WHAT BO PRINTER
WHAT BO PRINTER
2004-07-19 by lancscott
What printers are people using for BO printers?  What printers don't
work.
Re: WHAT BO PRINTER
2004-07-19 by Miguel Angel Aleman
I just started experimenting with promising results on an Epson 7600
(using the Ultrachrome Matte black on Epson-Enhanced-Matte and
Hanamuhle German Etching paper.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "lancscott"
don't
> work.
Re: WHAT BO PRINTER
2004-07-19 by Clayton Jones
Hello Lancscott,
>don't work.
Any Epson printer except the 800 will probably work.  The best results
will come from newer models with 4 picoliter or smaller droplet size
with variable droplet capability.  In addition, the new 4000 has a
superior dither pattern which produces the best BO prints I've seen
yet.  There is a possibility the the small C64 _may_ have this good
dither pattern but that has not been confirmed yet.
Many BO users prefer the Eboni black ink from MIS, so I'd also
recommend getting a model for which Eboni cartridges are available
(check with MIS for that information).
Another thing to look for is whether the model can handle the real
thick paper stock that many of the better fine art papers use.  For
example, the 2200 has a rear feeder that can accept very thick stock
that some other models can't handle.
I'm not certain, but am pretty sure that Canon and HP printers do not
produce as good results as the Epsons.
Clayton
Re: [Digital BW] Re: WHAT BO PRINTER
2004-07-19 by Don M
Clayton Jones wrote:
>Hello Lancscott,
> >don't work.
Clayton, so that you don't buy the wrong printer, the other printer is the
C84, not C64.
-Don
Hello Don,
>is the C84, not C64.
OOPS!!!  Sorry about that.  Somehow I got 64 stuck up there in the
gray stuff.  Thanks for the correction.
Clayton
2004-07-20 by Kip Babington
FWIW, I don't have a 4000 and so haven't seen its dither pattern, but I do
have a C84 (incredible bang for the buck) and printed a bunch of BO prints
with it using both the Epson OEM black cart that came with it, and with EZ
Eboni.  While the BO results are nice, they're smoother with the EZ inks
firing on all four nozzles.  And the BO dither in large smooth areas looked
almost exactly the same as I got printing BO on my old 860 with Epson ink
(same images printed at the same sizes - I was doing some comparison
testing of inks and papers.)
Kip
At 7/19/2004 06:38 PM +0000, you wrote:
>Hello Don,
> the C84, not C64.
>OOPS!!!  Sorry about that.  Somehow I got 64 stuck up there in the gray
>Regards,
>Clayton
2004-07-20 by Clayton Jones
Hello Kip,
>I do have a C84 (incredible bang for the buck) and printed a bunch
>of BO prints...the BO dither in large smooth areas looked
Well, that doesn't sound good.  I was hoping it would be like the
4000.  The 4000 dither pattern does make a difference.  I wonder if
drivers for existing printers could be reprogrammed to use that
pattern...
Thanks for the info.
Clayton
