Re: [Digital BW] Re: refilling
2005-01-20 by Bob Frost
Jack,
You just flick them off with your fingernail, and push them back on to the
locating peg(s). Done!
Discharge any static from your fingers first!
Bob Frost.
 It has also been said that chip replacement
is easy.  I gather that these chips can either be ordered or removed from
empty cartridges.  Could somebody PLEASE point me to a description of the
procedure for removing and replacing these chips for the 2200,
2005-01-21 by Don
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Bob Frost"
<bob@f...> wrote:
> Jack,
to the
> Bob Frost.
Bob, you must have better fingernails that I do! I've been trying to
get the chips off a couple of old empthy 2200 Epson cartridges here
for the past 10 minutes with no luck.  Are any tools OK to use for
this?  I'm talking Epson here not third party cartridges.  thanks for
any advice.
Don
2005-01-22 by Daniel Ridings
> any advice.
> Don
I just use the sharp corner of a small jewler's screwdriver (the kind you
tighten the screws in your glasses with). There's usually a small cavity
between the chip and the cartridge you can pry it into and behind the
chip. Then just pop it off.
Tools? Depending on your age, good reading glasses :)
Daniel
2005-01-22 by Bob Frost
Don,
OK, the 2100/2200 chips are in a recess which might make it a little harder,
but just use the tip of a small screwdriver, sharp knife, big needle, etc to
prise up the chip from the top. When the top of the chip comes off the
plastic peg (which protrudes through a hole in the chip), the chip slips
upwards and out from under the bottom peg/clip, which just fits in a slot in
the chip.
Bob Frost.
any advice.
