What is actually in Ultrachrome inks?
2005-03-11 by john dean
I know this is a naive question, and one I should know the answer to, but what actually is
in UltraChrome ink? Are they a hybred inkset composed of some dye and mostly pigment,
or what? I think Nash Editions was going to call them pigment prints and I was about to do
the same, but I'm wondering if that is really a good idea? I don't like do deceive people if I
know better.
John
RE: [Digital BW] What is actually in Ultrachrome inks?
2005-03-11 by Seth
I don't think it's naïve.  How would you know?  Do you think Epson would
would really publish the exact formulation?
Not that it's tough for a chemist to disassemble or reverse engineer.
Seth
==-----Original Message-----
==From: john dean [mailto:deanwork2003@...]
==I know this is a naive question, and one I should know the
==answer to, but what actually is in UltraChrome ink? Are they
==a hybred inkset composed of some dye and mostly pigment, or
Re: [Digital BW] What is actually in Ultrachrome inks?
2005-03-11 by Djon
It's not a dye or pigment or formulation.  Epson confuses the matter
by calling it "pigment" but they do that to distinguish it from
everything else that's out there.
A pigment is just a colorant, it's in dye and ink.
What's distinctive about Ultrachrome is the pigment's encapsulation.
None of the competing products are encapsulated.
>  y
My interpretation of these terms was that they distinguish the size of the "colorant"
molecules which in "dyes" are smaller and more fluid and break down more easily when
exposed to uv and blue radiation, while "pigments", larger more stable molecules, have a
much tighter bond. When you start to mix them that's when things become slippery. Not
to beat a dead horse and it isn't that important really, but there must be some chemist
who has written a description of the major products out there. Maybe not. I'm sure they all
vary from company to company, sometimes probably quite a bit, like the encapsulation
chemestry that Epson has a patent on , etc.  I'm sure all these companies play it close to
the vest to protect their own hard work and r and d expenditures.
John
-- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Djon" <westsidemaurice@y...>
> >  y
2005-03-11 by Paul Roark
> ... what actually is in UltraChrome ink?
> or what? ...
With the caveat that I'm making educated guesses here, since neither Epson
nor any other pigment company is about to disclose anything to me, let me
outline some of what I've been able to discern from various materials.
To start, the main distinction between a dye and a pigment is that pigments
are solid particles that are suspended in a fluid -- mostly water in our
case.  Dyes, on the other hand, are dissolved colorants -- like sugar in
water.  This leads to the main performance differences between them.  The
dyes go on as a liquid and then dry to become a thin crystalline coating on
the surface.  This makes for a nice even, high gamut coating, but the
crystals are very small.  Lightfastness increases with the size of the solid
crystal particle, the pigments are huge rocks compared to the dye crystals.
(Note that with an average pigment particle size of about 0.1 micron, our 25
micron nozzles do not get plugged by these "rocks" in and of themselves.)
The reason lightfastness is related to particle size is that most of fading
is oxidation.  The larger the particle, the less surface area it will have
relative to its mass.  Thus, with less surface exposed to the oxygen, the
colorant simply fades slower.
So, for lightfastness, we'd actually like the largest particles possible.
Unfortunately, the large particles would sink to the bottom of our carts.
While the pigments are selected, in part, based on their relatively low
specific gravities, they are all still heavier than the fluid carrier.  To
keep them in suspension the particles must be very small, the reasons being
the opposite of what we'd like for lightfastness -- the smaller particles
have more surface area to mass, thus increasing the effectiveness of
viscosity and Brownian motion to keep them from sinking immediately.
Chemically, the dye and pigment colors may be close to the same.  Some of
the pigments are "dye stacks" -- non-soluble, relatively large crystals of
dye.
The pigments that are probably used by Epson and the others are organic
compounds.  That is, they are based, in part, on carbon.
(Epson's Material Safety Data Sheets are of little value here because they
just call almost everything, "proprietary dyes and pigments.")
The cyan pigment is probably a "phthalocyanine."  This elegant molecule
looks like a symmetrical snowflake, with 4 carbon rings linked into a flat
disk by carbon and nitrogen.  There is a copper atom in the middle.  This is
a very important and stable class of pigments for industry.  The RIT tests
that MIS has published also show the cyan to be extremely lightfast.
The magenta is probably a "quinacridone."  This is composed of a linear
array of 5 carbon rings -- thus the "quin" -- with 2 pairs of oxygen and
hydrogen hanging off it.
The yellow is probably a "monoazo (arylide)."  This is a pair of carbon
rings joined by nitrogen to a central cluster of 4 carbons.  Colors are
controlled  by various atoms hanging asymmetrically off the sides.  While
this is only moderately lightfast, it also has the lowest specific gravity,
thus allowing the particles to be made larger.
What probably distinguishes the pigments from Epson and the others the most
is the surface treatment.  Epson uses an acrylic coating, whereas the others
use different surface attachments to help keep the materials in suspension
and dispersed, and help them stick to the paper.  There are arguments for
and against Epson's choice of acrylic.  Since it is not a good oxygen
barrier, it probably has little effect on lightfastness.  In fact, if it
makes the primary pigment particle smaller, its effect could be negative.
I would guess that UltraChrome inks are pure pigment, with no liquid dyes in
the fluid.  (A more interesting question is whether the acrylic coatings
have dyes impregnated in them, and I have no clue on this.)
Anyway, that is my long-winded, best guess as to the pigments that are in
both the Epson and third-party products.  There are many minor variations of
these basic pigment classes that alter the exact chemical structures and
colors.
That was very nice Paul. That was the most straightforward description of this issue that
I've ever heard. Thanks so much for the effort. You really seem to know your stuff.
John
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Paul Roark" <paul.roark@v...>
> > or what? ...
> dye.
> colors.
> Paul
> www.PaulRoark.com
2005-03-11 by Steve Kale
But arguably one could make a "dye" ink of very small carbon particles.  I
think the point of an earlier post was that pigment was a generic term
equally applicable to dye inks.  My understanding is the critical issues are
the size of the pigment particle and whether or how it is encapsulated.
Smaller particles sit better on or in paper but their mass to surface ratio
leads to faster oxidation, as you say.  I would like to hear from John
Edmunds on this.  The question is what might the optimum particle size
be...if one found a way to make markedly smaller encapsulated pigment
particles you would gain from their ability to soak into paper better and
from an overall greater saturation of pigment per ounce of ink and hence
better colour gamut.  But what about fade?
> From: Paul Roark <paul.roark@...>
> Date: Fri, 11 Mar 2005 09:31:30 -0800
> Subject: RE: [Digital BW] What is actually in Ultrachrome inks?
>> or what? ...
> dye.
> colors.
> Paul
> www.PaulRoark.com
> page.
> them short.
> Hostile, aggressive or argumentative users may be removed from the membership
> without notice.
> printing. Users who persistently make off-topic posts may be removed from the
> membership.
> guidelines, and to abide by the actions and decisions of the group Owner and
> Moderators. See „Group Topic, Rules and Guidelines‰ in the Files section:
> YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE „OWNER‰ AND
> „MODERATORS‰ OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU
> FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY
> DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS, GOODWILL,
> USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE  „OWNER‰ AND „MODERATORS‰ OF
> DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH
> DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW,
> THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR
> TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE
> DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE
> DIGITAL BW, THE PRINT YAHOO GROUP.
2005-03-11 by Brian Don Hohner
> colors.
> Paul
> www.PaulRoark.com
Beatiful synopsis Paul...
I've read a bit about colour chemistry and I agree on most points. I did read
somewhere on the net though, that the biggest difference between Epson's Archival
inkset and the UltraChrome is that to improve the colour gamut they opted to add
some dye to the yellow ink to improve colour space at the expense of longevity.
Yellow is the most ephemeral of all inks, even in lithography. If you put a litho in
strong sunlight the yellow will go fast and then the magenta and lastly that stable
Phthalocyanine you spoke of.
I've saved what you wrote as a nice summary for when I get asked these questions.
You aren't long winded but I am!
Brian
Yes, that thing about the yellow channel being "re-engineered" for greater saturation and
a more useful gamut in the reds is also something I heard when Ultrachome was first
introduced. Now whether that yellow has "dye" in it I don't know, and we may not even be
able to know without some chemist breaking it down methodically. Bottom line is it
doesn't really matter except for semantic reasons. I was going to put on my website that I
only work with pigments, no dyes, but I didn't say that ...... whatever.
I use both of these inksets and whatever they did to create UC works. Only if they made
them for the 10K I already have. That printer is a much nicer machine all around, strong as
an ox and significantly faster. I guess I'll have to go back to Lyson now for help.
That was great Paul, I'm printing it out for reference too.
John
What is dye made of?  Dye is "a usually soluble substance for staining or
colouring" but what substance?  One could make a dye of very finely ground
carbon.  A dye could well be the same materials mentioned  by Paul.  I don't
think dye or pigment are the right or adequate descriptors here.
> From: john dean <deanwork2003@...>
> Date: Fri, 11 Mar 2005 20:13:36 -0000
> Subject: Re: [Digital BW] What is actually in Ultrachrome inks?
> saturation and
> first
> not even be
> is it
> website that I
> they made
> around, strong as
> help.
> John
> ... that thing about the yellow channel being "re-engineered"
>for greater saturation and a more useful gamut in the reds is
>also something I heard when Ultrachome was first introduced.
> may not even be able to know without some chemist breaking it down...
Yellow dye definitely has its uses.
My old FSN was the first B&W ink I know of that had almost no warm shift (on
EEM).  Yellow dye was a critical component of that mix.  I used the
different relative fade rates of yellow dye and cyan pigment to handle the
underlying poor delta e (color shifting) of the inks of the time.  I
intentionally matched the yellow fade rate with the warming rate, but, of
course, going in opposite directions.  So they cancelled each other out.  I
used rock-solid cyan to offset the yellow dye's visual impact on the inkset.
This cyan was so tough even back then that it improved the lightfastness of
the overall inkset, even with the yellow fading away.
The general lesson is that to hold down delta e, dyes -- particularly yellow
-- can have a useful roll.
The nice thing about yellow dye is that while it is high in gamut, it is low
in visual density.  So, while it fades, its impact on color is more
significant than its impact on density.  The bottom line was that my
original FSN had a much lower delta e than the existing quads of the time,
yet it also faded less.  That's not a bad combination.
With the advent of the higher-load and more lightfast carbon inks used in
the UT inks, I agonized over whether to also build in a counter-shift to
hold down the delta e. I opted not to, in part, as a matter of principle.  I
wanted to be able to print as pure a carbon image as possible.  The carbon
does warm shift a bit, and I could control that with yellow dye.  But, in
the case of the UT family, the pure-carbon & pure pigment goals won.  The
warm shifting of the carbon is so much less than the older inks' warm
shifting, that it just is not a big enough deal to resort to adding dyes.
Epson, might have made some different decisions in this regard.
Epson's UC MSDS's suggest that those pigments are only partially carbon.
A UC-based quad inkset I made had the lowest delta e I've measured, but it
also had a slightly higher initial fade rate.  Maybe these are all
connected, but I'm speculating.
> line is it
> my website that I
> if they made
> around, strong as
> for help.
> John
> page.
> them short.
> membership without notice.
> the membership.
> and Moderators. See "Group Topic, Rules and Guidelines" in the Files
> section:
> YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE "OWNER" AND
> "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO
> YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR
> EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF
> PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE
> "OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN
> ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE
> OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii)
> UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii)
> STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT
> YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE
> PRINT YAHOO GROUP.
> But arguably one could make a "dye" ink of very small carbon particles....
My understanding is that dyes are soluble and pigments are not.  Only if you
consider molecules to be particles do the two meet.
I believe the carbon that is used in the black ink is mostly graphite.
Graphite is insoluble in water.  See
http://www.hummelcroton.com/data/grph_d.html
But, it is true that the particle size is probably the most important
distinction.
It is also my understanding that the dye printers can use low loads of very
finely ground pigment.
Apparently one thing that limits the non-Epson desktop printers in this
regard is the viscosity of the inks.  The piezo-electric head that Epson has
rather well protected with patents may be the only one that can pump the
high-viscosity base needed to keep high loads of larger particles in
suspension.  So, for example, the dye inkset blacks may well have carbon
particles in them.  But, there will be a relatively low load (relative
amount of pigment per volume or weight), and the particles have to be very
finely ground.  (The smaller the particle, the lower the viscosity needed to
keep it in suspension.)  The good dmax they get comes from the dyes that are
added, and the composition of these is unknown to me.  They used to be color
pigments, particularly cyan.  (That is where the PKN concept came from.)
So, does that mean that other patented head configurations, like the Iris for example, are
incapable of using the high-stability pigment inksets? HP is certainly doing something
interesting with pigments in their thermal printers to achieve such ratings.
John
-Apparently one thing that limits the non-Epson desktop printers in this
suspension.
2005-03-11 by Bob Frost
John,
The normal simple meaning of the terms is that a dye ink is a solution of
molecules that possess color, while a pigment ink is a suspension of large
aggregates of insoluble molecules that possess color.
But these terms were invented by humans a long time ago, and we now have
colored chemicals that don't fall cleanly into either of these categories.
As with most terminology and nomenclature, the terms/names/categories are
not absolute, but have to be changed as our knowledge increases.
With the Ultrachromes, Epson also coated the pigment aggregates with resin,
and with the new Higloss Ultrachromes they have apparently changed the resin
to make the particles more glossy.
Bob Frost.
"colorant"
easily when
molecules, have a
much tighter bond.
>like the Iris for example, are incapable of using the
I've been lead to believe that it is one of the major factors.
The Iris used rather fast-fading dyes.  That is why among some high end
galleries I spoke with, the "Giclee," which is associated with the Iris, got
a bad reputation.  That is one of the many reasons I avoid the use of that
term.
> HP is certainly doing something interesting with pigments in their
It may be that the main factor is currently the swellable paper.  What that
does is pull the dye down into a chamber, where dries in more of a
particulate form and is also protected by the paper emulsion.   It's, in
effect, an encapsulated quasi-pigment particle (my terminology).
Ultimately, the chemistry of mordants -- the substances that absorb or react
with the dyes to make these quasi-pigments -- also holds great promise.
Consider a 2-component, epoxy-like rock embedded in an emulsion that has
also become very hard.  I think the potential is immense.  (I'm so glad to
see Carly get fired.  Go to it HP inkjet tech guys!)
I think we'll benefit greatly by these big guys competing fiercely.  Canon
is also not to be counted out.  These are some impressive players, and we
benefit.
One thing I like about the pigment approach, however, is the ability to use
the traditional cellulose papers.  I still think carbon on cotton is the
combination to beat.  That may not always be the case.
> John
> has
> suspension.
> page.
> them short.
> the membership.
> section:
> PRINT YAHOO GROUP.
2005-03-11 by Paul D. DeRocco
> From: Djon [mailto:westsidemaurice@...]
As I understand it, the colorants in a dye ink are completely dissolved, so
they're floating around at the molecular level. In a pigment ink, the
colorants are solid particles much, much larger than a molecule, suspended
in a liquid. I've also read that the UC inks are not just solid particles of
a single color, but have a more complex structure, as you suggest. But
they're definitely not dye inks.
What is actually in Ultrachrome inks? One final question
Bob, Paul,
I'm gettig a much better understanding of this situaton now. We are moving beyond the
era of "colorants" as we once thought of them traditionally in art and photography, and
into the world of new chemical inventions, and that is why is so difficult to find anything
clear written about them, because it is all held so close to the vest.
.......think we'll benefit greatly by these big guys competing fiercely. Canon
benefit. One thing I like about the pigment approach, however, is the ability to use
combination to beat. That may not always be the case.- Paul
I agree that competition is what is going to make color imaging work the best for us.
The thing that doesn't appeal to me at all about HP's approach is the way you are 100%
dependent on their media-ink combination as a "system". Good marketing, bad art. I don't
like systems. I like diversity and uniqueness. That is why I think it is so silly for Epson to
be marketing this "system" of theirs where we are all trained to use only their appropriate
and apporoved substrates. They are trying to kill the best thing about their own printers,
but that dog won't hunt for them or us. People like diversity and uniqueness.
I have one final question before getting back to work. Why in the world if the yellow
channel is the PRIMARY ( though certainly not total) change in the Epson pigment inkset
from Archival CF to UltraChrome, is it not possible to just replace that yellow ink with the
Ultrachrome equivilent and remake profiles and the driver for everything, with much
improved results. I just don't get it. I am completely satisfied with the CF inks rendition of
all colors except the ones such as yellow, red, and orange, where intensity is needed in
these hues. The blues and greens are just beautuful to me and so much nicer than
anything we had to work with in chemical color printing. Of course the black component is
different but that's a different problem with different solutions.
John
2005-03-12 by Seth
I can't speak to Iris, but Epson piezo-electric heads work much differently
than other printers.  When I went to the Epson inkjet repair school it was
explained pretty well, though technologies change.
Canon Bubblejet (they dropped the name so I don't know if they dropped the
system) rather than squirt the ink, heated an ink bubble that burst and
layed down.  Actually, you could see the uneven spatter under magnification.
Basically, it farted on the paper.
HP was using just a plain old airbrush approach, though more refined.
This is another reason "universal" refill kits for desktops is bull.
Each head technology has its own limitations and pluses.
"Son of EP," small company that it is has managed to kick the big boys
(Canon and HP) for some time now.
Seth
==> So, does that mean that other patented head configurations,
==like the
==>Iris for example, are incapable of using the high-stability pigment
==>inksets?
2005-03-12 by aderca@sbcglobal.net
Actually, bubble jet heads are in essence a network of mini-resistors,
an electric pulse will heat the ink up to a bubble and then sudden cooling
will make it burst (roughly, this is what is taking place, in layman's terms).
I own both Epson and Canon printers (the latter for color only) and I think
that if you move into "dye" ink territory, it is wide open as far as which
printhead technology has the edge. It would of course be counterproductive
to launch a discussion as to which tool is the best overall, depending on the
task and the results you expect some are more apt than others.
Andrei
  Sent: Saturday, March 12, 2005 11:19 AM
  Seth
  ==like the
  ==>inksets?
  - By posting on this forum you agree to abide by the group rules and guidelines, and to abide by the actions and decisions of the group Owner and Moderators. See "Group Topic, Rules and Guidelines" in the Files section:
  BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE "OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE  "OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP.
        Yahoo! Groups Sponsor
              ADVERTISEMENT
  Yahoo! Groups Links
Combining CF and Ultrachrome- What is actually in Ultrachrome inks?
2005-03-12 by john dean
I'll try again asking this to you ink and printer experts.
Sorry to be repetative this is an issue that is haunting me and I think someone
out there may know the answer. Paul?:
yellow channel is the PRIMARY ( though certainly not total) change in the
Epson pigment inkset from Archival CF to UltraChrome, is it not possible to
just replace that yellow ink with theUltrachrome equivilent and, remake
profiles and the driver for everything, with much improved results. I just don't
get it. I am completely satisfied with the CF inks rendition of all colors except
the ones such as yellow, red, and orange, where intensity is needed in these
hues.  This CF yellow also has much worse metamerism.The blues and
greens are just beautuful to me and so much nicer than anything we had to
work with in chemical color printing just as in Ultrachrome. Yea the Magenta
may be a little weaker also but it is the yellow that is the big limitaion of this
inkset for color control. Of course the black component is different but that's a
John
RE: [Digital BW] Combining CF and Ultrachrome- What is actually in Ultrachrome inks?
2005-03-12 by Paul Roark
John,
> ... Why in the world if the
> to
I think one of the primary changes between the Archival and UC inksets was
the pigment load.  The UC inks have, I believe, a higher load of pigment
particles.
By the way, in my initial fade tests of B&W inksets made with UC LK and UC
or Archival color pigs added to neutralize the warmth of the LK, the UC
performed better than the Archival.
>...I am completely satisfied with the CF inks rendition of all colors
> except
> these
> Magenta
> of this
I suspect you could just use the UC yellow and not do any harm to anything.
The archival K tests out just like the old MIS VM.  I suspect it is a hybrid
black.  The UC MK and PK are much stronger.
Substituting the Yellow CF ink in 10K for Yellow UC or Lyson CP
( Sorry to clogging up this site talking about color pigments, it is just that this is the most
intelligent and useful sites I've encountered. I'll try to end this topic now)
 "I suspect you could just use the UC yellow and not do any harm to anything."
Paul R.
 I guess that is the million dollar question for me right now.
 Paul this is what I would like to do to avoid changing the inkset altogether. Maybe I
could use the Ultrachrome M Black or Ebony as well. But my primary challenge is not
permanence beyond Ultrachrome or the original CF K ink, but reducing metamerism in the
warm colors while also giving much greater saturation in those colors that contain yellow. I
would have to come up with a chipped 10K cart and fill it with UC yellow which wouldn't
be easy of course.
I guess what I don't understand at all is why I haven't heard others talking about this
change. There are thousands of us out there that have fine running stable 10K machines
that perform outstandingly except in this yellow channel oddity and Epson only
"retrofitted" these machines for a very short period of time to Uc. Now they want you to
replace the printer. They are so much faster than the 9600.
The short of the long of it is I would like not to have to completely change over to Lyson's
Cave Paint, though that is a very strong possibility. Now that I work with the 9600 I just
can't live with these CF reds anylonger, especially on rc media with skintones.
But if I end up wrecking my heads on a printer that is out of warranty, that would be worse
than leaving the Epson inks behind altogether in favor of Cave Paints.
Is there any place that I can check to see if anyone has tried substituting the yellow or
even the black channel on this inkset and leaving the others in place? I bet someone has.
Thanks again,
John
Re: What is actually in Ultrachrome inks?
2005-03-13 by dlruckus
Can't make a dye of anything larger than a molecule of carbon. Get 2
of them and it becomes a clump and -that-- is a pigment.
Duane
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Steve Kale
staining or
ground
 I don't
RE: [Digital BW] Substituting the Yellow CF ink in 10K for Yellow UC or Lyson CP
2005-03-13 by Paul Roark
John,
I can't imagine you'd damage your printer by trying the UC yellow.  I run
MIS, UC and Archival inks through all the smaller printers, and they all
seem very similar and compatible.  I would guess the downside is simply that
it won't give you the reds you want due to the Archival magenta still being
there.
I wonder what Epson did when they "retrofitted" the printers for the UC inks
-- besides make money on the process.  The UC inks carry a higher load of
pigs, so the viscosity might be a bit higher.  However, from my
measurements, all these inks are fairly close.  The only higher viscosity
ink I've run into was the magenta.  The MIS 7600 M was a bit too high for
the 1280, thus the "GP" inkset.  It didn't damage the printers as far as I
know.  The yellow is not that likely to have too high a viscosity because it
is the lightest (specific gravity) of the bunch.
I'm not familiar with the 10000, so I don't know what problems you might
have with chips, etc.
Good luck with the experiment.
> Sent: Saturday, March 12, 2005 3:25 PM
> Subject: [Digital BW] Substituting the Yellow CF ink in 10K for Yellow UC
> or Lyson CP
> now)
> anything."
> Paul R.
> altogether. Maybe I
> challenge is not
> metamerism in the
> contain yellow. I
> which wouldn't
> be easy of course.
> talking about this
> 10K machines
> only
> they want you to
> the 9600 I just
> skintones.
> that would be worse
> bet someone has.
> Thanks again,
> John
> page.
> them short.
> the membership.
> section:
> PRINT YAHOO GROUP.
Re: [Digital BW] Substituting the Yellow CF ink in 10K for Yellow UC or Lyson CP
2005-03-13 by john dean
Thanks Paul, I always appreciate your honesty and experience.
John
paul.roark@v...> wrote:
> John,
that
> there.
> Paul
> www.PaulRoark.com
> > From: john dean [mailto:deanwork2003@y...]
> > or Lyson CP
> > now)
> > anything."
> > Paul R.
> > altogether. Maybe I
> > challenge is not
> > metamerism in the
> > contain yellow. I
> > which wouldn't
> > be easy of course.
> > talking about this
> > 10K machines
> > only
> > they want you to
> > the 9600 I just
> > skintones.
> > that would be worse
> > bet someone has.
> > Thanks again,
> > John
as
same
> > page.
> > them short.
from
> > the membership.
> > section:
BW, THE PRINT
THE "OWNER" AND
NOT BE LIABLE TO
CONSEQUENTIAL OR
FOR LOSS OF
(EVEN IF THE
GROUP HAVE BEEN
GROUP; (ii)
BW, THE PRINT
DIGITAL BW, THE
> > PRINT YAHOO GROUP.
> > Yahoo! Groups Links
2005-03-13 by Ernst Dinkla
Paul Roark wrote:
>John,
>there.
To my knowledge Epson never retrofitted the 10K with UC inks, at least
not the ones that were already delivered. There's no 10600 firmware
either that can be uploaded to a 10K. This time Epson made money by
selling new 10600's :-)
I don't think that exchanging the yellow only resolves much of the
issues with the CF inks. Blues and reds are horrible if compared to the
MIS 7600 inks, black has a low Dmax.
I'm running MIS 7600 inks in the 10K here.  There's a trick that you
need to know when you want to refill the 10K cartridges and you also
need the chip resetter. Mediastreet has empty 10K compatible carts
though. But if you intend to use the 10600 inks + carts you need to
replace the chip and it is very difficult to get them off the carts
without damaging them.
I've used the left over yellow and lightmagenta 10K CF inks to mix a
sepia for the Eposn 9000 last Friday and get no clogging so far.
Ernst
>term.
You are right on that. Pity though that Epson has a new concept for
quality guarantee in inkjet printing that gets the name UltraGiclee. We
will live with that name for another decade.
>benefit.
Not related to the recent HP dye-coating technology but:
The first pigment inks were used in Encads etc GO type ink, HP has used
black pigment in many inkjets and full CcMmYK pigment sets in the wide
formats. So the use of pigment inks isn't limited to piezo heads. They
all didn't have the gamut we like and which is available in the Epson UC
and third party clones.  Piezo heads seem to be more suited for
"thicker" inks in general, that includes sublimation inks for textiles,
UV curing resin inks, heavier pigmented inks, etc
Competition between the big boys is a good thing. If compared to what
almost a 100 years of analogue color photography has delivered in terms
of fade resistance then we shouldn't complain too much. At least the
biggest boy pays attention to that aspect, something the biggest boy in
analogue photography used to neglect. Where HP will be in the printing
industry in five years is hard to say. The competition isn't from Japan
only, Dell wants a share and you may expect Chinese companies to join
the Korean ones soon. The sign industry is already surprised by the
number of Chinese Wide Format (up to 5 meter) printers that were brought
to the market last year. Based on Xaar or Spectra piezo heads (UK) but
nevertheless.
Ernst
Ernst:
 Actually Ernst they did offer a retrofit for a short period. If was a very slick
move though. I had recently paid 10 grand for my 10KCF and Wilhelm was
raving about how this inkset had changed photography forever. UC had just
been revealed and all we knew or sure was that they had redeveloped the
yellow to give greater gamut but that it cut the longevity in half.  Of course that
was kind of a myth because the whole set was new. We also knew that it
would lack the two black channel configuration and  so the 6 ink UC wouldn't
help with any monochrome content. That didn't seem like a good move for me
to pay them a grand or two, whatever they were charging then, for a change
that I was totally  unclear about.   It was probably only for about 6 months that
it was offered and not broadcast very loudly. Shortly after I remembr talking to
an Epson rep on the phone about something else and he told me that it cost
them too much to offer this program so they were stopping it. And then they
gave you the nice opotion of retiring you new machine and buying the new
model. So much for top of the line service.
You and Paul are probably correct here. I think it would definitely help some
but the best solution is too change inksets altogether and begin anew. Did
you know that Epson doesn't offer an OSX driver for their 10600 machine with
Archival or even the dye inkst? I personally think they want to discourage the
use of these inksets and retire them. Why else would they do that?
Ernst, How have your MIS 7600 pigments worked out for you? When I do very
large things I just love the speed of this big machine.  What options for third
party inksets do I have? Have you compared the pros and cons of each? The
two people I've discussed the Cave Paints with rave about them and say they
equal or surpass UC. I guess my options are MIS 7600, the Media street
pigment, or the Cave Paint. I don't know anything about the permenence tests
on any of these. Lyson's own pr and information on their own product is so
bad I have to find out through the grapevine about them, but I think they are
good. None of these third party offerings have the polymer encaptulation
pigments that Epson patented. The one very fine thing about that original CF
inkset is the lack of cloggs. My machine has been trouble free for 3.5 years
with daily useage and not one single clog. I never shaked the carts. They did
that right.
Thanks guys,
John
2005-03-14 by Ernst Dinkla
>that right.
At the time the chip resetter became available, MIS had its inks ready
too. MIS also had the quad inks. Most of the time a friend orders and I
get my ink from him, sometimes it goes the other way around. It is
expensive for us to buy from several US suppliers. He has two 9600
running the MIS 7600.
There were some other clone producers but their price wasn't as nice.
Mediastreet's clone wasn't there yet but my experience with their
Generations ink has always been good. They have 10K carts. I am no fan
of Lyson for a long time, for several reasons but that's an old story.
I'm using the MIS 7600 inks in the 10K a friend uses them for about a
year I guess in two 9600's. They are not without problems but that's
mainly the heads getting filthy at the paper side.  Enough printing
helps to keep the pigments from settling. The higher pigment load has an
influence on the stability of the total system. It could well be the
same with the 10600. So strictly comparing it with a 10KCF isn't correct.
Ernst
