Hi Steve,
You're right about the confusion, but it's not you, it's definitely me that's
confused. I completely misunderstood the problem, and your explanation. I
think I'm beginning to get it.
I thought I needed two iterations of the QUAD printer, but duh, the curves take
care of the PK/MK issue in the QUAD driver; it's the Epson driver that's the
problem.
I'll try the double install of the two inks and the Epson drivers later when I get
home, and let you know how it worked.
Thanks for your patience.
peter
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Steve Kale <
stevekale@b...> wrote:
> Ok I think you or I are getting confused. The only issue re swapping ink
> cartridges arises with the Epson driver - not QTR. If you use a Mac and the
> Epson driver the procedure I described will avoid you having to delete
> printer etc when swapping PK to MK and vice versa. With QTR, it does NOT
> care if you swap. So you only need QUAD2200 once (as opposed to the
Epson
> driver where you should have two of all that you use - No Margins, Maximum,
> Standard etc). QUAD2200 can sit happily alongside your twin sets of Epson
> drivers - just define the Epson ones first.
> > From: krn_ptr <krn_ptr@y...>
> > Reply-To: <DigitalBlackandWhiteThePrint@yahoogroups.com>
> > Date: Fri, 18 Feb 2005 14:45:40 -0000
> > Subject: Re: [Digital BW] PK or MK on QUAD 2200?
> > Yeah, thanks for your reply again, Steve. Unfortunately, the suggested
method
> > doesn't really seem to apply to the new easy install procedure in v2.1d.
> > There
> > is no CurveDropBox anymore that I can find.
> > The install automatically sets up a printer which I have now named,
> > QUAD2200MK. You load the curves into that first printer the same way as
in
> > v2.0, using the terminal launched by the curves installer file. However,
there
> > doesn't seem to be any way to get the curves into the second Quad printer
> > selected in the Printer Setup Utility.
> > The good news is that the Epson 2200 Firewire printer I selected in the
> > Printer
> > Setup Utility to print colour, does work without having to trash/reinstall the
> > printers etc. So your idea would work if I only knew how to install a second
> > QUAD2200PK printer and get the curves loaded.
> > peter
