than adequate for proofing/reviewing a strip.
Finally, I sometimes shoot Polaroid 55 b+w negative film in 4x5 sheets.  Polaroid 55
negatives are too big to fit in my Epson 4x5 film holder.  Again, I lay the negative
directly onto the glass, and lay the Epson holder down on top of it, just as I do with
the matting board on top of the 120 roll film negatives.  It works -- here are a couple
of examples:
http://www.pbase.com/image/24159622
http://www.pbase.com/image/21566869
I've found that, for my 3200 at least, Tri-X and other b+w films behave better this
way than in Epson's film holders.  If you do this, don't forget to flip the image in PS!
Sanders McNew
www.mcnew.net
Re: Scanning Tri-X
2004-01-09 by Mark Hahn
Thanks!
Yeah, with 120 or 4x5" you aren't enlarging as much and it is ok.  I
have a Epson 2450 and it is ok for 120, but quite good for 4x5".  I
found that mine does terrible on the glass, in fact I have to shim
the holder higher to get maximum sharpness out of the scanner (spent
more than an hour experimenting)... they don't hold very tight
tolerances on those machines I guess, but they are good for large
format negs IMO... I would pan it for 35mm as well though.
I've been using a Minolta Scan Dual II for a long time and that is
worthless for Tri-X, but even what I see from the highly regarded
4000ppi Nikon doesn't blow me away either...
Nice photos on your site!  ...but looking closely the grain still
doesn't look quite right to me... I think I am really picky:)
mark
If you're
job, at least
down (to avoid
pleasing
tool for
cannot speak to
film scanner
well with
machines
light source.
strengths, but
if you
film from one or
and most of
> Sanders McNew
> www.mcnew.net
Re: Scanning Tri-X
I have seen this too, but it more because they are slightly out of
focus and it blurs the grain a bit; then with post processing you can
sharpen the image without resolving the grain.  It is a well know
trick, but it isn't really what I am after.
mark
behave better this
Epson 2450 - negs on glass [was:Re: Scanning Tri-X]
here's and article showing why your probably *don't* want to lay your
negatives on the glass:
http://www.normankoren.com/Tutorials/Epson_flatbeds.html#Focus_spacing
(see Focus and Spacing)
This made a big difference in the quality I get out of the scanner.
mark
to
RE: [Digital BW] Re: Scanning Tri-X
2004-01-09 by Daniel Staver
Tri-X is one of my favorite films for grain, so I was surprised to read
that it's no good for scanning. I guess everybody's tastes are
different... I've tried numerous films, and I keep coming back to Tri-X.
I usually rate it at 800 to get more speed and grain. We have about five
hours of weak daylight here in Norway at the moment, so I need all the
speed I can get...
I scan on the Minolta 5400 and find that it can resolve the grain
nicely.
On the front page of my site images 2-4 and 8-9 are Tri-X rated at 800.
Of course, it's kind of hard to tell what the grain is like because of
the JPEG compression.
Daniel Staver
http://daniel.staver.no
2004-01-09 by Austin Franklin
> speed I can get...
> nicely.
> Daniel Staver
Hi Daniel,
For 35mm, if you like Tri-X, try Neopan 1600 developed in XTOL, 1:1 or even
1:3.  It's got very smooth tonality, and really quite reduced grain for that
speed.  I use Delta 3200 rated at 1600 for MF, same developer.
I do not like Tri-X in XTOL BTW...
Austin
> XTOL, 1:1 or even 1:3.  It's got very smooth tonality, and
> really quite reduced grain for that speed.  I use Delta 3200
It's funny you should recommend that now, since I've just gone through
ten rolls of Neopan 1600 after reading about it on the Photo.net forums.
I develop it in DD-X 1:4 and rate it at 640-1200. I think it's a little
contrasty at 1600.
The flowers on my homepage were shot handheld in the middle of the
night, with only a streetlight for lightning, and rated at 1600:
http://daniel.staver.no/content/view/full/2/offset/6/
This one is rated at 640:
http://daniel.staver.no/content/view/full/2/offset/0/
It's the finest grained high speed film I've tried, better than many 400
iso films even.
I still like Tri-X a lot though...
Daniel Staver
Re: [Digital BW] Re: Scanning Tri-X
2004-01-11 by Alan Zinn
>If you're
>at least
>(to avoid
>pleasing
>for
>cannot speak to
>Sanders,
>Don Karner
Don,
Have a look at this: http://www.panoramacamera.us/m_2450test.html  I use AN
glass.  I, agree, the Epson2400, 3200 with SilverFast have no problem with TX.
AZ
Build a Lookaround!
The Lookaround Book, 2nd ed.
NOW SHIPPING
>speed I can get...
>nicely.
>Daniel Staver
Daniel,
Part of the photographic art is exploiting the aesthetic nuances of the
equipment and materials. It blows my mind to hear of workers trying to
overcome TX grain, or now in the digital age, trying to create the "look"
of TX grain with digital cams.
Your web page and photographs are wonderful.
AZ
Build a Lookaround!
NOW SHIPPING
2004-01-12 by Don
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Alan Zinn
> >Don Karner
> Don,
use AN
problem with TX.
> AZ
Thanks Alan.  So let me get this right, the negative goes flat down on
the glass and the AN glass holds it down.  Correct?  thanks for all
your help. Can't wait to try this myself.  Do you do anything to trick
the scanner into knowing it is a transparency?
Don K.
2004-01-12 by Alan Zinn
> > >Don Karner
> > Don,
>use AN
>problem with TX.
> > AZ
>Don K.
Don,
I just toggle Negative and Transparency in the scanner program
(SilverFast). Put the glossy side of the film up. With a Gepe or similar AN
glass slide mount you can test the system with one piece of the glass held
down with tape.
AZ
Build a Lookaround!
NOW SHIPPING
2004-01-13 by Mark Hahn
for many of us "old-timers" (really, I'm not *that* old;) 35mm Tri-x
in D-67 just gave a "special" look that we came to love... then we
have drifted into the digital darkroom for one reason or another (for
me it was a severe aquired sensitivity to photochemicals).  If we
were currently using higher resolution scanners and printers there is
no reason that we can't reproduce Tri-X images by digital means, we
just need a high enough capture resolution to scan it off the film
and then print resolution to get it back out.  When you use a scanner
that has too low a resolution to actually capture the film grain you
do not end up with a "Tri-X photograph."  Each pixel is going to be
an average of a bunch of grain clumps and the resulting image will
have a look of "Tri-X being scanned at XXXppi," which may be
desirable to some people, but will not look like a traditional print
from Tri-X.  As I've said before, it isn't an issue for large
negatives becuase they don't have to be enlarged so much and you
can't see the effect so clearly, but for 35mm you definitely can.
Well, anyway... if I could still work in a darkroom I would be
shooting lots of 35mm Tri-X and if I could digitally scan and print
it to my satisfaction I would be shooting a lot of it as well...
mark
to
the "look"
2004-01-13 by Truman Prevatt
Hey, watch who you're calling an "old timer" ;-) I mostly do 4x5 now,
but it's all TriX.  I scan it with an Epson 2450 and find that the final
prints (1280) still maintain that TriX look we all fell in love with
when we so young and foolish. I tried the new modern stuff - TMax and
Delta but found something missing - I still craved for what I had seen
in my misspent youth - something only TriX could deliver. Now I have
that in the digital darkroom.
Truman
> mark
pixelization and banding...
2004-01-14 by Allan Chen
>I know this is a topic much discussed, esp. in the more distant past, but
>I wasn't able to find answers through a search without having to wade
>through a very large number of irrelevant posts.  Sorry.
I printed a photo yesterday using the UT (1) inks on EEM, and had rather
severe banding and what looks like pixelization.  The only thing I did kind
of weird to this file was that I reset the middle-gray point to get a more
neutral and contrasty print.  The original negative is Delta 3200 @ 3200,
and with all the base fog it's pretty muddy and low contrast.  Even after
tweaking the contrast I still wasn't happy with the whites, so I just did
the little "click to set grey" thing on a levels layer and ended up with
something that looked a lot better on screen.  However, the histogram is
rather ugly now - there are a lot of gaps.
Does a file like this, with a gap-filled histogram (sorry, not sure if
there's a better term), cause this blotchy output?
just wondering.  I'll mess around with settings tonight.
allan
Technology Projects Manager
Academic Computing and the Office of Accessible Education
Stanford University
voice - 650-996-0546
fax  -   650-725-4685
