2 QTRpc questons
2 QTRpc questons
2004-10-10 by Tom OConnell
Hi-
Loading the loopback adapter got my first print session going fine
except that it killed my internet connection. So I tried deleting it
and it would not, but finally found that by canceling printer
sharing, I could connect to the internet. Is this normal?
In ver.25 there is no longer a paper profile to select...is there any
issue as to which paper to use? glossy?
thanks,
tom
Re: 2 QTRpc questons
2004-10-10 by njfranknj
I'm not having any problem with interference - I'm on dial-up, BTW.
Under Control Panel/Network Connections I have three headers
"Dial-up", "LAN or High-Speed Internet" and "Wizard", with my internet
connection in the first and the loopback adaptor in the second under
subheading "Local Area Connection". All are enabled.
Hope that helps,
Frank
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Tom OConnell"
<tomoc@y...> wrote:
> Hi-
> thanks,
> tom
internet
Thanks, Frank. That's just how I was set up. The only difference is
that I also had a coupld of wireless networks available and I was
connected at the time to an ethernet network (but only had internet
access, not local network access).
I'm beginning to think I didn't need the loopback...that maybe I
could have just enabled printer sharing?
Would anyone know if being connected to a wireless network satisfies
the "always on network" requirement???
thanks again,
tom
RE: [Digital BW] Re: 2 QTRpc questons
2004-10-10 by Brentley Beerline
A wireless network absolutely counts as a network and would not require a
loopback.
Sent: Sunday, October 10, 2004 11:22
Subject: [Digital BW] Re: 2 QTRpc questons
internet
thanks again,
tom
2004-10-11 by Tom OConnell
require a
> loopback.
Thanks Brently...I will try to uninstall the loopback adapter and I
should be fine.
cheers,
tom
PS- we all owe a big thanks to Roy and Stephen. Roy, you really have
an amazing app...
2004-10-11 by Stephen Billard
Wireless should suffice. Get rid of the loopback adapter and then share your
printer.
-Stephen
 www.sbillard.org/Stephen
> From: Tom OConnell [mailto:tomoc@...]
> Sent: Sunday, October 10, 2004 11:22 AM
> internet
> second under
> thanks again,
> tom
> $9.95 domain names from Yahoo!. Register anything.
> http://us.click.yahoo.com/J8kdrA/y20IAA/yQLSAA/ucIolB/TM
> If you wish to receive no emails or just a daily digest, or
> you wish to unsubscribe, please edit your Membership
> preferences by visiting this same page.
> - As threads develop, trim off excess portions of earlier
> messages to keep them short.
> - Good manners are required at all time. No personal attacks
> or flames. Hostile, aggressive or argumentative users may be
> removed from the membership without notice.
> - Keep your posts and threads related to the group topic of
> digital B&W printing. Users who persistently make off-topic
> posts may be removed from the membership.
> - By posting on this forum you agree to abide by the group
> rules and guidelines, and to abide by the actions and
> decisions of the group Owner and Moderators. See "Group
> Topic, Rules and Guidelines" in the Files section:
> BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL
> BW, THE PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE
> THAT THE "OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT
> YAHOO GROUP SHALL NOT BE LIABLE TO YOU FOR ANY DIRECT,
> INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY
> DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF
> PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN
> IF THE  "OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT
> YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH
> DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE
> THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED
> ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii)
> STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW,
> THE PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO
> THE DIGITAL BW, THE PRINT YAHOO GROUP.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Stephen
share your
> printer.
> -Stephen
Thanks Stephen. I'm still having a problem.
I have one laptop that I use in two locations with 2 different 2200s.
Should I be able to just change the printer sharing (delete on one
and use the same Quad2200 name on the other) and select in the GUI
dialog box...then just print? or is there another issue with using 2
different printers?
thanks in advance...hate to pester you.
tom
You shouldn't have to delete either. Just select the printer that is
connected. (If you don't have version 0.26, you should download it, it
allows you to select printers from your normal printer list--takes care of
the SHARE name automatically.)
-Stephen
> Sent: Sunday, October 10, 2004 11:34 PM
> share your
> > printer.
> > -Stephen
> different printers?
> tom
it
care of
> -Stephen
Thanks, Stephen-
I now have .26 but have the same result. I drop an 8bit GS .tif
240dpi image on the print area of the GUI and it shows "Quadtone RIP
is printing" but after about 30 seconds the message disappears and
nothing happens.
Looking at the QTRlog, it shows the last line
ERROR: Unable to write raster data to driver!
I've read and reread all the stuff on both websites and the files
that came with both downloads and cannot find any variance from the
instructions... Guess I should wait till I'm back with the first
printer or try the loopback adapter again (though I don't see why
since the GUI definitely distinguishes between printers that are
shared and those that are not).
If you have any ideas, it would be great.
cheers,
tom
2004-10-12 by fredila2
Tom,
I don't know if this will help but...
I tried for two weeks to print using the 2200 shared, a USB
connection, and the loopback adapter.  I messed with firewalls,
settings, etc.  Yet I could not make it work and got the
same "unable to write raster data to driver" message every time.
Stephen then suggested (after version .26) that I attach a parallel
printer cable to the 2200 (in addition to the USB connection).  I
gave the parallel connection the "Quad2200" share name. I also
disabled the loopback adapter.  I did all that today and finally got
it to work (with all the firewalls enabled.)  Thank goodness...and
thanks Stephen.
Fred Rothenberg
that is
it,
> it
takes
> care of
> > -Stephen
> Thanks, Stephen-
RIP
> nothing happens.
> cheers,
> tom
2004-10-12 by Tom OConnell
Fred-
I assume you then print with the parallel port? and the USB
connection is just to "share" on the network or to print with the OEM
driver or other rip?
tom
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "fredila2"
<fred@f...> wrote:
> Tom,
got
> thanks Stephen.
Tom,
Yes, when using QTR I print using the parallel port on which the
2200 is "shared."  I do not share the USB connection (I use the USB
connection for non-QTR printing on the 2200.)  I am not on a network
and do not use the loopback adapter.
Fred
<tomoc@y...> wrote:
> Fred-
OEM
> tom
> <fred@f...> wrote:
> > Tom,
parallel
I
> got
goodness...and
> > thanks Stephen.
2004-10-12 by Stephen Billard
If you are using the parallel port, there is no need to Share the printer.
-Stephen
> From: fredila2 [mailto:fred@...]
> Sent: Tuesday, October 12, 2004 11:20 AM
> Tom,
> Fred
You are correct.  There is no reason to share the parallel port
printer.
Fred
printer.
> -Stephen
> > From: fredila2 [mailto:fred@f...]
> > Tom,
USB
network
> > Fred
Just curious? How difficult would it be for you to hook your printer up with
Firewire? I see in my network connections that my Firewire connections are
listed. Maybe an answer to the networking issues? Also might print faster
for you.
-Stephen
> Sent: Tuesday, October 12, 2004 1:18 PM
> printer.
> Fred
Fred-
I don't see how you can set up the printer with both USB and Parallel
ports? I need to keep the USB for other printing???
I must have something else set up wrong since so many have used it
just following the instructions.
This is starting to turn into a much bigger effort than I wanted to
make <sigh>. I think I'll just put this puppy on the back burner for
a while and get some printing done <<g>
thanks for your help.
Tom O'Connell
> printer.
> Fred
Fred-
Tom O'Connell
> printer.
> Fred
2004-10-13 by fredila2
Don't know about Firewire, but I will look into it.
Fred
printer up with
connections are
faster
> for you.
> -Stephen
> > printer.
> > Fred
Tom,
If you have a parallel printer cable, turn off the computer and the
printer.  Attach the parallel cable to the 2200 (leave the USB cable
connected too.)  Attach the other end of the parallel cable to the
back of your computer.  Turn on the printer.  Turn on the computer.
If you are in "plug and play" mode, Windows will discover what it
thinks is a NEW printer and complete the connections for you.  A new
printer icon will show up under "Printers and Faxes" (probably
called Epson 2200-copy 1).  Then, when using QTR (or QTRGui is even
better) select Epson-copy 1 as your printer.
If you need more help with this, just holler.
Fred
<tomoc@y...> wrote:
> Fred-
Parallel
to
for
> Tom O'Connell
> > printer.
> > Fred
2004-10-15 by Tom OConnell
<fred@f...> wrote:
Fred-
That was it. Now I'm set. Thanks so much.
tom
> Tom,
cable
computer.
new
> Fred
