> From: Susan Dennis [mailto:scprints@...]
> Sent: Sunday, May 30, 2004 8:54 PM
> Subject: RE: [Digital BW] Re: Digital Negatives
> Chris,
> My favorite way to print is to use 100% cotton content bond
> paper, like a Strathmore bond in 24# weight. You have to
> watch how much ink you are putting down but you get a very
> fine delicate print. It is more like a gravure. Like the ones
> that Edward Curtis made in the early part of this century on
> fine Japanese tissue paper and the vellums. They were all
> hand pulled and very fine. I have collected originals of his
> over the years.
> Printing with the Epson 3000 and the quad ink set comes the
> closest to those fine prints I have been able to produce. I
> differ in that I am using neutral tone inks B&W and not his
> red sepia tones. That color does not work for my material.
> Fine printing is just that, fine printing and there are many
> ways to achieve a desired result. The accepted pattern of
> workflow methods and materials is not the only way to achieve
> an artist goal. These cotton bonds do not have the chemical
> coatings of the offset sheets that make the blacks soft and
> gray in the shadow areas. Coated commercial printing papers
> do not work at all with inkjet inks. But there are a few
> commercial matte coated papers that do take the ink properly
> and come in a variety of weights. They are considerably
> cheaper and readily available through paper merchants. At the
> very least they are a good way to proof images with out
> wasting the expensive papers. If you are talking glossy
> finish, that is another ball game. Only papers made
> specifically for ink-jet printers will do.
> Charlie Dennis
> From: Chris Hargens [mailto:chargens@...]
> Sent: Sunday, May 30, 2004 7:10 PM
> Subject: [Digital BW] Re: Digital Negatives
> Thanks, Charlie, for all the information. I agree with all
> the points
> you've made as well as the theory behind them. As for the
> prints I've
> been making with various quadtone sets on matte paper so far, I'm
> reasonably happy with some and unhappy with others. I like the look
> of the Ultrachromes when printing BW, but I don't like the problem
> with metamerism (as well as the slight bronzing when printing on
> glossy papers).
> Chris Hargens
> --- In DigitalBlackandWhiteThePrint@yahoogroups.com,
> "Charlie Dennis"
> <scprints@b...> wrote:
> > Chris,
> > Just a few things you should consider when making your negs for
> prints in
> > the way that you want, on your printer.
> > Sorry these are so long.
> > 1. any problems that you have making ink prints on your printer
> will also
> > hold true for making a neg off the same device. It will be no
> better than
> > the prints you make. Anything that can and does happen to your
> prints will
> > happen to the negative plus the time you will spend in
> the darkroom
> finding
> > out if the negative is any good.
> > 2. Making a negative in a printer is an additive process to a
> substrate. It
> > is not an exposure process to a coated material and then
> applying a
> > subtractive process that is both chemical and physical.
> > 3. The image on the negative produced by the image setter is
> controlled by a
> > high end laser that is calibrated and tested every day
> for accuracy
> and
> > consistency
> > 4. The dots or random spot of the image setter can be
> much finer in
> its
> > resolution than anything that a printer will be capable of
> producing. The
> > spot it produces can be the equivalent of a 600 line per inch
> screen value.
> > That is a spot smaller than the size of the silver crystals in the
> film you
> > use in your camera.
> > 5. Control and consistency on the negative is a standard operating
> procedure
> > of the process when the image bureau creates a film that is
> readable with a
> > target chart and densiotometer.
> > 6. There will be no blocking of values at either end of the scale
> of the
> > image setter neg. It will have more information than your printing
> paper
> > will be able to record.
> > 7. You will be less at the mercy of inconsistent neg. because of
> density
> > problems and clogged heads of a print device with an image setter.
> > 8. If you inkjet prints are lacking in the snap that you
> want, then
> the
> > negative you create on it will more than likely lack something
> also. The
> > fact that you are printing to a silver print paper will not solve
> all that
> > you are looking for in the print. If the print is flat
> the negative
> will
> > also be flat produced in the same way.
> > I for one have never been a fan of any additive process. It has
> never proven
> > to be as consistent and accurate as a subtractive system in
> reproduction. In
> > the graphic arts industry, system after system of additive
> processes has
> > been dropped or revised always in favor of the easier to control
> subtractive
> > and exposure systems.
> > I am not saying the negative from a printer will not work or will
> not be
> > usable, but it will depend on the investment of your time and
> testing you
> > put into it. The shorter way will be the image setter if you are a
> > perfectionist for technical detail.
> > I would be pleased to see how your efforts turn out. If you have a
> > densitometer to read both reflective and transmission
> values of the
> print
> > and negatives you will make your life a lot easier when making
> adjustments
> > to your finished work.
> > Charlie Dennis
> > From: Chris Hargens [mailto:chargens@s...]
> > Sent: Sunday, May 30, 2004 10:06 AM
> > Thanks, Randy and Charles, for your advice. If I go the digital
> > negative route, I'll be using my 2200 to make them. According to
> > Burkholder the 2200, along with the 7600/9600, "gives the best
> negs
> > on the desktop yet." I've read that for silver printing, as
> opposed
> > to platinum, imagesetter negatives are superior to those from
> inkjet
> > printers, but I haven't heard anything to suggest that inkjet
> > negatives noticeably lower in quality.
> > Chris Hargens
> > Please visit the Group Homepage to check the Files, and other
> resources as
> > they are often being updated.
> > http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint
> > If you wish to receive no emails or just a daily digest, or you
> wish to
> > unsubscribe, please edit your Membership preferences by visiting
> this same
> > page.
> > Please follow these basic guidelines:
> > - As threads develop, trim off excess portions of earlier
> messages to keep
> > them short.
> > - Good manners are required at all time. No personal attacks or
> flames.
> > Hostile, aggressive or argumentative users may be removed from the
> > membership without notice.
> > - Keep your posts and threads related to the group topic of
> digital B&W
> > printing. Users who persistently make off-topic posts may be
> removed from
> > the membership.
> > - By posting on this forum you agree to abide by the group rules
> and
> > guidelines, and to abide by the actions and decisions of the group
> Owner and
> > Moderators. See "Group Topic, Rules and Guidelines" in the Files
> section:
> > BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW,
> THE PRINT
> > YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE
> "OWNER" AND
> > "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE
> LIABLE TO YOU
> > FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR
> EXEMPLARY
> > DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS
> OF PROFITS,
> > GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF
> THE "OWNER" AND
> > "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE
> BEEN ADVISED
> OF THE
> > POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE
> INABILITY
> > TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED
> ACCESS TO OR
> > ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR
> CONDUCT OF ANY
> > THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY
> OTHER
> > MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP.
> > Yahoo! Groups Sponsor
> > ADVERTISEMENT
> > Yahoo! Groups Links
> > a.. To visit your group on the web, go to:
> > b.. To unsubscribe from this group, send an email to:
> > DigitalBlackandWhiteThePrint-unsubscribe@yahoogroups.com
> > c.. Your use of Yahoo! Groups is subject to the
> Yahoo! Terms of
> Service.
> > [Non-text portions of this message have been removed]
> other resources as they are often being updated.
> you wish to unsubscribe, please edit your Membership
> preferences by visiting this same page.
> messages to keep them short.
> attacks or flames.
> from the membership without notice.
> digital B&W printing. Users who persistently make off-topic
> posts may be removed from the membership.
> rules and guidelines, and to abide by the actions and
> decisions of the group Owner and Moderators. See "Group
> Topic, Rules and Guidelines" in the Files section:
> BW, THE PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE
> THAT THE "OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT
> YAHOO GROUP SHALL NOT BE LIABLE TO YOU FOR ANY DIRECT,
> INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY
> DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF
> PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN
> IF THE "OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT
> YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH
> DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE
> ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii)
> STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW,
> THE PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO
> ADVERTISEMENT
> c.. Your use of Yahoo! Groups is subject to the Yahoo!
> Terms of Service.
> --------------------~--> Yahoo! Domains - Claim yours for
> only $14.70 http://us.click.yahoo.com/Z1wmxD/DREIAA/yQLSAA/ucIolB/TM
> or flames. Hostile, aggressive or argumentative users may be
> removed from the membership without notice.
