QTRgui Calibration Mode
2005-03-26 by mastedward
I am reading Tom Moore's tutorial on making curves for QuadToneRIP.
One of the first steps is to print an ink Seperation Test Page.  Having
selected the Options/Calibration mode as directed, and set the
calibration slider all the way to the left (100) and clicking the print
button, my Epson 2200 prints the Ink Pattern Page but using
(apparently) only black and magenta inks. Ink 1 prints its step pattern
in shades of light blue to dark purple.  Ink 2 is the same but lighter.
Inks 3 to 7 all look much the same; white to dark red (magenta?).  Not
at all what is illustrated in the tutorial.  Any ideas what the reason
for this is??  Thanks,  Edward
Re: QTRgui Calibration Mode
2005-03-26 by koloshor
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "mastedward" <mastedward@y...> wrote:
That sounds like you're not actually getting QTR to run in calibration mode. Either you've got an old version (in which case, you really need to upgrade to the latest, or you've got the dreaded "mixed installation". Sometimes, when you install a new QTR over an older one, bits and pieces of teh old program hang around, mucking up the works.
Download QTRcleanout, run it, and it will decontaminate the old QTR versions, so your new QTR installation should be "pure".
Re: QTRgui Calibration Mode/thanks Koloshor. . .
Thanks, Koloshor.  Ran the cleanout program and then downloaded
QuadToneRIP again and that solved that problem. Now I just need a
tutorial to explain the rest of Tom's tutorial. . .he lost me after
the the ink seperattion test. . .Edward  --- In
DigitalBlackandWhiteThePrint@yahoogroups.com, "koloshor" <wiz@n...>
QuadToneRIP.
Having
print
pattern
lighter.
(magenta?).  Not
reason
