Understanding dots and dots
2004-05-25 by mike_nunan
I'm mainly hoping Roy and Paul can shed some light on this, but if
anyone else wants to jump in, please feel free.  I've been looking at
Roy's very interesting scans of prints, posted in the thread "Dots
and More Dots". I must admit, I'm slightly surprised by the
differences. On my monitor, the images measure 4"x4", so that's a 16x
enlargement factor relative to the physical print. That means that
viewing the screen from 8ft away is like looking at the print itself
from 6", which is about as close as I can focus with my naked eye.
What I'm surprised by is the fact that there is such a difference in
visible dot between the 2200/UT7 print and the 1270/UT2+1160/VM
prints, especially against the UT2 prints as I thought the inkset
used a very similar set of grey tones to UT7. If anything, I would've
expected the 2200 print to be finer due to the smaller drop size, but
instead the reverse is true. The difference is clear at an effective
6in viewing distance and still noticeable at 8-12in, so this would
definitely be a concern to me in a real print. Any idea what gives?
TIA
-= mike =-
Re: Understanding dots and dots
2004-05-25 by Roy Harrington
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "mike_nunan"
> TIA
> -= mike =-
Hi Mike,
I was also a little surprised at that difference as well.  I think the
dotsizes of both printers is advertized as 4 picoliter so that
shouldn't be a factor.   I don't know if there's any difference in the
densities of the inks in the two sets.  Maybe Paul can address that.
That pretty much leaves the driver as the only signiicant
difference.  The 1270 print was done with QTR with curves I made.
The 2200 print was done using the Epson driver so its a little
hard to say what ink is used where.  My guess is that it uses one of
the darker inks (maybe the LK) at a lighter gray.
Roy
Hi Roy,
Maybe it is a driver issue between those two. Are you set up to do a
QTR UT print on the 2200? That would settle it I guess.
Also, what do you think it is about the 1160/VM combination that
makes it so smooth? VM only has black and three grey shades, same as
UT, right?
-= mike =-
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Roy Harrington"
if
looking at
thread "Dots
16x
that
itself
in
would've
but
effective
would
gives?
> > TIA
> > -= mike =-
> Hi Mike,
> Roy
Mike,
At the moment I just have UC inks in my 2200 so I can't tell you
what I'd get with different inks and QTR on the 2200.
I think the primary reason for the smooth 1160 is just simply that
it has a lighter gray than the UT7 or UT2 inkset.  The effect of a
lighter gray is beneficial in two ways.  First the dots are simply
lighter and even in a field of white they are less obvious. Second,
for a given shade on the paper, you will be using more dots and
therefore they fill in the spaces more.
I've looked at the scan a little more and it appears that there are
also a fair amount of the sepia ink dots -- yellow slot.  I think the
print was made with the "default" method where the Epson driver
mixes all the inks to produce what it thinks is neutral.  There's a
good possibility that using the PS curves it would be smoother.
Roy
> Hi Roy,
> UT, right?
> -= mike =-
> if
> looking at
> thread "Dots
> 16x
> that
> itself
> in
> would've
> but
> effective
> would
> gives?
> > > TIA
> > > -= mike =-
> > Hi Mike,
> the
> the
> > Roy
2004-05-26 by mike_nunan
Hello again Roy,
Ok, that makes sense. Just to clarify one point, in your last para
where you say the print could be smoother, are you referring to the
1160 print? If so, then "wow" would be my main comment to that!
TIA
-= mike =-
<roy@h...> wrote:
> Mike,
> Roy
> > Hi Roy,
do a
as
> > UT, right?
> > -= mike =-
Harrington"
> > <roy@h...> wrote:
> > > --- In
<snip>
> > > Hi Mike,
think
> > the
in
> > the
that.
made.
one of
> > > Roy
