jpg vs. raw
2005-07-01 by claudej1@aol.com
As a digital photographer for 10 years now, I'm on my 30th digital camera. Starting with the 200 series Kodaks, we were forced to shoot RAW (it wasn't called that back then, Kodak stupidly called it a .TIF). This moronic naming convention was copied by Canon (a Kodak partner for the 500 series of cameras) up until very recently. In tethered event photography or doing pictures of kids with Santa at the mall requires SPEED, while maintaining quality. This also applies to coporate parties where couples wearing evenening clothes are photographed with instant delivery of 5x7 dye sub prints in folders. By having a modern digital camera with Firewire that does "Jepegging" in the camera, the image would come up on the screen in about 3 seconds vs. 10. Muliply that number times 7,000 customers and you can see why Jepeg is superior. I have printed, on a 4000, with BO, a Jepeg of a beach scene in Pacifica, CA. The original from a 50mm prime lens on a Canon 1D Mark II, handheld at 1/800 s. was a perfect exposure with K values ranging from 0-100 percent. After using my faovorited color to BW conversion, I applies a whisper of USM and a Tri-X curve sag. I then hit the print button. My older Zoner friends looked at this print in disbelief, thinking it had been done with a 4x5 or MF camera on tripod. The main reasons to shoot RAW is to have the ability to use the full dynamic range of the sensor for luminance compression in the image, do a different "emulsion characteristic" than what is offered with camera controls, or to correct for lens aberrations. Other than architectural or landscape work, I can't see why the extra time is ever needed for RAW workflows. Photos under controlled flash lighting and custom white balance to compensate for system color shifts in the ambient environments are just fine from high quality Jepegs, even when printed on large format inkjets. Jepeg is data lossy, but not visually lossy when "done right." Claude [Non-text portions of this message have been removed]
