MIS Ultratone - Longevity Tests
2004-06-06 by darajani
I was wondering if anybody had seen these test results posted on a
gum printing site, which seem to indicate 400-600 years longevity for
Ultratone inks on certain papers with fixatives applied:
http://www.livick.com/method/inkjet/pg2d2.htm
I'm not sure about the methodology here, as there are terms thrown
around that I don't quite understand (neutral gray band test?).  But
the numbers seem impressive and I'm curious if similar tests have
been done elsewhere for prints with fixatives (like Clearshield or
Lascaux) applied.
Mike
Re:Ultratone-Longevity Tests-What ever happened to Hydrocote?
2004-06-06 by John Vitollo
Reading Livick.com longevity pages reminded me of Paul's Hydrocote coating tests a
couple of years ago. What was the final verdict for Hydrocote?
http://home1.gte.net/res0a2zt/coating.html
http://hydrocote.com/our_products.htm
The Livick site recommends:
http://www.clearstarcorp.com/clearshield.asp
John V.
Horizontal banding
2004-06-06 by Arthur Fink
Just started printing on a new (used) Epson 3000, using the old Cone
driver, MIS/FSN inks, Hannemuhle 308 photo rag paper.  8-1/2 x 11 prints
have been fine.  Now I just did an 11x17, and it has bands running
lengthwise on the print (in the direction of paper travel through the
printer)... slightly dark areas.  Everything on the printer seems to be
clean, nozzle check and alignment show perfect.  Any idea where else to look?
Arthur Fink
  A r t h u r    F i n k     P h o t o g r a p h y
  Ten New Island Avenue      207.766.5722
  Peaks Island, Maine 04108  arthur@...
Re: Horizontal banding
2004-06-07 by Clayton Jones
Hello Arthur,
>the printer)... slightly dark areas.  Everything on the printer
>seems to be clean, nozzle check and alignment show perfect.
Something similar happened to me once.  While researching digicams I
downloaded and printed several sample images from dpreview.com.  One
of them had slightly dark bands running horizontally through the
landscape oriented print, opposite to head travel.  They were evenly
spaced, about 3/16" wide.  Didn't look anything like microbanding or
dither banding.  At first I thought the printer was goofy, but other
prints were fine.  That print always had it.  I couldn't see anything
in the image on screen.  Never did figure it out.
So try other images and see what happens.
Clayton
RE: [Digital BW] MIS Ultratone - Longevity Tests
2004-06-07 by Paul Roark
Mike,
At http://www.livick.com/method/inkjet/pg2d2.htm, about 1/3 of the way down
the page, Livick seems to have some tests that indicate up to a 681 year
longevity for MIS Ultra Tone ink printed with a 1280.
Livick uses outside direct sun for testing, as best I can tell.  I don't
think he even uses a plain glass between the sun and the test strip.  So,
there is a lot of very short wavelength UV in the light source.  Plain
window glass usually filters this out in indoor display.  With this light
source, coatings that have a UV absorber in them will probably have a major
advantage, which might not be the case in normal indoor display.
Clearshield has such a UV absorber.  Lascaux spray and Hydrocote do not.
Livick seems to have been looking at various combinations of sprays and
coatings.  I don't really understand all the test results, but,
needless-to-say, I'm pleased to see the Ultra Tone ink doing so well.
___________________
Sent: Sunday, June 06, 2004 9:03 AM
Subject: [Digital BW] MIS Ultratone - Longevity Tests
Lascaux) applied.
Mike
they are often being updated.
page.
them short.
membership without notice.
the membership.
Yahoo! Groups Links
RE: [Digital BW] Re:Ultratone-Longevity Tests-What ever happened to Hydrocote?
John,
I stopped pursuing the Hydrocote-Mayer rod coating.  There were several
reasons for this.  I could not, with the setup I had, scale up to 16 x 20
with consistent results.  About 8x10 was it for me.
For display prints that I was going to sell or display in a gallery-type
setting, glazing would be necessary anyway, so I would not use the
Hydrocote.  For casual snaps that I wanted to just have displayed with no
glass, a simple spray (PremierArt) on glossy (Epson Glossy Photo, Ilford
Smooth Pearl, or Epson Premium Semigloss) is easier and gives me a print
that is protected well enough to clean with a damp cloth.
So, bottom line, I gave up on Hydrocote, even though I think such a coating
if done well might give the best looking final print in an un-glazed
display.  I don't think the Mayer rod is the way to do that for large
display, however.
___________________________
Sent: Sunday, June 06, 2004 2:45 PM
Subject: [Digital BW] Re:Ultratone-Longevity Tests-What ever happened to
Hydrocote?
tests a
John V.
page.
them short.
the membership.
Yahoo! Groups Links
